Question about GE WJSR2070B Top Load Washer
My ge washer will not spin or agitate
The belt is like new,
    President:
  • GE Master
  • 1,922 Answers
Check the continuity of the magnetic switch under the top cover and the plug connection to the switch,they get bad and dont make connection then it cant agitate or spin
Posted on Apr 28, 2013
SOURCE: ge washer does not agitate; fills and spins okay
Can't do anything about the one that's smoking. As with most electrical stuff, once you let the smoke out it no longer works.
Mine had the same original problem. Would fill, but would not agitate. It just sat there with a tub full of water and clothes.
I scoured the internet, and came to the conclusion that it was either:
The timer (unlikely, according to most posts I read), or
The motor. The motor in these is a reversing motor - one direction for spin, the other for agitate.
If half the motor quits working, you'd get spin but no agitate or vice-versa.
I took the motor out to take it and have it bench-tested to be sure before I spend the money on a non-returnable new motor. Unfortunately, no one here can (or will) bench-test the motor.
In the meantime, my wife called the retailer where we bought the machine and asked if they could test the motor. They said there was no need - that the control board in the machine probably just needed to be reset.
So far, I have taken off the front panel, taken off the control panel, removed the top of the machine, removed the ring on the top of the tub. Removed the agitator. Removed the four bungee-cord things that keep the machine from rolling over or something. Removed the bell thingy under the agitator. Removed the big nut under that to be able to remove the tub. Removed a plate on the top of the machine so that there is room to remove the tub. Removed the tub. Removed the big tub by lifting it to disconnect the shock absorbers, and disconnecting the drain hose and the air tube that controls the fill level. Tilted out and removed the big tub with the motor frame attached to the bottom. Removed the pulley, belt and motor frame. And removed the motor from the frame. All just to get the motor out to take it to the shop. Who would not test it.
But I digress.
The procedure to reset the control board is this:
1) Unplug the washer.
2) Wait 30 seconds or more. (This allows all capacitors to discharge and make the "computer" forget everything.)
3) Plug the machine in.
4) Open and close the lid 10 times. (The magnets in the lid are the only method you have to "talk" to the "computer.")
5) Run the machine.
It sounded stupid. It sounded like a Monty Python skit, but I did this. I reassembled the machine, and did the reset procedure. The machine worked just fine. Filled, agitated, drained, rinsed, did the spin cycle. Just like a wash machine should.
Makes me wonder about $300 repair bills.
Posted on Mar 11, 2009
  • 7 Answers
SOURCE: GE agitator does work
The agitator is fastened to the agitator shaft and its movement is driven either by splines or a simple clutch assembly. The splines are usually plastic or rubber nubs on a cylinder that fits over the agitator shaft. If the nubs wear down, the shaft will not turn properly or it will turn weakly. If the agitator is moving in only one direction, the likely cause is the clutch assembly. The clutch has dogs that depress and pop up with each turn. If those dogs are worn, they will not engage properly and the agitator will turn only in one direction.
Various makes and models differ in how the agitator is removed. In some newer models, the agitator just lifts straight up and out. However, in most models you will have to do some combination of the following steps. First remove the fabric softener dispenser, if any. It should either lift or screw off. Next remove the cap. It may lift off, screw off or failing that, it may need to be pried off.
Posted on Dec 22, 2007
  • 61 Answers
SOURCE: GE washer won't agitate or spin
un plug the machine , wait 30 sec. plug back in , open and close the lid completly 5 times with in 30 sec. if the problem is just needing to be reset this will do it if not you need to replace the motor
Posted on Jan 21, 2009
mgprice
  • 744 Answers
SOURCE: GE washer GNSR2140A0WW wont spin/agitate but fills and drains
Hello, your problem is going to be with the lids switch, in this machine it is going to be a magnetic contact. You can confirm this my pulling the front panel off and accessing the wireing to the lids switch, If you have electrical knowledge bypass the lid switch using a wire nut and run the machine. If all is ok make sure you relpace the lid switch since it is there for a reason. If you have any other questions or concerns please feel free to comment again. Good Luck!!!
Posted on Jul 19, 2009
SOURCE: drum won't agitate or spin what do we do?
have the belt checked :)
Posted on Nov 26, 2009
Ras7233kq0 washer won't spin Washer agitates and
Check the belt on the drive system to the motor.if the motor is working the belt might be broken. If the belt is intact it could be a relay to engage the belt drive.
Oct 16, 2013 | GE WCVH6260FWW
GE washer WPRE6100G0WT not agitating or spinning
Depends on how old the machine is. It might me a transmission problem
Jul 25, 2012 | GE Profile WPRE6100G Top Load Washer
My ge wpsf4170 top load washer agitator spins but the drum itself stays stationary.
