Question about HP LaserJet 9500n Printer
WHAT DOES THE SENSOR LOOK LIKE? - HP LaserJet 9500n Printer
    Champion:
  • HP Expert
  • 312 Answers
A sensor is usually a small black plastic module open in the middle and allows a plastic flag to enter and leave which breaks a circuit when entering and leaving. Most generally they do not go bad.
Posted on Jan 31, 2015
Tip
Aprilia Fault Codes
Component Fault Code Possible Cause
Camshaft position sensor 11 Sensor not connected.Sensor broken.
Wiring faulty.
Crankshaft position sensor
Intake pressure sensor
Intake pressure sensor 14 Excessive pressure difference between two pressure sensors
Throttle position sensor 15 Sensor not connected.Sensor broken.
Wiring faulty.
Coolant temperature sensor
Air temperature sensor
Atmospheric pressure sensor (inside ECU) 23 Sensor faulty
Ignition coil 1, Front cylinder 33 Ignition coil faulty or wiring not connected
Ignition coil 2, Front cylinder
Ignition coils 1 and 2, Front cylinder
Ignition coil 1, Rear cylinder
Ignition coil 2, Rear cylinder
Ignition coils 1 and 2, Rear cylinder
Fall Sensor (tip-over sensor) 41 Sensor not connected.Sensor broken.
Wiring faulty.
Source Aprilia Fault Codes
on Dec 20, 2016 | Motorcycles
Im getting code P2253 on my 04 Saturn vue with 3.5l V6. Anyway to tell which O2 sensor it is? Thxs Bill
P0804 is the highest OBD-II trouble code.
Here's your Oxygen sensor codes.
P0130 02 Sensor Circuit Malfunction (Bank I Sensor 1)
P0131 02 Sensor Circuit Low Voltage (Bank I Sensor I)
P0132 02 Sensor Circuit High Voltage (Bank I Sensor 1)
P0133 02 Sensor Circuit Slow Response (Bank 1 Sensor 1)
P0134 02 Sensor Circuit No Activity Detected (Bank I Sensor 1)
P0135 02 Sensor Heater Circuit Malfunction (Bank 1 Sensor 1)
P0136 02 Sensor Circuit Malfunction (Bank I Sensor 2)
P0137 02 Sensor Circuit Low Voltage (Bank I Sensor 2)
P0138 02 Sensor Circuit High Voltage (Bank I Sensor 2)
P0139 02 Sensor Circuit Slow Response (Bank 1 Sensor 2)
P0140 02 Sensor Circuit No Activity Detected (Bank 1 Sensor 2)
P0141 02 Sensor Heater Circuit Malfunction (Bank 1 Sensor 2)
P0142 02 Sensor Circuit Malfunction (Bank I Sensor 3)
P0143 02 Sensor Circuit Low Voltage (Bank I Sensor 3)
P0144 02 Sensor Circuit High Voltage (Bank I Sensor 3)
P0145 02 Sensor Circuit Slow Response (Bank 1 Sensor 3)
P0146 02 Sensor Circuit No Activity Detected (Bank I Sensor 3)
P0147 02 Sensor Heater Circuit Malfunction (Bank I Sensor 3)
P0150 02 Sensor Circuit Malfunction (Bank 2 Sensor I)
P0151 02 Sensor Circuit Low Voltage (Bank 2 Sensor I)
P0152 02 Sensor Circuit High Voltage (Bank 2 Sensor 1)
P0153 02 Sensor Circuit Slow Response (Bank 2 Sensor 1)
P0154 02 Sensor Circuit No Activity Detected (Bank 2 Sensor 1)
P0155 02 Sensor Heater Circuit Malfunction (Bank 2 Sensor 1)
P0156 02 Sensor Circuit Malfunction (Bank 2 Sensor 2)
P0157 02 Sensor Circuit Low Voltage (Bank 2 Sensor 2)
P0158 02 Sensor Circuit High Voltage (Bank 2 Sensor 2)
P0159 02 Sensor Circuit Slow Response (Bank 2 Sensor 2)
P0160 02 Sensor Circuit No Activity Detected (Bank 2 Sensor 2)
P0161 02 Sensor Heater Circuit Malfunction (Bank 2 Sensor 2)
P0162 02 Sensor Circuit Malfunction (Bank 2 Sensor 3)
P0163 02 Sensor Circuit Low Voltage (Bank 2 Sensor 3)
P0164 02 Sensor Circuit High Voltage (Bank 2 Sensor 3)
P0165 02 Sensor Circuit Slow Response (Bank 2 Sensor 3)
P0166 02 Sensor Circuit No Activity Detected (Bank 2 Sensor 3)
P0167 02 Sensor Heater Circuit Malfunction (Bank 2 Sensor 3)
Note: "Bank 1" is the side of the engine with cylinder 1. "Bank 2" is the other side.
