Question about Texas Instruments TI-84 Plus Calculator
Ive lost the graph lines on the TI 84
I no longer have the graph lines on the display.
    New Friend:
Press [2nd] ZOOM, scroll down, and select AxesOn.
Posted on Apr 18, 2013
SOURCE: entering inequalities into TI-84 to graph
Then push the graph button finally.
Posted on Feb 28, 2008
FusionDude
SOURCE: I am trying to use
Press 2nd, then 0 (this will take you to the Catalog)
Scroll down until you see "Axes On"
Hit Enter twice
TADA!!!
Posted on Feb 11, 2009
  • 88 Answers
SOURCE: I can't graph on my ti-84 plus silv. edition
More than likely, you've put in a number in the xmin or xmax that is not correct. Example....you put in an xmin of 10 and an xmax of -10 which would be backwards. This could also happen in the ymin or y max.
The easiest way to fix this is to press zoom 6 which wil get you back to the default graph of xmin of -10, xmax of 10 and ymin of -10 and y max of 10.
If you can't see your graph on this screen and need to change the window, just be sure the number in the min for both x & y is smaller than the number in the max. You change your window size by pressing the window button.
Posted on Aug 15, 2009
  • 8073 Answers
SOURCE: TI 84 won't graph more than one function
If you have used or just run the Transfrm Application, you will no longer be able to draw more than one graph.
To restore the native OS graphing capabilities Uninstall the Transfrm Application. Here is how to do it.
  1. Press the [APPS] key.
  2. Scroll Up to reach the bottom of the list faster.
  3. Point to Transfrm and press [ENTER].
  4. Select [1:Uninstall]
Note: Do not worry about Uninstall, it will merely kick the application from memory. Transfrm will still remain in calculator.
Posted on Apr 17, 2010
  • 102366 Answers
SOURCE: on my ti 84 plus
You're probably trying to graph a function that does not involve stat plot features. You can correct this by turning off the stat plot features. Press "2ND" "STAT PLOT" and then select 4:PlotsOff.
Posted on Sep 27, 2010
Does the Sharp EL -520X do the same as a Texas instruments ti-84
No, the EL-520X is a scientific calculator while the TI 84 Plus is a graphing calculator. It can display graphs which the Sharp cannot do.
Dec 01, 2015 | Texas Instruments Office Equipment &...
My TI-84 will graph but it will not show me the table of values. It just shows up blank.
Enter the function using the Y= editor. Pressing [ 2nd ][Graph] (table) will display the table. You can then press [GRAPH] to see the grapg. If you want both graph and table side by side use the split screen feature.
To do so press [Mode]. Scroll down to the last line Full Horiz G-T. Highlight the option G-T. Press the Graph key.
Sep 24, 2013 | Texas Instruments TI-84 Plus Calculator
My TI-84 Plus won't let me graph trigonometric functions.
Is it somehow preventing you from graphing, or are you simply not getting the graph you expect?
Most likely you have the angular mode set wrong. You probably want it set to radians. Press MODE, move to the third line, highlight RADIAN, press ENTER, then 2ND [QUIT].
If it's not the angular mode, please reply to this post and give an example or two.
Mar 22, 2013 | Texas Instruments TI-84 Plus Calculator
On my ti 84 i downloaded a program called mirage os and now i have lost the ability to graph. When i try to graph it just say invalid dim. How do i fix this?
Nov 28, 2010 | Texas Instruments TI-84 Plus Calculator
How do i get rid of the shade when i press graph on my ti 84 plus graphing calculator
Press the Y= key. Move to the equation in question, then press left-arrow repeatedly until the cursor is at the far end of the line. Press ENTER repeatedly to cycle through the different graph styles. The default is the four dots in a diagonal line from upper-left to lower-right.
Sep 15, 2010 | Texas Instruments TI-84 Plus Calculator
How to use graphing caculator, TI 84?
Turn StatPlotsOff to avoid errors:
Press [2nd][STATPLOT][4:PlotsOff][ENTER].
  1. Verify that in [MODE] Func is highlighted.
  2. If it is not, use arrow to highlight Func and press [ENTER[ to validate.
  3. Press [Y=] and type in the functions.
  4. Press [ENTER] at the end of each function.
  5. Before pressing [GRAPH], make sure that all the = signs that define the functions to be graphed are highlighted white on black. If one is not highlighted, use arrow to move cursor on the sign and press [ENTER].
  6. Select the graph styles: The small piece of line to the left of a Y that defines a function is the style. Move cursor on it and press [ENTER] . Each [ENTER] (on same line) selects another style.
  7. Press [GRAPH] to see the graphs.
  8. If one of them is missing, verify that its = is still highlighted, then use the [WINDOW] to set the Window dimensions, or the [ZOOM] to adjust.
If you have problems, post a comment to this thread.
Mar 10, 2010 | Texas Instruments TI-84 Plus Calculator
How do i solve this problem 3x+25=5x using my TI 84 plus
i think there are programs but with something as simple as that you should be able to work it out manually....
3x+25-5x=5x-5x
-2x+25-25=0-25
-2x=-25
x=25/2 or 12.5
Jul 05, 2009 | Texas Instruments TI-84 Plus Calculator
LOST MANUEL
In pdf format:
http://education.ti.com/guidebooks/graphing/84p/TI84PlusGuidebook_Part2_EN.pdf
Mar 29, 2009 | Texas Instruments TI-84 Plus Calculator
Texas Instruments TI-84 Plus Calculator Logo
107 people viewed this question
Top Texas Instruments Office Equipment & Supplies Experts
k24674
Stevan Milanovic
Are you a Texas Instruments Office Equipment and Supply Expert? Answer questions, earn points and help others
