Question about Welding Tools
I have a Lincoln welder sa 250 d3.152 I was wanting to know which is the positive on exciter ring or brushholder front or back brush holder?
CarlGehrke
  • 169 Answers
SOURCE: lincoln ranger 250 voltage problem
Check the current control resistor with an ohm meter. The center terminal should have a smooth rise or fall of resistance when measured to one end or the other of the resistor. If the resistor and the wiring to it are OK, check the shunt in the output it'll be by the "electrode" terminal. If both are OK you probably have a bad control board.
Regards,
Carl
Posted on Feb 23, 2009
  • 4 Answers
SOURCE: WILL THE LINCOLN SP125 MIG WELDER WELD ALUMINUM AND STAINLESS?
The mig welder should be capable of welding aluminum not stainless but the makers should be able to give you more detail. mig is used for steel and aluminum normaly but I do not know this transformer
Posted on Apr 08, 2009
  • 225 Answers
SOURCE: what is the 250 class mig welder to buy the miller
I was warrenty repair shop for lincoln, esab ,miller, hobart,and clark for five years .my expereance with lincoln as far as customer sevice they dropped the ball alot,miller on the other hand had great cusomer service.My opinion the miller family is the way to go for dependability,parts,and service.
Posted on Jul 12, 2009
  • 25 Answers
SOURCE: How do you ignite a Lincoln Electric Welder???
You don't need an striker with a MIG welder just hook the ground cable to the base metal point the nozzle where you want to weld and pull the trigger and it will weld. Household current will run a MIG welder Take a look at the plug on the welder if it will pug into a 110v outlet you are all set, but most likely you will need a 220v outlet and maybe as much as an electric dryer type outlet.
It takes a lot of practice to be a decent welder you also need to know what voltage and wire speed settings to use for a given thickness and type of material.
You don't mention shielding gas, if you are using a flux core wire you don't need it, but if you are using regular wire you do.
If I may make a suggestion, If you really want to learn how to weld, find a community college near you and take an introductory welding class. You will get a wealth of information and practice on different welding processes. The instructor will work with you and get you welding much better and faster than you will on your own. Most importantly you will get a lot of safety information.
This is a good introductory book:
http://www.amazon.com/Welders-Handbook-RevisedHP1513-Cutting-Oxyacetylene/dp/1557885133/ref=ntt_at_ep_dpt_1
Posted on Mar 04, 2010
SOURCE: sp-200 lincoln welder
Go to the following link:
www.weldingsupply.com
Posted on Dec 14, 2010
Why will it not rev up
Welder Idles but dosnt rev up so when i strike an Arc [Archive ...
www.hobartwelders.com > ... > EQUIPMENT TALK > Generator/Welders
Apr 21, 2008 - 7 posts - ‎4 authors
... is good there,I have continuity from the wire there back to the Auto Idle Module,and i... If it does not affect the idle. then check these things. ... out,,can i put a PTO cable on the throttle and pull up the RPMs when i weld? right ... Benefits of Stick?
Sep 26, 2007
SA 250 will not strike an arc
May 7, 2006
Lincoln Weld-Pak 100hd.. Need some opinions, =]
Jan 15, 2005
Aluminum repair
Mar 19, 2003
More results from www.hobartwelders.com
SA-200 Idler Troubleshooting - Weldmart Online
https://www.weldmart.com/main/.../sa200idler_troubleshooting.html
The solenoid pulls the carburetor throttle plate closed and the engine drops to idle ...Turn it off (close it) and the solenoid releases; the welder idles up. ... If it does show power-with the engine off, remove the wire and recheck the terminal. ... B. The idler solenoid is good but it will not idle up when you strike an arc, or when a ...
Idler control for sa 200 lincoln welder - American Welding Society
Dec 08, 2015 | Welding Tools
225Bobcat gen.runs but will not excite when trying to strike arc
#Tags bobcat 250 welder service manual
coop.bounceme.net/term/bobcat-250-welder-service-manual
Why does my miller bobcat welder generator not stay at an idle when swithed to low idle, insted it goes back and ... Won't strike an arc,fuses ok brushes and slip.
Aug 11, 2015 | Electrical Supplies
How do you split the engine from the armature on older Lincoln Red Face welders?
Remove the roof, front panel, exciter brush holders, exciter nut, centering collar, exciter armature, exciter frame, generator housing, then the main armature. Support the engine carefully while doing this. I am a certified Lincoln tech and I do this monthly. Cutting the bars in the bell housing to get to the flex plate bolts can lead to a broken crankshaft. I have a poor fellows broken crankshaft here to prove it. So, please do it correctly and carefully. Also, change the armature bearing. It's cheap insurance.