Jul 03, 2011 | 2004 Saturn VUE
I need a honda car code , i can't turn on my radio
service manual.
Code Description Possible Cause
0 ECU / ECU signal No signal to ECU
1 Oxygen sensor circuit Oxygen sensor or circuit, ECU
2 Oxygen sensor circuit Oxygen sensor or circuit, ECU
3 MAP sensor circuit Map sensor circuit
4 CKP sensor / engine speed (RPM) Crank angle sensor or circuit, ECU
sensor
5 MAP sensor circuit MAP sensor or circuit, mechanical
problem
6 ECT sensor circuit ECT sensor or circuit, automatic
transaxle control unit
7 TPS / Angle Sensor TPS sensor or circuit, automatic
8 CKP sensor / engine speed (RPM) Crank angle sensor or circuit, ECU
sensor
9 CMP sensor CMP sensor or circuit
10 IAT sensor IAT sensor or circuit
11 Idle Mixture Adjuster Sensor Idle mixture adjuster sensor or
circuit
12 EGR system fault No EGR action, faulty EGR valve
13 BARO sensor circuit BARO sensor or circuit
14 Idle Air Control valve circuit / ECU Open or shorted out ignition signal
circuit / No signal to ECU
15 Ignition Output signal Open or shorted ignition output
signal circuit
16 Fuel Injector Circuit Open or shorted fuel injector
circuit
17 VSS circuit VSS sensor or circuit
18 Ignition Timing Adjuster Open or shorted signal circuit
19 A/T Lock-up control solenoid Open or shorted signal circuit,
Lock-up control solenoid lock-up solenoid
20 Electrical Load Detector / Sensor Electrical load detector or circuit
Honda/Acura
Fault Code Definitions (21 - 59)
Chapter 3 22
21 Spool Solenoid Valve Open or shorted signal circuit,
spool solenoid valve
22 Valve Timing Electronic Oil Open or shorted signal circuit,
pressure switch valve timing oil pressure switch
23 Knock sensor circuit Knock sensor or circuit
30 AT / ECU communication signal A AT control unit, ECU
31 AT / ECU communication signal B AT control unit, ECU
35 Traction control / ECU / signal Traction control module, ECU
36 Traction control / ECU / signal Traction control module, ECU
41 Oxygen sensor heater - left side Oxygen sensor / heater or circuit
42 Oxygen sensor heater - right side Oxygen sensor / heater or circuit
43 Fuel Supply system - left side Oxygen sensor or circuit, fuel
system
44 Fuel Supply system - right side Oxygen sensor or circuit, fuel
system
45 Fuel metering - left side Injector control circuit, incorrect
fuel metering
46 Fuel metering - right side Injector control circuit, incorrect
fuel metering
48 Heated oxygen sensor Oxygen sensor or circuit
53 Right Knock Sensor Right knock sensor or circuit
54 CKP sensor 2 CKP sensor 2 or circuit
59 CMP sensor 2 CMP sensor 2 or circuit
Dec 28, 2010 | 1994 Honda Accord
05 dodge cummins,driving down roadway ,throttle will climb erratically for about 3-4 seconds when coming to a stop, it has electrical throttle connections ,no cables that i can see. When parked idling and...
To retrieve OBDII Error codes from your Chrysler/Jeep/Dodge vehicle, do the following sequence with the key: ON-ACC-ON-ACC-ON and look at the odometer, that is where codes will be displayed. Here are the codes that you may/can get.
Ho2S = heated oxyen sensor, TP = throttle position, MAF = mass airflow, MAP = manifold absolute pressure, TC=turbocharger.
