Question about Goodman CLQ36AR49 Air Conditioner
Goodman A60002R Air Conditioner
Pcb board need to change, What cloud be curse?
rockitman187
  • 2559 Answers
SOURCE: Do I need to change a filter? Where is the filter located?
Yes,The is a metal strip that is about 1.5 inches wide and held on with one screw,Just remove that and the filter is located there.
Posted on May 29, 2009
james3751
  • 614 Answers
SOURCE: My fan motor runs to slow and needs to be speeded
AO Smith motor speeds are Red low Blue med. And black high. Just unplug from fan switch plug in new speed. Turn power of first. Rus
Posted on Jun 18, 2009
farfield
  • 462 Answers
SOURCE: I have a 16seer ssx16 goodman air conditioner need
I dont have long but what exactly do you need to know about wiring?
Posted on Jun 27, 2009
  • 340 Answers
SOURCE: I have a Goodman air conditioner. My outside unit
If you are sure of the power then ya have a control problem thermostat set correctly? could be open low pressure switch I would call for service. Tom
Posted on Jul 03, 2009
the dr
  • 447 Answers
SOURCE: my air conditioner air handler humsbut moter does
either bad motor ....or.... if you are lucky a bad run capacitor. you will need some sort of capacitor checker and multimeter to diagnose it further.
Posted on Oct 31, 2009
My house was struck by lightning most of all my computers and tv's and phones are no working and my ac is not coming on at all. What happen to my AC unit
Hi and welcome to FixYa, I am Kelly.
The main Preinted circuit board (PCB) most likely has had a failure of the small PCB transformer. This is the most susceptable component (PCB transformer) in the Air Conditioner. Within the last 60 days I have personally experienced the exact same symtom. I replaced the PCB transformer and 1 diode on the main PCB of the air-conditioner and my AC unit is working fine. Unless you can find a source for the transformer your only option is to replace the PCB (Board).
Finding the exact transrformer for the PCB can take a very long time. It iwll look similar to this one: http://www.machsources.com/productimages/9913/pcb-mounting-transformer.jpg
If you have home owners insurance ALL STATE and State Farm often cover this type of damage. It is worth the time to find out if you are a home owner.
Thanks for choosing FixYa,
Kelly
Sep 13, 2011 | Frigidaire FAC085M7A Air Conditioner
Hello, we had central air conditioner installed last October. We turned our unit on for the first time and the outside unit shuts down but the air handler continues to blow air and never shuts down. ...
Hello, if the blower motor runs continuously and does not shut off at tne thermostat then the relay on tne integrated control board is bad. Only option is to replace the control board
Jun 28, 2011 | Goodman CKL36AR36 Air Conditioner
My modle number is aruf 036-00a-1 my serial number
MY MODLE NUMER IS CPLE42-1 SERIAL NUMBER IS 010940037
Aug 04, 2010 | Goodman CKL36AR36 Air Conditioner
My son has a Goodman Manufacturer Corp Heat Pump/air conditioner. Forced air I believe. The air conditioner quit. A repairman indicated that in order to replace the air conditioner the furnace will have to...
I don't see any reason to change the furnace unless it's an air handler and not a furnace with a coil on top or bottom. And then, the only reason to change the inside unit when you change the outside unit is because it's a R-22 system and your going back with a 410A system. They just discontinued R-22 equipment this year and not a lot are still available. But even if that's the case, the only thing they should have to replace is the coil and maybe the copper line set. That's all I can think of. Hope this helps!
Jul 14, 2010 | Goodman CKL30AR30 Air Conditioner
Goodman GPM075-3 air conditioning connections
your thermostat powers 'Y' for cooling. That in your case blue wire connects to 'Y' on the control board in the furnace. Then a pair of low-voltage wires connects 'Y' and 'C' on the furnace to the two wires to the coil of the contactor in the a/c condensing unit. So to follow the path, the signal wire from the thermostat sends 24v down the Y wire to the furnace board Y terminal which also connects to one side of the contactor coil in the air conditioner. To complete the control circuit to the air conditioner there has to be a common wire. This is connecting the C wire from the furnace board to the other side of the contactor in the air conditioner. Hope this helps.
Dec 11, 2009 | Goodman Heating & Cooling
I have a goodman heat pump and all winter it worked fine, now i set it for ac and stil blowing hot air
The reversing valve may be stuck or it has a burnt solenoid coil. Also, check the defrost relay accross the contacts with an ohmmeter and see if it's bad. Goodman heat pumps also trip on high pressure. There's a resettable switch on some units with a red button. However, I think the problem is in the defrost circuit or reversing valve. If your electric heat is on, change the board.
Apr 27, 2009 | Goodman CLQ36AR49 Air Conditioner
Will not go into defrost
Did you change the thermostat in heat pump? or did you change it when you replaced the board?
Dec 06, 2008 | Goodman CLQ36AR49 Air Conditioner
Goodman CLQ36AR49 Air Conditioner Logo
55 people viewed this question
Top Goodman Heating & Cooling Experts
Dan Webster
Dan Webster
Paul Carew
Tim Whalen
Are you a Goodman Heating and Cooling Expert? Answer questions, earn points and help others