Feb 26, 2015 | Lincoln Welding Tools
Lincoln classic 3 d welder
The Lincoln Classic 3D welder has a flashing diode attached between the main generator brushes, this is a cathode to stud diode which also has an NC MOV connected across the circuit for protection from field collapse, it is attached to a copper band and is easily seen, remove the generator cover, standing in front of the welder with the cover removed, it should be on the right side.
This is a common problem on this machine, and is simple to test & replace.
also,... attached to the back of the front control panel of the machine is a 20 amp glassine fuse, next to a 40 amp 800 volt bridge rectifier, both also easily tested and replaced.
check the conduction zone on the exciter brushes, the surface of the brush riding on the slip rings, or commutator, depending on which machine you have, should be 'shiny" and smooth, indicating and insuring proper conduction.
Apr 14, 2014 | Lincoln Electrical Supplies
Oil dip stick blows out of holder
first check your crankcase vent if it is clear the rings could be stuck or worn out if it has alot of hours or it was ran without a aircleaner. if the vent is clear try to put a little bit of transmisson fluid in the gas to loosen the rings up GOOD LUCK
Mar 18, 2013 | Lincoln Ranger 250 Gxt Welder Generator...
Lincoln diesel welder not working
Put a 9 volt battery across the slip rings of the exciter for a moment to "Flash" the exciter. If the first attempt does not work, reverse the polarity of the 9 volt battery. It only takes a few seconds. This creates the initial magnetic field that makes it work.
Mar 25, 2012 | Welding Tools
My lincon welder sa 250 won;t turn on after i turn it off
Lincoln's welders have a very weak on/off switch sometimes you need to wiggle the switch a little bit to help make contact. Try this, open the welders cover and using an insulated tool and insulated gloves try to bridge the switch. If the machine makes contact then buy a new on/off switch and change it.Other tip is to check your cable plug to see if all cables are still in place.
Nov 10, 2011 | Welding Tools
Ranger welder does not generate enough dc current to weld with and only enough current to turn a ac drill very slowly. checked wires seem to be ok.
clean the brush rings with a very fine emery cloth is still then there is a controller board issue at that point it will have to go to a service center do to there are no supplier's for them other that Lincoln go to their sit HERE and find a service center in your area these boards range from $250.00 to $600.00 there is 4 of them in the machine they will have to remove the top and swap the boards till they find the right one have the same welder i have been through this with Lincoln already hope this helps
Aug 09, 2010 | Lincoln Electric Ranger Gxt 250 Amp...
My welder an sa-200 revs up like its in working
some welders have a load meter that is ajustable on the plugs look for someting like that you can dial in how much power is able to go to the plugs on some of them
Nov 10, 2009 | Lincoln Welding Tools
No power to weld or use A/c power outlets
You don't say what model welder you have, some Miller welders have 3 slip rings and brushes some have just 2. In either case the next step is to use an ohm meter to check the resistance of the rotor and brush assembly. If this is a 2 slip ring model, take one of the wires off of one of the brushes then measure the resistance between the 2 brush terminals - it should be something between 10 and 100 ohms. If you get an open circuit measure the resistance from one slip ring to the other right at the slip rings - if you now get something other than an open you've got bad brushes (about $10 each to replace),
The 3 slip ring models are similar but have 2 rotor windings - take off the wire from the middle brush and measure from it to each of the ends.
If your rotor and brushes checked out OK you should next check the fuse in the exciter circuit, this will be on the block where the other end of the brush wires go.
If the fuse was good you need to do an excitation test. This is a bit dangerous so be careful. Look at the schematic pasted inside the case and figure out which brush is the positive (+) one. The wires are numbered and so is the schematic so this isn't as hard as it might seem.
Disconnect the wires from both brushes (all 4 wires in the 3 slip ring model) and tape them off so you won't get shocked. Get a 9V battery or make up jumpers that will let you connect the welder battery to the brushes. Start the welder and connect your temporary power supply, measure the AC at the outlets (it should be around 60VAC with a 9V battery) and the DC voltage at the weld terminals (should be above 10V), lastly measure the voltage at the wires you disconnected from the brushes (should be around 70V DC). Disconnect the temporary power supply and shut down the welder.
If you didn't get AC at the outlets and DC at the weld terminals above, something is wrong with the stator in your welder. If you didn't measure any DC on the wires that go to the brushes (most likely thing to happen), you've got something wrong in the exciter circuit. Check the rectifier, the capacitor, the exciter winding in the stator, and lastly the current control board. Older welders will also have the fine current control rheostat in this circuit (look for burned windings on it).
That's about all of the general advice I can give you without knowing more about which welder you have.
Carl
Oct 23, 2008 | Miller Welding Tools
Welding Tools Logo
Top Welding Tools Experts
Bill Boyd
Are you a Welding Tool Expert? Answer questions, earn points and help others