P0030 HO2S Heater Control Circuit Bank 1 Sensor 1
P0031 HO2S Heater Circuit Low Voltage Bank 1 Sensor 1
P0032 HO2S Heater Circuit High Voltage Bank 1 Sensor 1
P0036 HO2S Heater Control Circuit Bank 1 Sensor 2
P0037 HO2S Heater Circuit Low Voltage Bank 1 Sensor 2
P0038 HO2S Heater Circuit High Voltage Bank 1 Sensor 2
P0050 HO2S Heater Circuit Bank 2 Sensor 1
P0051 HO2S Heater Circuit Low Voltage Bank 2 Sensor 1
P0052 HO2S Heater Circuit High Voltage Bank 2 Sensor 1
P0056 HO2S Heater Circuit Bank 2 Sensor 2
P0057 HO2S Heater Circuit Low Voltage Bank 2 Sensor 2
P0058 HO2S Heater Circuit High Voltage Bank 2 Sensor 2
P0100 MAF Sensor Ckt. Insufficient Activity
P0101 Mass Air Flow (MAF) Sensor Performance
P0102 Mass Air Flow (MAF) Sensor Circuit Low Frequency
P0103 Mass Air Flow (MAF) Sensor Circuit High Frequency
P0104 Mass Air Flow Circuit Intermittent
P0105 MAP Sensor Circuit Insufficient Activity
P0106 Manifold Absolute Pressure (MAP) System Performance
P0107 Manifold Absolute Pressure (MAP) Sensor Circuit Low Voltage
P0108 Manifold Absolute Pressure (MAP) Sensor Circuit High Voltage
P0109 Manifold Absolute Pressure Circuit Intermittent
P0110 Intake Air Temperature (IAT) Sensor Circuit
P0111 Intake Air Temperature (IAT) Sensor Performance
P0112 Intake Air Temperature (IAT) Sensor Circuit Low Voltage
P0113 Intake Air Temperature (IAT) Sensor Circuit High Voltage
P0114 Intake Air Temperature Circuit Intermittent
P0115 Engine Coolant Temperature (ECT) Sensor Circuit
P0116 Engine Coolant Temperature (ECT) Sensor Performance
P0117 Engine Coolant Temperature (ECT) Sensor Circuit Low Voltage
P0118 Engine Coolant Temperature (ECT) Sensor Circuit High Voltage
P0119 Engine Coolant Temperature Circuit Intermittent
P0120 Throttle Position System Performance
P0121 Throttle Position Sensor Circuit Insufficient Activity
P0122 Throttle Position (TP) Sensor Circuit Low Voltage
P0123 Throttle Position (TP) Sensor Circuit High Voltage
P0124 Throttle Position Sensor 1 Circuit Intermittent
P0125 Engine Coolant Temperature (ECT) Insufficient for Closed Loop Fuel Control
P0126 Insufficient Engine Coolant Temperature for Stable Operation
P0128 Coolant Thermostat
P0130 HO2S Circuit Closed Loop (CL) Performance Bank 1 Sensor 1
P0131 HO2S Circuit Low Voltage Bank 1 Sensor 1
P0132 HO2S Circuit High Voltage Bank 1 Sensor 1
P0133 HO2S Slow Response Bank 1 Sensor 1
P0134 HO2S Circuit Insufficient Activity Bank 1 Sensor 1
P0135 HO2S Heater Performance Bank 1 Sensor 1
P0136 HO2S Circuit Bank 1 Sensor 2
P0137 HO2S Circuit Low Voltage Bank 1 Sensor 2
P0138 HO2S Circuit High Voltage Bank 1 Sensor 2
P0139 HO2S Slow Response Bank 1 Sensor 2
P0140 HO2S Circuit Insufficient Activity Bank 1 Sensor 2
P0141 HO2S Heater Performance Bank 1 Sensor 2
P0142 HO2S Circuit Bank 1 Sensor 3
P0143 HO2S Circuit Low Voltage Bank 1 Sensor 3
P0144 HO2S Circuit High Voltage Bank 1 Sensor 3
P0145 HO2S Circuit Bank 1 Sensor 2 Slow Response
P0146 HO2S Circuit Insufficient Activity Bank 1 Sensor 3
P0147 HO2S Heater Performance Bank 1 Sensor 3
P0150 HO2S Circuit Closed Loop (CL) Performance Bank 2 Sensor 1
P0150 HO2S Circuit Bank 2 Sensor 1
P0151 HO2S Circuit Low Voltage Bank 2 Sensor 1
P0152 HO2S Circuit High Voltage Bank 2 Sensor 1
P0153 HO2S Slow Response Bank 2 Sensor 1
P0154 HO2S Circuit Insufficient Activity Bank 2 Sensor 1
P0155 HO2S Heater Performance Bank 2 Sensor 1
P0156 HO2S Circuit Bank 2 Sensor 2
P0157 HO2S Circuit Low Voltage Bank 2 Sensor 2
