Question about Coffee Makers & Espresso Machines
I'm having trouble with my CBTL kaldi. When I turn
  • 1089 Answers
SOURCE: the red light for descaling won't go off after descaling
The button to push was the steam button and hold for 5 to 10 seconds until the light goes out.
Posted on May 21, 2009
SOURCE: My Keurig B60 is Suddenly Brewing WEAK Coffee
I don't have a solution but have just experienced the same problem and am baffled. I am using the same beans same grind. In fact using the exact same grind it went from great one day to weak the next day.  I always run it for 15 - 16 secs to get the shot and that hasn't changed. Pressure and temperature appear fine. I cleaned the top of the top filter which was a little dirty but not seriously bad - no change. The coffee flow which is normally chocolate coloured to start with is just mid brown.
Posted on Feb 28, 2010
  • 5 Answers
SOURCE: Senseo coffee maker not working
One of two things, first of all, it wont open until it cools down/depressurizes. First problem is that the ground coffee is two fine, and the second possible problem is that the coffee is packed too tightly. That is assuming that you dont use the pads but coffee pad adapters.
Posted on May 23, 2010
  • 1089 Answers
SOURCE: the machine is still turning on however the light
HI I would suspect the thermostat on top of the boiler. it is 2 red wires with a little thermal couple on the end. Could be broken or bad. Goes to the board.
Posted on Oct 04, 2010
SOURCE: Saeco Talea Giro Plus, descaling
Try doing another rinse cycle until water tank empties. I had to do that a couple of times, then the red exclamation mark came on. Then I turned knob to off position, refilled water tank, pressed the descale button for 6 seconds, green light came back on and it did its priming.
Posted on Apr 20, 2011
I have a Panasonic HDTV 1080p and it won't turn
You have a 5 year old projection TV with power supply trouble
Jul 13, 2013 | Televison & Video
Fujitsu plasmavision won't turn on
How many times do the red light blinks at a time? Count it. It is fault indication. After counting it, click here for details.
Dec 24, 2012 | Televison & Video
Sharp model lc-20sh1u won't turn on, just makes a clicking sound and indicator light flashes red.
The clicking sound may be a power relay coming on and then off--problem indicates a trouble in the main power supply.
Nov 02, 2012 | Sharp LC-20SH3U 20 in. EDTV-Ready LCD...
Tv won't turn on. Blinking in standby in red. Won't start
This is an indication of protection error and might require attention of a qualified service technician.
Aug 17, 2012 | Sony BRAVIA KDL-V32XBR1 32 in. LCD HDTV
TV won't turn on
Before going OFF, the standby LED might blink. These blinks are fault indication. The number of blink should be counted. Count the number of blinks at one time, before the TV goes OFF. [eg: 4 blinks Power SOS P Board; 6 blinks Driver SOS 1 SU / SD / SC Boards
(SC energy recovery circuit)] and so on. you can get more details from this site named 'Electro-help'. You can reach it by searching the keyword "electronicshelponline" by internet.
Jul 03, 2012 | Panasonic TC-P50X1 50 in. Plasma HDTV
My bpanasonic 48 won't turn on the light blinks
I may if you know what the model number is which is not indicated here.
Jun 14, 2012 | Televison & Video
Kdfe55a20 won't turn on at all It's a Sony
which LED lights on front are on and or blinking?
If the red or others blink look to see if they are blinking a specific number of times--like red one blinking 3 times, pause and repeating--this is a error code and may indicate what problem in set is.
Apr 24, 2012 | Sony Televison & Video
Heard a pop , bulb blew out , replaced bulb , it worked for two days , now red light blinks three times pauses then three times and so on , tv won't turn off light won't turn off unless I unplug...
3 blinks indicates lamp door is not on or has not been reinstalled properly. This also could mean the lamp door switch has failed itself. Try removing the lamp door and putting back on, if that doesnt correct the problem then I recommend having the switch replaced.
Oct 26, 2011 | Sony KDF-E42A10 42 in. LCD Television
Won't even turn on. Was flashing cup size lights on left & right and I turned it off and later tried to turn it on and it won't turn on.
The problem is often that the machine develops a leak in the hose that is rightover the transformer...the water drips onto the transformer and kills that...then you have no power to run the machine.
Here is a tip that I wrote about this problem...
Keurig OneCup Coffee Brewer will not turn on
heatman101
Sep 13, 2011 | Keurig B100 Coffee Maker
We ran the clean cycle on the coffee maker and the clean cycle will not turn off.
First, let me clarify what the red light indicates. A solid red light indicates the cleaning cycle is in progress. A blinking red light indicates the coffeemaker is off, but is due to be cleaned.
The red light will continue to blink while the coffeemaker is off until the cleaning cycle has been completed fully. The process takes about an hour and a half and is not intuitive. So, here are my instructions.
With the coffeemaker off (with the red light blinking), pour four cups of pure white vinegar (no water added) into the reservoir. Don't short the amount. You'll need four cups to complete the cycle. Remove any filters, but leave the strainer basket in place. Tap the "select" button three times until the red light is on (and stays on, not blinking). The cleaning cycle now begins. It should take between 45 minutes and an hour to complete. Don't be concerned about the 30-minute long pause during the cycle when nothing happens. This is intentional and part of the cycle.
After the cleaning cycle has completed, get rid of the vinegar. Rinse out the strainer basket and the coffee pot. Run a full pot of clean water thru a regular brew cycle (with the pot and basket in place, of course). Then, dump the water, rinse the pot and basket again, and run another full pot of clean water thru a regular brew cycle. Dump that water too. And, you're done!
May 15, 2011 | Mr. Coffee JWX27 12-Cup Coffee Maker
Coffee Makers & Espresso Machines Logo
1,358 people viewed this question
Top Coffee Makers & Espresso Machines Experts
Kolbrun...
Are you a Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
