Question about Body Solid G4I Iso-Flex Home Gym
Avanti home gym set
I have either the 2006 and 2007 model avanti home gym set. 200lbs stack with the leg press attached to the side. i have lost the instructions and was wondering wher i could find them? preferably on the net. thanks
Hg 2000
Contact Avanti directly to request assembly instructions
Oct 28, 2014 | Avanti Fitness HG2000 HomeGym
Need Instruction Manual for Marsy Cross Trainer?
It's my guess that this model is not made any more.
Try contacting the manufacturers. Instructions for for contacting the manufacturers can be be found through this site
http://marcyfitness.co.uk/?q=Products/Elliptical
7.June.2014
Jun 06, 2014 | MARCY 100 lb Stack Home Gym
I need stell cables for my ms3200
please give me a back side photo of multi sports ms 3200 homegym
Oct 02, 2011 | Multisports MS3200 MS3200 Three Station...
I have a california gold universal home gym with leg press. I need the assembly instructions. I don't know how to hook up the cables. with out cables the machine is useless. thanks
I have manuals for both the main device and the leg press and photos of my complete set if you are referring to the California Gold home gym. My copy of the owners manual is a .pdf file and is pretty large. Get back to me and I will attempt to email them to you.
Mar 02, 2011 | Icon Gs 2500 Gold Gym
Need instructions to assemble my Marcy MWM 982
The instruction manual is available on the website of Mercy, it is not exactly the same model but instruction are similar, just click the link below to download the pdf
http://www.impex-fitness.com/images/mwm981%20manual.pdf
Feb 21, 2011 | MARCY 100 lb Stack Home Gym
Looking for a web site to replace the cable on the Total Gym Weider 2980X stack home gym
Try this..
Customer Service for Retail and QVC Models
For help with all Total Gym retail and QVC models (models other than Total Gym 2000, 3000, XL, XLS and Electra) please contact Customer Service at 1-800-321-9236. // Web Trends Definitions var gDomain="statse.webtrendslive.com"; var gDcsId="dcsupufpe10000s9urugpmzne_2k1h"; var gFpc="WT_FPC"; var gConvert=true; if ((typeof(gConvert)!="undefined")&&gConvert&&(document.cookie.indexOf(gFpc+"=")==-1)&&(document.cookie.indexOf("WTLOPTOUT=")==-1)){ document.write(""); }
// onTarget tag var s_PageName= "fitquestcs.php"; // Quantcast tag _qoptions={qacct:"p-86P2XjTjOrkgc"}; // load JS files at window.onload Event.observe(window, 'load', function() { // onTarget tag // EAC.JS.load('/ontarget.js'); // Quantcast tag EAC.JS.load('http://edge.quantserve.com/quant.js','javascript_tracking'); // Keyword Max tag //EAC.JS.load('http://keywordmax.com/tracking/show.php?id=468164933&blockengines=WS&loc=Homepage'); // Begin SearchForce tracking code for landing page (4.0) EAC.JS.load('http://sftrack.searchforce.net/SFConversionTracking/CTCommon.js','head',{onload:function(){ SFCookie.include(); window.jcexpire = "30"; window.jURLData = "" + window.location.search.substring(1); if((jURLData && jURLData != null && jURLData != "null" && jURLData.length > 0) && jURLData.indexOf("jsid=") > -1) ImageJSLandingProcess(); }}); // Touch Commerce Chat tag EAC.JS.load('https://totalgym.inq.com/chatskins/launch/inqChatLaunch319.js','head',{charset:'utf-8'}); }); if (!navigator.cookieEnabled) document.getElementById('cookieEnabledCheck').style.display = 'block';
Jan 22, 2011 | Total Gym Weider 2980x 214 Lb Stack Home...
I am looking for replacement cables for my MS 3200 Home Gym. I need the back cable that goes to the leg raise/ shoulder butterfly area and has two lower pulleys on the lower part of the back side of the...
The only source for replacement parts I have been able to locate is Multisports themselves. They are located in Houston Tx. Here is a like to their contact info. Ask for parts ordering and they should be able to identify the part # you need and help you with your order.
Have a great day.
Jan 04, 2011 | Multisports MS3200 MS3200 Three Station...
Hiya, trying to put our weider power stack multi gym 200lbs bench thing together, we have no idea where the cable goes please help.
Hi there. You can go here and enter the model number (located under the seat) In the model number box and download a manual for free.
http://www.iconservice.com/CustomerService/manuals.do
Good Luck, Tim
Aug 16, 2010 | Exercise & Fitness
I need to move my body solid G4I to another room,
first disassemble the chest press then tie wrap the cable to frame. pull the weight stack off then tie wrap weight stack cable then remove rear base all away to where the front seat is attached now you should be maneuver to the other room
May 13, 2010 | Body Solid G4I Iso-Flex Home Gym
Body Solid G4I Iso-Flex Home Gym Logo
613 people viewed this question
Top Body Solid Exercise & Fitness Experts
John
Tom Chichester
Techmotionusa.com
Techmotionusa.com
Are you a Body Solid Exercise and Fitnes Expert? Answer questions, earn points and help others