P0158 HO2S Circuit High Voltage Bank 2 Sensor 2
P0159 HO2S Slow Response Bank 2 Sensor 2
P0160 HO2S Circuit Insufficient Activity Bank 2 Sensor 2
P0161 HO2S Heater Performance Bank 2 Sensor 2
P0162 HO2S Circuit Bank 2 Sensor 3
P0163 HO2S Circuit Bank 2 Sensor 3 Low Voltage
P0164 HO2S Circuit Bank 2 Sensor 3 High Voltage
P
Dec 18, 2010 | 2005 Dodge Ram 2500 Truck
Hur byter jag växellädsolja på
160....O2 Sensor Circuit No Activity Detected (Bank 2 Sensor 2)
P0161....O2 Sensor Heater Circuit (Bank 2 Sensor 2)
P0162....O2 Sensor Circuit Malfunction (Bank 2 Sensor 3)
P0163....O2 Sensor Circuit Low Voltage (Bank 2 Sensor 3)
P0164....O2 Sensor Circuit High Voltage (Bank 2 Sensor 3)
P0165....O2 Sensor Circuit Slow Response (Bank 2 Sensor 3)
P0166....O2 Sensor Circuit No Activity Detected (Bank 2 Sensor 3)
P0167....O2 Sensor Heater Circuit (Bank 2 Sensor 3)
P0168....Fuel Temperature Too High
P0169....Incorrect Fuel Composition
P0170....Fuel Trim (Bank 1)
P0171....System too Lean (Bank 1)
P0172....System too Rich (Bank 1)
P0173....Fuel Trim Malfunction (Bank 2)
P0174....System too Lean (Bank 2)
P0175....System too Rich (Bank 2)
P0176....Fuel Composition Sensor Circuit
P0177....Fuel Composition Sensor Circuit Range/Performance
P0178....Fuel Composition Sensor Circuit Low Input
P0179....Fuel Composition Sensor Circuit High Input
P0180....Fuel Temperature Sensor A Circuit
P0181....Fuel Temperature Sensor A Circuit Range/Performance
P0182....Fuel Temperature Sensor A Circuit Low Input
P0183....Fuel Temperature Sensor A Circuit High Input
P0184....Fuel Temperature Sensor A Circuit Intermittent
P0185....Fuel Temperature Sensor B Circuit
P0186....Fuel Temperature Sensor B Circuit Range/Performance
P0187....Fuel Temperature Sensor B Circuit Low Input
P0188....Fuel Temperature Sensor B Circuit High Input
P0189....Fuel Temperature Sensor B Circuit Intermittent
P0190....Fuel Rail Pressure Sensor Circuit
P0191....Fuel Rail Pressure Sensor Circuit Range/Performance
P0192....Fuel Rail Pressure Sensor Circuit Low In put
P0193....Fuel Rail Pressure Sensor Circuit High Input
P0194....Fuel Rail Pressure Sensor Circuit Intermittent
P0195....Engine Oil Temperature Sensor
P0196....Engine Oil Temperature Sensor Range/Performance
Nov 20, 2010 | 2004 Volvo S80
2006 hundai elantra P2270 code. If this is an O2 sensor, which one?
Possible O2 sensors:
P2270 O2 Sensor Signal Stuck Lean Bank 1 Sensor 2
P2271 O2 Sensor Signal Stuck Rich Bank 1 Sensor 2
P2272 O2 Sensor Signal Stuck Lean Bank 2 Sensor 2
P2273 O2 Sensor Signal Stuck Rich Bank 2 Sensor 2
P2274 O2 Sensor Signal Stuck Lean Bank 1 Sensor 3
P2275 O2 Sensor Signal Stuck Rich Bank 1 Sensor 3
P2276 O2 Sensor Signal Stuck Lean Bank 2 Sensor 3
P2277 O2 Sensor Signal Stuck Rich Bank 2 Sensor 3
P2278 O2 Sensor Signals Swapped Bank 1 Sensor 3 / Bank 2 Sensor 3
This is Bank 1 (closer to the dash panel) Sensor 2 (located after the catalytic converter).
Note: A malfunctioning front oxygen sensor may cause fuel trim codes to set.
  1. Several Diagnostic Trouble Codes use specific terminology to refer to sensor location. The illustration and key below explain the following terms:
  2. Engine BANK Bank 1 is closer to the dash panel, (also referred to as RH or right hand). Bank 2 is closer to the radiator, (also referred to as LH or left hand).
  3. UP Refers to Sensor 1 or "front sensor". It is located closer to the exhaust manifold and before the catalytic converter.
