SOURCE: How to install canon ir 3300 printer installed ?
First make sure a tech's installed the Canon Network Multi-PDL Printer Kit for the IR3300 (includes network kit and BOOT-ROM).
When you press the counter check button do you see IR3300(IR2200N)? If not then you don't have the printer kit installed.
If you have the print kit installed, the print drivers can be downloaded from the Canon website. You'll need to have your copier on your network.
You could then setup a local printer using a tcp/ip port (assign your copier a static IP address) on your server and then share it on your network.
SOURCE: error code e000007-0000 in caonon ir 3300
my canon ir 3300 shows error e-000007-0000 how can i solve this problem
SOURCE: canon ir 3300 drivers
You can download the drivers for Canon ir 3300 drivers from http://www.usa.canon.com/opd/controller?act=OPDDisclaimerAct&fcategoryid=2291&modelid=6363&id=30079&file=/cpr/software/devicemanagement/HP_Output_Server_v3.5_Canon_imageRUNNER3300.zip