If the drum spins but the agitator doesn't agitate then its the dog(lil arm things) that grab the agitator ridges to work. If the drum doesn't spin at all its the belt under the drum. it's either broke the belt or has worn and slipped off or the drum was way off balance and kicked it off(belt) . way cheaper to fix either than buy new and most new ones have no agitator anymore so how does it clean better? In my opinion, they don't so I get the parts online at repair clinic and do it my self. Sorry Maytag Repair man. But I saved a lot
Sep 05, 2017 | GE Washing Machines
I have a GE washer model # WHDRR418GWW. It is about 19 months old. It stopped agitating and spinning. It will fill with water and the timer/knob will go thru the cycles. But when it reaches the washing...
You have what is called "agitating dogs" there are usually 4 of them at the bottom of the agitator. They have small grippers which lock onto the agitator and agitates. If the washer is ever overfilled or over time filled to heavy this will wear down the nylon teeth on the "dogs". The top of the agitator will spin off, you will see a bolt inside at the bottom, remove bolt and the agitator will pull out. Google "agitating dogs on washer. It will give you pictures for a better understanding. If the belt was broken the washer would not drain, because the belt turns the pump. These dogs are about $5 and honestly easy to install. Good Luck.
Dec 04, 2010 | GE WHDRR418GWW 35 cu. ft. Washer
Ge frontload washer seems like it is not aggitating... what would be the problem???
Hello there:
The first thing to check when your GE washer is not agitating, is the belt. Let me tell you how to check the belt & the clutch with out having to take the washer apart.
The belt: Set the timer in the spin cycle and pull the timer knob to turn the washer on.
If the washer drains the water and then spins the way that it should, this tells you that the motor, belt & clutch are not the reason why your washer won't agitate.
A broken belt could be the reason your washer is not agitating or spinning.
The agitator: After making sure that the belt, motor & clutch are working ok, lets check the agitator.
The agitator uses a plastic agitator coupler that is couple to the transmission shaft by using splines cut in the coupler and on the transmission shaft.
Too much usage or overloading the washer too many times will wear the agitator coupler splines. With out the splines the coupler could not be coupled to the transmission shaft and that could be the cause why your washer is not agitating.
The clutch: A bad clutch could also be the reason the washer won't agitate or spin. Usually when the clutch is bad the washer will be noisy, like when you have bad brakes on your car.
The transmission: The transmission could be the reason your washer is not agitating. A common problem with the transmission is oil leaking right on top of the motor pulley and the belt.
As you can see, there could be different reasons why your GE washer is not agitating. You just need to keep checking each part until you find the problem and replace the part responsible.
Oct 03, 2010 | GE WSXH208A Front Load Washer
My hotpoint has quit spinning, how do I evaluate and repair
If it will not agitate or spin, you will need to replace the belt. If it will agitate but not spin, you have a bad transmission. This has been a nightmare to Hot Point (GE). I did warranty repairs for GE for 8 years. During that time, GE had me condemn on average 6 washers a week due to bad transmissions. Reason being, it was cheaper for them to send the customer a new washer than it was for them to ship me a new transmission and pay me to replace it.
Sorry but take my advise when I say, when you replace your washer, don't but a GE or Hot point. They still have not bothered to fix their transmissions.
Oct 16, 2009 | Hotpoint VBSR3100D Top Load Washer
No spin - agitate
You just do this
  • Test the lid switch
  • Inspect the motor coupler
  • Inspect the drover belt (belt drive only)
  • Inspect under the washer for soot (clutch)
  • Test the motor
  • Inspect the pulley
  • Test the transmission
  • Inspect the Agitator
  • Inspect the pump coupling
  • Test the Water switch level
Good luck !!!
Regards
PCmania
Jul 08, 2009 | GE Washing Machines
Agitator will not spin.
Try these
  1. Test the lid switch
  2. Inspect the motor coupler
  3. Inspect the drive belt (belt drive only)
  4. Inspect under the washer for soot (clutch)
  5. Test the motor
  6. Inspect the pulley
  7. Test the transmission
  8. Inspect the agitator
  9. Inspect the pump coupling
  10. Test the water level switch
pls rate my suggestion.....
Jun 20, 2009 | GE Washing Machines
GE Washer Model WJSR2080V3WW Agitates, Pumps, but will not Spin
I solved the mystery of the non spinning washing machine by GE. I pulled the agitator off and to my horror was a broken " hub". This the part in the middle of the basket under the agitator. The transmission shaft comes up through the center of it. Any way, it was severely broken and wedged in so it would not spin. Not sure if this is the only problem but I am going to buy a new machine. I can not get it unbolted to replace the hub and don't want to **** around with it. THANKS.
Jan 25, 2009 | GE Washing Machines
GE WJSR2070B Top Load Washer Logo
148 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
