Question about Sony Handycam DCR-TRV60E Mini DV Digital Camcorder
Dv pin not work properly - Sony Handycam DCR-TRV60E Mini DV Digital Camcorder
Can I hook up to the DW 100 Canon burner with my ZR200 to burn mini tapes on DVD?
No. The Canon USA web site says the Canon DW-100 has a USB terminal and works with "USB 2.0 Hi-Speed (with compatible Canon camcorders only)." In other words, the Canon DW-100 burner works only with Canon's USB 2.0 camcorders. I have a Canon ZR200. The ZR200 has Firewire 400 digital video output, not USB 2.0 output. The USB port on the ZR200 is ONLY for still images. Video will not and cannot be output through the USB port on the ZR200. (Page 121 in the ZR200 manual mentions using the USB port on your camcorder for transferring still JPEG images to your computer.) You need a DVD burner with "DV Input" (also called Firewire 400 or IEEE 1394) to hook up your camcorder to burn Mini-DV tapes onto DVD. The Sony VRDMC10 Stand Alone DVD Recorder/Player has DV Input. The ZR200 camcorder did not come with a Firewire cable, but you can buy one at any electronics store or at a cheaper price online. Make sure that you get the right kind of Firewire cable, 4-pin to 4-pin or 4-pin to 6-pin, whatever the DVD burner you choose requires. (Your ZR200 has a 4-pin DV port on the camera's end.) USB 2.0 Hi-Speed (with compatible Canon camcorders only)
Mar 15, 2011 | Canon ZR200 Mini DV Digital Camcorder
Step by step instructions to transfer recorded videos from jvc gr-d370u to Pc, please.
First, you need a Firewire connection (also called IEEE 1394). Most of PC computers don't have it, including mine. I bought a cheap Firewire card and installed it into an empty PCI slot, costed about $15.
I hope you don't have the USB cable and the firewire cable plugged into your computer at the same time. That can break things.
With the firewire cable plugged into the DV port of the camcorder and the firewire port of the computer and the camcorder is in Play mode (and plugged into the wall AC power with the power adapter), are you saying that when you launch MovieMaker and "Capture", the video camera is not recognized?
There are only two conditions that can cause this:
1) The firewire400 port on the computer is not working properly (how do you know it is working?). If you are using Vista Home Basic, chances are good that the IEEE1394a firewire port drivers were never loaded... so, that will be your first step. Get that port working and you'll be ready to go.
2) The DV port on the camcorder is not working properly. This could be for several reasons, but lets hope the DV port was not fried if you ever had the USB and firewire connections to your computer at the same time... Reset the camcorder to factory defaults by disconnecting all cables, removing the rechargeable battery and removing the little date/time button battery inside the camcorder. Wait for about 20 minutes. Put the button battery back in, then put the rechargeable battery back on. Set the date and time. Connect the firewire cable to the DV port, connect the AC power adapter to the wall, connect the other side of the firewire cable to the firewire port on the computer, launch MovieMaker - will it "Capture" from the video tape?
Anyone you know nearby with an Apple Macintosh and iMovieHD? You will need a 4-pin to 6-pin firewire cable and the AC power adapter. If it works with the Mac, we know it is not the camcorder's DV port. If it does not work, chances are good the camcorder's firewire port is bad.
Hope this was helpful?
Jan 30, 2011 | JVC GR D370US camcorder Mini DV
I have a jvc gr-d33 and am trying to transfer mini dv to dvd through my laptop toshiba satellite l355. on my jvc i have the 4 pin dv and know it has to transfer through firewire but on my toshiba i dont...
I'm afraid that there is chatter on the forums that these Firewire to USB convertors don't work properly with video cameras. That doesn't mean you can't try it, of course.
Most PCs have a USB port, but no Firewire port. Macs often have a Firewire port but may not have USB. If you have a Windows desktop PC, you can fit an add-on Firewire interface card. This will come with a driver for the card. No help on a laptop unfortunately.
