Question about GE WJSR2070B Top Load Washer
My GE washer model number is WJSR2070B2WW will not agitate or spin
The belt is new
SOURCE: ge washer does not agitate; fills and spins okay
Can't do anything about the one that's smoking. As with most electrical stuff, once you let the smoke out it no longer works.
Mine had the same original problem. Would fill, but would not agitate. It just sat there with a tub full of water and clothes.
I scoured the internet, and came to the conclusion that it was either:
The timer (unlikely, according to most posts I read), or
The motor. The motor in these is a reversing motor - one direction for spin, the other for agitate.
If half the motor quits working, you'd get spin but no agitate or vice-versa.
I took the motor out to take it and have it bench-tested to be sure before I spend the money on a non-returnable new motor. Unfortunately, no one here can (or will) bench-test the motor.
In the meantime, my wife called the retailer where we bought the machine and asked if they could test the motor. They said there was no need - that the control board in the machine probably just needed to be reset.
So far, I have taken off the front panel, taken off the control panel, removed the top of the machine, removed the ring on the top of the tub. Removed the agitator. Removed the four bungee-cord things that keep the machine from rolling over or something. Removed the bell thingy under the agitator. Removed the big nut under that to be able to remove the tub. Removed a plate on the top of the machine so that there is room to remove the tub. Removed the tub. Removed the big tub by lifting it to disconnect the shock absorbers, and disconnecting the drain hose and the air tube that controls the fill level. Tilted out and removed the big tub with the motor frame attached to the bottom. Removed the pulley, belt and motor frame. And removed the motor from the frame. All just to get the motor out to take it to the shop. Who would not test it.
But I digress.
The procedure to reset the control board is this:
1) Unplug the washer.
2) Wait 30 seconds or more. (This allows all capacitors to discharge and make the "computer" forget everything.)
3) Plug the machine in.
4) Open and close the lid 10 times. (The magnets in the lid are the only method you have to "talk" to the "computer.")
5) Run the machine.
It sounded stupid. It sounded like a Monty Python skit, but I did this. I reassembled the machine, and did the reset procedure. The machine worked just fine. Filled, agitated, drained, rinsed, did the spin cycle. Just like a wash machine should.
Makes me wonder about $300 repair bills.
Posted on Mar 11, 2009
buffalonyman
  • 1865 Answers
SOURCE: GE washer doesn't spin or agitate has new timer
Bad motor?
Posted on Apr 15, 2009
jumptrout51
  • 3361 Answers
SOURCE: Will not agitate or spin
Check 1. the water level switch, 2. the timer, 3. the lid switch.
Posted on May 15, 2009
SOURCE: will not go in to spin cycle
Remove agitator (it will pop off when pried) then you will find your answer. Mine was a broken tub collar to shaft.
Posted on Aug 18, 2009
SOURCE: WJSR2070B2WW AGITATOR REMOVAL
got help on another site for free that told how to remove agitator which allwed me to see the metal part that connects inner drum to transmission had completely broken into two seperate parts. will replace.
anks
bobth
Posted on Dec 06, 2009
Ge frontload washer seems like it is not aggitating... what would be the problem???
Hello there:
The first thing to check when your GE washer is not agitating, is the belt. Let me tell you how to check the belt & the clutch with out having to take the washer apart.
The belt: Set the timer in the spin cycle and pull the timer knob to turn the washer on.
If the washer drains the water and then spins the way that it should, this tells you that the motor, belt & clutch are not the reason why your washer won't agitate.
A broken belt could be the reason your washer is not agitating or spinning.
The agitator: After making sure that the belt, motor & clutch are working ok, lets check the agitator.
The agitator uses a plastic agitator coupler that is couple to the transmission shaft by using splines cut in the coupler and on the transmission shaft.
Too much usage or overloading the washer too many times will wear the agitator coupler splines. With out the splines the coupler could not be coupled to the transmission shaft and that could be the cause why your washer is not agitating.
The clutch: A bad clutch could also be the reason the washer won't agitate or spin. Usually when the clutch is bad the washer will be noisy, like when you have bad brakes on your car.
The transmission: The transmission could be the reason your washer is not agitating. A common problem with the transmission is oil leaking right on top of the motor pulley and the belt.
As you can see, there could be different reasons why your GE washer is not agitating. You just need to keep checking each part until you find the problem and replace the part responsible.
Oct 03, 2010 | GE WSXH208A Front Load Washer
WJSR2070B2WW AGITATOR REMOVAL NOISY IN SPIN . AGITATOR SPINS BUT TUB DOESN'T.
anks
bobth
Dec 06, 2009 | GE Washing Machines
Ge washer top load wlse4000goww not washing/spinning only pumps
Your type of washer usually has a belt theat runs the agitator and spins the tub. The pump is hooked by a direct coupling. If you are still pumping that tells me the motor works but the belt is probably broken or worn so badly that it no longer drives.
Have the belt replaced or do a search for "appliance parts" and then enter your model number. You will get a parts menu to order a new belt from for your unit.
Belt replacement for some of these units can be a major chore... then again some are relatively easy, but consider yourself warned if it is a real project....
I hope that this will help you to solve your problem!
Thanks for using Fixya!!
Heatman101
Dec 05, 2009 | GE WDSR2080D Top Load Washer
GE Washer does not drain or spin
Inspect the drain hose for kinks
Test the timer control
Test the lid switch (some models)
Inspect the water pump
Inspect the drive belt (belt drive only)
Inspect the motor coupler
Jul 15, 2009 | GE WDSR2080D Top Load Washer
My washer agitates but will not spin
Check the lid switch, in some cases if the lid switch is broken it will agitate, but will not spin.You may need to replace the belt, if belt is in good condition and tight, you may need to check the timer. When you find the faulty part that needs to be replaced call First Source Parts and use the model number to order the part you need.
Jul 05, 2009 | GE WJSR2070B Top Load Washer
Will not go in to spin cycle
May 09, 2009 | GE WBSR3140DW Top Load Washer
GE Washer Knocking During Spin Cycle
remove the agitator and inspect the main shaft on the gear box.and check the belt underneath.if the shaft is bend you will need a new gearbox. hope this helps.
Feb 09, 2009 | GE Spacemaker Washer and Dryer Electric...
GE WJSR2070B Top Load Washer Logo
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
