How to clean tub of wa 82 vsl
I want to clean the tub of the samsung wa82vsl washing machine...how to do it???
5 Suggested Answers
  • 51 Answers
SOURCE: I have Samsung washing machine WA 85 V9. Please
Go to this site and download your manual
www.samsung.com/au
Posted on Jun 12, 2009
  • 441 Answers
SOURCE: I've got a Samsung Toploader washing machine,
You can use a online source such as marcone.com and just have it shipped
Posted on Jul 16, 2009
SOURCE: Clean LG WF-T652a Top Loader Washing Machine
I have this problem too and I solved it easily !!!!
I hypothesised that something was blocked by dried up lint/silt. So I filled the machine with very hot water and also poured hot water down the lint filter outlets. I left it for 5 minutes and then started a wash cycle - and the water now comes out of the lint filter ducts. ! :-)
Posted on Jun 19, 2010
blueextc3221
  • 15935 Answers
SOURCE: gorenje washing machine WA 72145 washing clothes
This advise is for Kenmore Elite and Whirlpool Duet front loader washers and dryers with a Control Lock problem.
This may or may not be an indication of a serious problem. In the majority of the cases, this is a simple operator error. Nearly all these model appliances have some sort of Control Lock feature on the front panel now. This is a designed safety feature that is used to prevent small children from manipulating the controls. The controls can be easily locked or unlocked by pressing and holding the following button on the front panel:
Whirlpool Duet Washer - Press and hold the END OF CYCLE SIGNAL button for 3 seconds.
Whirlpool Duet Dryer - Press and hold the END OF CYCLE SIGNAL button for 3 seconds.
Kenmore Elite Washer - Press and hold the DRAIN/SPIN button for 3 seconds.
Kenmore Elite Dryer - Press and hold the AUTO DRY LEVEL button for 3 seconds.
These instructions may not be all inclusive for all Kenmore and Whirlpool models, but they are the most common. Chances are, if you have a Control Lock feature, the instructions will be printed on the front panel adjacent to the button that is required to lock or unlock the controls.
NOTE: These instructions may also work for newer model Maytag, Hotpoint, Admiral and Fridgidaire model front loaders as well. Refer to your owner's manual or front panel for instructions pertaining to your sepcific model.
If the Control Lock feature will not lock or unlock the appliance, unplugging the unit for AT LEAST 30 minutes is recommended in order to reset the main control board. In many cases this is all that is required to correct momentary glitches.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Oct 01, 2010
IGET SOME BLACK STUFF AFTERWASHING LIKE THE DIRT FROM THE TUB
Very well could be excessive buildup which would mean it would need possibly a extra rinse to help clear up. When was the last time you did a tub clean on the unit?
Mar 01, 2016 | Samsung Wa95v3 7.5kg Washing Machine For...
Samsung model wa 7584C1. has 1E error code have changed pressure switch and tub hose still shows the same error please help
IE - Water level sensor fault This fault code is fairly self-explanatory and tells you that the washing machine has detected an error with the pressure sensor or pressure switch
  • Check water level sensor
  • Check wiring to water pressure sensor
  • Check connections to water level sensor
  • Check main electronic controller
  • Apr 06, 2015 | Samsung Washing Machines
    I have a Samsung Sw62asp washing machine. How do I take the tub out to check that there isn't any hair clips stuck as it makes a really bad clicking noise when it is spinning out. Thanks
    You can remove the front kick panel and remove the tub to pump hose to clean it out. You also have very easy to access from rear of washer
    Check that the motor transmission coupling is not coming apart as well. You should never have to remove the tub, this is a very time and labor intensive job.
    Jul 14, 2011 | Samsung SW62ASP Top Load Washer
    We clean the filter after every wash but we still get black & white bits on the washing wa have cleaned the waste pipe, pump filter at the back is always clean .model no sw75usp can you help under...
    Hi bob, have you tried cleaning the dispencer drawer that supplys the detergent to the tub? in some cases over time the detergent holder can collects small amounts of powder that can dry out and stick to the walls of the holder and when the machine is in its spinning stage can sometimes vibrate the dry powder in turn cause the powder to enter the tub also there can be a huge build up of liquid detergent like softners that can form a hard black residue in the holder in turn causing the clothes to collect black paticles. If all is ok then you could try applying a hot wash cycle without any clothes in the tub to flush the bowl from any contaminents, thumbs up if this helps thanks.
    May 06, 2011 | Samsung Washing Machines
    How do I open the drum in an Indesit washing machine
    remove back cover. remove heater held in by 1 10mm nut, prize heater out and you can see into the gap between tub and drum and fish object out
    Sep 06, 2008 | Indesit WA 125 Front Load Washer
    Samsung washing machine filter
    it has a self cleaning filter. if you want to clean out the tub and filter thoroughly then:
    • run a cycle with no clothes using hot water and a gallon or two of bleach.
    • after the tub has filled up add a teaspoon or less of dish liquid like palmolive. this acts like a surfactant for the bleach.
    • make sure you also run an extra rinse cycle to make sure you have all the bleach out of the machine before putting clothes in.
    Aug 04, 2008 | Washing Machines
    Washer won't drain completely
    water sond when tub is spun by hand is normal. there will always be wa terinside machine betwen tubs, maytag even uses a waterfilled tub ring for counter balance, totlly normal to hear. as far as mildew smells, use www.affresh.com
    Apr 12, 2008 | Maytag Neptune MAH5500B Front Load Washer
    Washing Machines Logo
    42 people viewed this question
    Top Washing Machines Experts
    Gerry Harvey
    Gerry Harvey