Nov 20, 2010 | JVC GR-D33US Mini DV Digital Camcorder
Firewire problem
It should work. Laptops have a 4pin connection. There is a video on how to specifically connect digital cameras to laptops using 4pin to 4 pin IEEE 1394 cable. So it should work... The video is on www.HandBookLive.com under Electronics category. It doesn't cover the software because all softwares would be different, but you can see that it uses 4 pin to 4 pin. You can double check on this site though.
Sep 06, 2008 | JVC GR-D20EK Camcorder
Problem with DV output on ag-dvc30
It is possible that you have a faulty firewire port or cable that is sending electricity through one of the pins that is not designed to handle it. If one of the six pins at one end of a cable is bent, for example, it can electrocute whatever is at the other end.
It's been a while now - did you ever get this problem solved?
Aug 08, 2008 | Panasonic AG-DVC30 Mini DV Digital...
NOt recognized
if your trying to download video usb won't work! must use firewire cable hooked up to dv port on cam and connection on laptop or tower called 1394-cable is either 4 pin or 6 pin-depends on computer- cam is always 4 pin-says dv on camcorder-usb only for still pics-use windows movie maker in xp or vista to edit
Jun 28, 2008 | Canon MV700 Mini DV Digital Camcorder
Jvc gr-d72u
use firewire cable from your dv port to stream video-4-4 pin for laptop 4-6 pin for mac or tower
May 17, 2008 | JVC Cybercam GR-D72 Mini DV Digital...
Panasonic dv web cam I cant dect it on my computer
Most likely you are connecting the camcorder to the PC via USB. In that case the video most likely cannot be transferred due to the fact that this is a master-slave (copy and paste) interface. In this case you would need a peer to peer (streaming) interface to copy from the miniDV tape - which would require a DV cable. The camera may have a 4-pin, but your PC might have a different configuration - usually also 4-pin or 6-pin. When you find out, you will need to get a 4-pin to X-pin DV interface cable that is OHCI compliant and you should be set. To capture the video, put the camera in playback mode and use whatever software you prefer - MovieMaker works well. Good luck.
Feb 25, 2008 | Panasonic NV-GS25 Mini DV Digital...
Connection
Only DV connections (IEEE1394 connections) are possible when connecting your camcorder to a computer. DV connections (IEEE1394 connections) Your camcorder can be connected to a computer equipped with an IEEE1394 (DV) terminal or OHCI-compliant IEEE1394 capture board. You can transfer taped recordings (digital video signals) to the computer by connecting the camcorder to the computer. Use the editing software supplied with your computer/capture board to transfer video recordings from tape to the computer. If you are using a computer running Windows XP, you can also record the video simultaneously on your computer's hard disk and on the tape using DV-PC Recorder Software. You can download the DV-PC Recorder Software from Canon's DV-PC Recorder Web site. Making the connection Connect the camcorder to the computer as shown in the figure below. The computer's IEEE1394 (DV) terminal is either a 4-pin or a 6-pin type, depending on the computer used. Use either the CV-150F (4-pin - 4-pin) or the CV-250F (4-pin - 6-pin) DV cable (sold separately), whichever fits your computer's terminal. Precautions (1) There are cases where the connection may not work correctly, depending on your system specifications/settings. (2) If the computer freezes while you have the camcorder connected to it , disconnect and reconnect the DV cable. If the problem persists, take the following actions. (2-1) Disconnect the DV cable from the camcorder and the computer, and then turn off the camcorder and the computer. (2-2) Turn the camcorder and the computer back on and then reconnect them with the DV cable. (3) Your camera cannot be used with DV NETWORK SOFTWARE (DV Messenger).
Sep 04, 2005 | Canon XL2 Mini DV Digital Camcorder
Sony Handycam DCR-TRV60E Mini DV Digital Camcorder Logo
Top Sony Video Cameras Experts
Larry Stiles
Larry Stiles
Jerry Greenberg
Jerry Greenberg
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