  4. DOWN Refers to Sensor 2 or "rear sensor." It is located after the catalytic converter.
  5. The following examples show how to interpret oxygen sensor terminology:
  6. B1/S1 = Bank 1/Sensor 1 = Dash panel side, BEFORE the catalyst or "upstream"
  7. B2/S2 = Bank 2/Sensor 2 = Radiator side, AFTER the catalyst or "downstream"
Aug 06, 2010 | Hyundai Elantra Cars & Trucks
I need a diagram of the exhaust system on a Mazda 626
0996b43f80203328.jpg enlarge_icon.gifenlarge_tooltip.gif Fig. Component Location Chart-2000 MPV
1 PCM 2 Mass air flow (MAF)/intake air temperature (IAT) sensor 3 Throttle position (TP) sensor 4 Fuel tank pressure sensor 5 Engine coolant temperature (ECT) sensor 6 Crankshaft position (CKP) sensor 7 Camshaft position (CMP) sensor 8 Knock sensor 9 Heated oxygen sensor (HO2S) (front, LH) 10 Heated oxygen sensor (HO2S) (front, RH) 11 Heated oxygen sensor (HO2S) (rear, LH) 12 Heated oxygen sensor (HO2S) (rear, RH) 13 EGR boost sensor 14 Power steering pressure (PSP) switch 15 Main relay
0996b43f8020330c.jpg enlarge_icon.gifenlarge_tooltip.gif Fig. Component Location Chart-2001 MPV
1 PCM 2 Mass air flow (MAF)/Intake air temperature (IAT) sensor 3 Throttle position (TP) sensor 4 Engine coolant temperature (ECT) sensor 5 Crankshaft position (CKP) sensor 6 Camshaft position (CMP) sensor 7 Knock sensor 8 Heated oxygen sensor (HO2S) (front, LH) 9 Heated oxygen sensor (HO2S) (front, RH) 10 Heated oxygen sensor (HO2S) (rear, LH)* 11 Heated oxygen sensor (HO2S) (rear, RH)* 12 EGR boost sensor
0996b43f8020330f.jpg enlarge_icon.gifenlarge_tooltip.gif Fig. Component Location Chart- 2002-06 MPV
May 22, 2010 | 2004 Mazda MPV
I need help looking for all the sensors on a d16 honda civic
What sensor are you try to look for?
here is the list of all the sensors for 97 honda civic EX
1.Countershaft Speed sensor
Driven Pulley speed sensor
Engine Coolant Temperature Sensor
Front wheel sensor
Fuel Tank Pressure Sensor
Intake Air Temperature Sensor
Knock Sensor
Mainshaft speed sensor
Manifold Absolute pressure (Map) sensor
Primary Heated Oxygen sensor
Rear Wheel sensor
Secondary Gear shaft speed sensor
Throttle Position sensor
Vehicle speed sensor.
I hope this can help you, please put something on the ratting. good luck.
Mar 18, 2010 | 1997 Honda Civic
My check engine light has come on in my 2006 Pontiac G6 after 2 and a half years. What could possibly be wrong since I keep my car serviced and the guys had just told me that my car was in tip top shape?
P0016 - Crankshaft Position Camshaft Position Correlation Bank 1 Sensor A
P0030 - Heated Oxygen Sensor (H02S) Heater Control Circuit Bank 1 Sensor 1
P0031 - Heated Oxygen Sensor (HO2S) Heater Circuit Low Voltage Bank 1 Sensor 1
P0032 - Heated Oxygen Sensor (HO2S) Heater Circuit High Voltage Bank 1 Sensor 1
P0036 - Heated Oxygen Sensor (HO2S) Heater Control Circuit Bank 1 Sensor 2
P0037 - Heated Oxygen Sensor (HO2S) Heater Circuit Low Voltage Bank 1 Sensor 2
P0038 - Heated Oxygen Sensor (HO2S) Heater Circuit High Voltage Bank 1 Sensor 2
P0050 - Heated Oxygen Sensor (HO2S) Heater Circuit Bank 2 Sensor 1
P0051 - Heated Oxygen Sensor (HO2S) Heater Circuit Low Voltage Bank 2 Sensor 1
P0052 - Heated Oxygen Sensor (HO2S) Heater Circuit High Voltage Bank 2 Sensor 1
P0053 - HO2S Heater Resistance Bank 1 Sensor 1 (PCM)
P0054 - HO2S Heater Resistance Bank 1 Sensor 2 (PCM)
P0056 - Heated Oxygen Sensor (HO2S) Heater Circuit Bank 2 Sensor 2
P0057 - Heated Oxygen Sensor (HO2S) Heater Circuit Low Voltage Bank 2 Sensor 2
P0058 - Heated Oxygen Sensor (HO2S) Heater Circuit High Voltage Bank 2 Sensor 2
P0068 - Throttle Body Airflow Performance (PCM)
P0100 - MAF Sensor Circuit Insufficient Activity
Jun 25, 2009 | 2006 Pontiac G6
HP LaserJet 9500n Printer Logo
48 people viewed this question
Seeker5211
Seeker5211
