Question about Vizio P50HDTV10A 50 in. Plasma HDTV
50 INCH VIZIO GALLEVIA - Vizio P50HDTV10A 50 in. Plasma HDTV
4 Suggested Answers
SOURCE: Standby power usage of the 42" Vizio Gallevia?
According to a Cnet review of the 42" Vizio Gallevia, the standby power usage is only .75 watts. Because it is so low, I now have no concern about leaving the set in standby mode. Virtually no savings to be realized by unplugging the set between usage.
Posted on May 19, 2009
  • 8457 Answers
SOURCE: my vizio 50 inch plasma tv will not turn on. what
Tries unplug,replug about an hour,see if it reset itself.Not than must replaced the signal tuner board.Plasma have this problems alot.
Posted on Jan 08, 2010
  • 5129 Answers
SOURCE: How can you tell if the bulb on a vizio gallevia
LCD TV's don't have a bulb. They have backlights (usually compact fluorescent tubes) and a panel of LCD pixels. So you can have one of three things fail: the video board, the inverter that drives the backlights or the backlights themselves. If the problem happened suddenly the inverter is more likely to have failed. As the backlights fail, the screen slowly dims or the image will become pink/red. Look closely at the screen, if you see a dim image then the backlight has probably failed (block the room light but try looking with a flashlight from a few inches away from the screen). If you see nothing, the inverter or the video board are more likely suspect.
For an out-of-warranty TV, open up the back of the TV and remove the shielding. Look for any scorch marks or bulging or damaged capacitors. (Sometimes other parts will fail on this part but these can be spotted easily. Capacitors look like cylinders on a tripod.) The scorch mark and smoke may indicate a resistor or zener diode that had been used as a fuse and is now gone.
If you borrow (or have a) high-end multimeter (able to measure high frequencies - 50 kHz) or an oscilloscope, hold the multimeter probes a fraction of an inch apart about an inch above the inverter board and power up the TV. If you see a 1 or an actual value, you have a good inverter. If you see a reading near 0, the board is bad or the multimeter can't resolve the frequency.
In either case, you can buy a replacement inverter for $50-150 and just do a simple swap. Disconnect all of the wires (connections are similar to molex and ribbon cables in a computer) and remove board (a few screws usually). Connect the cables to the new inverter. (If you google backlight inverter replacement, you'll find videos and text descriptions.) Note the part number on the board, including the Rev number, and order the exact one (shopjimmy.com or lcdparts.net are good starting points). Universal inverters do exist but can result in reversed controls (up to lower the brightness). Replacing individual parts on the board is cheaper but more prone to not tracking down all of the bad parts.
If the inverter is good, then it's probably backlights themselves (several in most TVs). These are sandwiched on the perimeter of the TV (usually under some tape that holds the lamp, reflector and other parts together. You need to order by length and width and get ones for your TV size. Separate the panel from the bezel. Remove the tape, and separate the reflector (make a note of how things are put together) then you have to Dremel (or use another rotary tool) to remove the plastic to get the backlight out. (They are often molded into the frame.) Then put in the new backlight and reassemble everything. (http://www.lcdparts.net/howto/default.aspx) but for an overview: http://www.inventgeek.com/Projects/BacklightFix/overview.aspx Then push the new backlights into place, reconnect the wires and close up the sandwich of tape and other parts around the screen. Then replace it in the bezel.
With a good spare backlight, you can test an inverter for condition (plug together and turn on the tv while the box is open). Similarly a good inverter can test the backlight.
I hope this helps.
Posted on Sep 22, 2010
Vizio Gallevia can't see whole picture
Check the button for picture size and adjust accordingly.
Sep 18, 2015 | Shopnbc VIZIO Gallevia 46" 1080p LCD HDTV
Is there a special bracket to mount the 50 inch D series vizio to the wall?
Many aftermarket mounting brackets are virtually universal in application provided your 50-inch Vizio TV can meet the size and weight limitations stated.
Nov 29, 2014 | Vizio VP504F 50-inch 1080P Plasma TV...
When I turn on my Vizio Gallevia 42" tv it Just Shows a Blue screen and no signal then turns off
Have you got anything connected to the TV? If so, make sure they are powered on, and all connected correctly.
Hope this helps
TV_Doctor
Jan 03, 2011 | Vizio Gallevia GV42LF 42 in. LCD...
Hi there-I just hung a new 42 inch Vizio at my Dad's house and he said he can smell something burning... I hung the tv on Monday a week ago... any ideas?
check the screws that you used to install plate on the back of tv some times they are to long ,it can be pressing up against circet board with out you knowing
Nov 02, 2010 | Vizio Gallevia GV42LF 42 in. LCD...
Hi, My Vizio Gallevia 42 is showing a "no signal" message and then shutting itself off. Do you know what that means?
Dec 23, 2009 | Vizio Gallevia GV42LF 42 in. LCD...
May 18, 2009 | Vizio Gallevia GV42LF 42 in. LCD...
Thinking about buying a used Vizio 42"
Don't buy it. VIZIO is not standing by their products.
My GV42L had issues from the ssart and now it shows No Signal and shuts of in 2-3 seconds. I read many similar issues on this site with VIZIO.
Sep 27, 2008 | Vizio Gallevia GV42LF 42 in. LCD...
Vizio P50HDTV10A 50 in. Plasma HDTV Logo
35 people viewed this question
Top Vizio Televison & Video Experts
CoppellTVRepair.com
Computer Repairing
Computer Repairing
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
