Canon pixma mp4900 has 5b00 error how can I clear it
5 Suggested Answers
cropp
  • 377 Answers
SOURCE: canon mp150 pixma printer error e5
dear warenout
try this methode
Methode 1
1) With the printer powered off but connected to a power source, press the Power button while pressing and holding
the Stop/ Reset button.
2) When the Power LED is lit, press the Stop/Reset button two times while pressing and holding the Power button.
3) When releasing the Power button and the Stop / Reset button (regardless of order), the printer will move into a
service mode. (Waiting formenu selection)
4) When the LED lights in green, press the Stop/Reset button the specified number of time(s) according to the
function listed in the table below.(Each time the Stop/Reset button is pressed, the LED lights alternately in
orange and green, starting with orange.)
The number of the Reset
button pressing
LED Function Remarks
0 time Green Power off
1 time Orange Service pattern print
2 times Green EEPROM print
3 times Orange EEPROM reset
4 times Green Waste ink counter reset See waste ink counter reset
procedures below.
5 times Orange Destination setting See Destination setting
procedures below.
6 times Green Print head deep cleaning
11 times Orange Button / LCD checking
12 or more times Returns to a menu selection
that's all
maybe it can fix your problem
thanks
cropp
Posted on Mar 15, 2008
SOURCE: Service error 5100 on my canon Pixma mp110
just replaced the ink cartridges and reset the counters, evrth ok now :-)
Posted on Nov 09, 2008
pineworks
  • 4041 Answers
SOURCE: canon pixma ip1700 printer error 5100?
Hi You can Try 2 things.
ERROR 5100 means that there is some foreign object blocking your cartridges carriage that disables it from moving. Generally when this happens, something has fallen into the printer, or a piece of paper has been jammed in there.
First step, remove the ink cartridge, and turn the printer upside down and gently shake it, see if anything comes out.
If nothing goes, or you can't hear anything rattling around, get a piece of cardstock paper (60lb or heavier) and gently push this through the printer, to see if it will help push out what might be stuck in there
Next try.
It may be a piece of paper or a scotch tape or a staple wire.
Solution 1:
Clean the timing strip.
Solution 2:
The purge cap (the white sliding mechanism that the print head parks to when it's not in use) may be not lubricated well enough .
Lubricate the sliders with some white grease (don't get it on the small wipers or the black caps); this repair probably require to remove the right panel off of the printer to gain access to the purge mechanism.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Posted on Feb 20, 2010
  • 219 Answers
SOURCE: 5100 error message on canon
This is a generic error for a problem with the print carriage. Unplug for 30 seconds then replug, clean the cartridge's contacts, check and make sure the encoder strip is not out of place behind the carriage. Do a full cleaning of the print head manually:
(1) Open the printer
(2) Remove the ink cartridges from the print head.
(3) Use cotton swabs dipped in hot water to thoroughly clean the print head.
(4) Repeat this until there is no ink residue coming off on the cotton swab.
(5) Once finished, allow to dry and replace the cartridges
(6) Try to print something now
If none of that works, most likely you need a new print head
Rate my answer then, please
Posted on Jul 06, 2011
How to clear e000067 for canon irc2880i copier
Are you looking for Canon printer support number to sort out issue related with your printing machine? We also provide the Canon Printer customer Support, Canon Pixma Support Number, software installation, software upgrade, cartridge jam, paper jam issues and much more. Canon Pixma Printer Support
Jan 18, 2016 | Canon Office Equipment & Supplies
How to clear error code 5010 on canon pixma mp460 all in one printer
Check the manual that came with it for the answer to the codes.
Jul 20, 2014 | Canon PIXMA MP460 All-In-One InkJet...
Canon pixma IP 2770 error code 006
U have to download resetter file
http://imadeitthisway.blogspot.com/2010/09/canon-ip-2770-reseter.html
http://m4sjoysaja.blogspot.com/2010/08/how-to-reset-clear-counter-canon-ip.html
I hope its working
Jan 18, 2012 | Canon Pixma iP2700 InkJet Photo Printer
Error code 6A00
Step by Step troubleshooting canon pixma MP800 error code 6A00
The Problem Canon PIXMA MP800 Error 6A00
1. The print head cartridge keeps locking itself up on the right hand side.
2. Frequent 5100 errors even when the printer is on standby
3. Even when I wipe up the print cartridge, the next print will
mess up the bottom of the print cartridge with ink again.
Step for troubleshooting canon pixma MP800
1. Opening the cover and wait for ink carriage to center
2. Pull out power cord
3. Pushed carriage to far left (should slide easily)
4. Used paper towel and wiped purge unit a lot of times
(press down to soak paper towel with ink). Repeat until the paper towel is relatively clear.
5. Used diluted napisan (oxygen-based cleaning agent in the
ratio of 1:3 with powder:water) and soaked paper towel
6. Repeat step 4 with wet paper towel. Repeat until purge unit is near-white.
7. Pulled and pushed clear plastic wiper (north of purge unit) and wiped it down
8. Slided carriage back to original position
9. Removed Print head cartridge and wiped out excess ink stuck on bottom.
Mar 01, 2011 | Canon PIXMA MP800R All-In-One InkJet...
I have a Canon Pixma MP780, keep getting "clear ADF" messages. changed the settings to off. Also, scanner is giving me some error messages #2, #178
Try Canon support. Type your query. Click "Search"
Example: Type "clear ADF" (You may have paper or some obstruction in the Auto Document Feeder).
http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&fcategoryid=238&modelid=10444#SupportDetailAct
Nov 30, 2009 | Canon PIXMA MP780 All-In-One InkJet...
How to clear the error E007? The red light is on
You cannot clear this error, you need to replace the fixing film.call service
Apr 09, 2009 | Canon PIXMA iP1800 InkJet Photo Printer
37 people viewed this question
k24674
jasbo
jasbo
