Question about Miraphone Music
The thumb ring on my Miraphone 191 tuba broke off. Any fix from Miraphone?
Learning to playbluegrassmusic on my guitar,and learning how to sing bass......
Most of the bluegrass is in your thumb, you play the bass strings with your thumb, and leave the rest of the job for the rest of your finger. Johnny Cash and Mark Knopfler are the two dudes who opened my eyes to bluegrass rythms. Also Johnny Can help you a lot on those bass tones try singing daily as deep as you can but don't stretch it out, just as much as you feel comfortable everyday and after a while you'll get the Barry White kinda bass sounds. And for the bluegrass thing just check the internet out there are tons of high quality in depth reviews of the thumb picking style, and try playing to a four bar backing drum track and follow it up with your thumb. And that's the rule of the thumb.
Common Bluegrass Flatpicking Licks Guitar Lesson Tutorial
Jun 13, 2017 | Music
I broke my input usb on my hardware traktor s4. where i can buy a new one to fix my s4?
That happened to me as well. NI was pretty good about a return and fix, didn't even ask me about the warranty.
Sep 29, 2012 | Native Instruments Traktor Kontrol S4
Need a sound/presets for the Korg Tr rack
http://www.korg.com/SupportResults.aspx?productid=191
Feb 07, 2012 | Korg Music
How hard is it to repair a sticking key on the keyboard. I have a new Yamaha MM6 and it's going to cost me all kinds of shipping charges to exchange it. Was wondering if it would be worth it to just...
It kinda depends on if a hammer is broke or key is broke. Or if a foreign object is stuck in there. Typically not hard if you can remove screws and remember how they go back in. TypicAlly the bottom panel comes off keyboards ( start by removing those screws ) or the top case will fold up ( still bottom of keyboard screws ) then multiple screws to realease keyboard assembly. May have to disconnect some wires/ ribbon cables so have a sharpie ready to label to ensure correct reassembly. Then it's all about if they have separate keys or a keytree or sometimes just removing ba key and reseating fixes sticking problems. Get yourself a can of blow off or contact cleaner just in case. Not sure who locally to you sell parts but you can always call manufacturer and ask who does their distribution for parts.
Aug 26, 2011 | Yamaha MM6 Mini Mo Keyboard Pro
BR-1180 freezing & high-pitch ring
Check your power supply to the unit. Low voltage COULD cause this.
Also make sure a setting is not "looping" the audio back into itself.
May 23, 2010 | Boss Micro BR Digital Recorder
En los amplificadores Line 6 Spider III ¿puedo conectar pedales de efectos que no sean de la misma marca línea 6?
translation: In the amplifier Line 6 Spider 3, is it possible to connect effect pedals of other makes apart from Line 6.
Creo si, pero primo del amplificador con una corda guitarra.
I think that you can, just add them to the input
Jan 23, 2010 | Line 6 Spider Iii 30
I broke the master volume switch off. How I do I
I have a soloution that will work as long as you still have the metal shaft on it?
if it does go to your local electrical store and buy a new knob.
then all you have to do is screwthe knob back on to the amp.
please reply and tell me if that helps.
Aug 01, 2009 | Line 6 Spider Iii 30
Wanting to know the age of my tuba
As a musician I'm not entirely sure. Best to contact worldwide services at www.yamaha.com and email customer services.
Mar 30, 2009 | Yamaha Music
Input wires broken loose, not sure where the go to
The center pin is your tip..which should have a wire going from 1/4" jack to the XLR jack. Pin 1 is earth ground...should be coming from 1/4" jack sleeve. Pin 3 would come from the 1/4" jack ring.
http://upload.wikimedia.org/wikipedia/commons/thumb/8/81/XLR_pinouts.svg/540px-XLR_pinouts.svg.png
If you are still having trouble, post links to pictures of the internals of the guitar showing the assembly.
Mar 27, 2009 | Music
Location of serial number on Yamaha tuba (Eb 321S)
I have an Eb 632 and its on the back of the second valve casing. Good luck.
Dec 10, 2008 | Yamaha Music
Music Logo
Top Miraphone Music Experts
Vito Vacirca Jr.
Are you a Miraphone Music Expert? Answer questions, earn points and help others
