Question about Denon Rcdn7 Ceol Ipod Cd Receiver In White With Integrated - rcd-n7
Connection fail 03 denon ceol
When trying to use the internet radio function, it tells me that there is a server error. I connect wirelessly to my homenetwork with succes, but it still happens. Then I try to Update the firmware, but it tells me that there is a connection fail 03. What to do?
5 Suggested Answers
SOURCE: denon ipod dock 'no connection' problem
Double check the 'dock control' connection. On the dock and receiver to ensure it's plugged in nice and tight.
Posted on Mar 07, 2010
Testimonial: "Thanks, this was the case, we found out after ages of trying to solve the problem from a more technical angle it just needed to be pushed down firmly."
reyjoshua07
  • 1157 Answers
SOURCE: Cant update firmware. connection fail:03
Hi rune321,
I would like to clarify if what is the type and model name of your unit?
Thank you for using FixYa.
Posted on Jun 16, 2011
bigbird498
SOURCE: Unable to play pandora on Denon 1912
Check the Denon website. There is a notice for Pandora users. Pandora changed something and Denon products are blocked as of 11/30. They state that they are working on a fix and to check back after 12/6 for the update.
Posted on Dec 02, 2012
vk3uck
  • 166 Answers
SOURCE: Where can I find the latset firmware updates for a Denon DBP 1611UD Universal BluRay Player ?
Go into the menu and look for software/firmware upgrade
Posted on Jul 02, 2014
I am using a Denon internet radio on LAN (pirelli modem), works fine, but I cannot receive BBC. BBC on the PC works fine. Could that be a router problem? Any ports or adjustments I have to consider? If so,...
I have the same problems with my Pirelli modem in Austria (A1) trying to play BBC radio stations. I connected my Denon CEOL RCD-N7 to a different network (SilverServer in Austria) and it played the BBC radio stations swimmingly (not sure what modem was used btw)... I have another internet radio at home (Reciva based) and surprisingly, that one plays the BBC stations fine using the WMA streams.
I do have a workaround now for the Denon system: I have added the following URLs (AAC streams) to "My Added Stations" on RadioDenon.com and they work like a charm:
http://www.bbc.co.uk/radio/listen/live/r1_aaclca.pls
http://www.bbc.co.uk/radio/listen/live/r2_aaclca.pls
http://www.bbc.co.uk/radio/listen/live/r3_aaclca.pls
http://www.bbc.co.uk/radio/listen/live/r4_aaclca.pls
http://www.bbc.co.uk/radio/listen/live/r4x_aaclca.pls
Any suggestions as to what the issue might be with the Pirelli modem are welcome!
-- Hope this helps.
Jan 29, 2013 | Denon Audio Players & Recorders
Internet connection failed but IP address obtained.
Sounds like a problem with the firmware in your router. Connect
your laptop directly to one of the four ports with a cat 5 cable. Turn of your wireless adapter and connect through the cable.
Once your web browser is open, go to the URL http://192.168.1.1/. This will take you to a pop up box which asks you to enter a user name and password. The default user name is admin and the default password is admin or password. From there You will be all the settings you can control. You are looking for the one to go on line and download the current firmware update. This will most likely solve your problem. If your router was working fine before do not tamper with any of the other options. If this does not clear up your problem you will probably need a new router. You can also try Pushing the tiny reset button on the back and running the setup disk that came with your router. If this fails you definitely need a new router.
I hope this helps you. If you need more help feel free to contact me.
George
Jul 25, 2008 | Sony Playstation 3 (PS3) Console
Tip
WPS54G Printer Server Setup
I bought a Linksys Wireless-G WPS54G printer server and trie to put it in my home network. Following the instruction from the manufacturer and spent many hours, I still couldn't make the printer server work. There was no problem to get the IP address from my DHCP server using the wired connection. But when I pulled off the network cable and tried the wireless connection, I got "connection failed" error at the last step to install the printer server. I checked my router's client monitor and found the printer server did get the dynamic IP address wirelessly. When I pinged that IP address, there was no response at all from the printer server. In another word, the printer server couldn't communicate with other devices in wireless mode in the network. I searched the Internet and found there were many users had same problem and couldn't resolve the issue even from the manufacturer technical support. As a last resort before I was going to send back the printer server, I switched the network router to one of a different brand. My previous router was manufactured by BUFALLO INC and the new one was made by D-Link. After I rerun the installation following the instruction, the "connection failed" error was gone. The printer server could work finally.
The tip here is: Try a different brand router when there is a connection failure problem for installing the WPS54G printer server, if possible.
on Mar 02, 2008 | Linksys Wireless-G WPS54G Print Server
Bought a denon ceol n8 , now when I turn it on it says updating, then update failed
I had the same problem.
Confirm that the receiver is linked by wire (I think that's best than Wireless) and reset the microprocessor (page 49 of the manual: Unplug the power; than, plug the power while pressing Volume UP and DOWN on the main unit; when the power indicator lights white, release the buttons - "Initialized" appears on the screen). When Quick Set up appears, run it to connect to the Network. After the network is connected, upgrade the firmware (see page 14 of the manual for that).
That worked fine for me.
Dec 01, 2012 | Audio Players & Recorders
When I try to connect to the internet using a wireless connection, a screen comes up says "Communication with the server failed. A DNS error has occurred. (80410402)." How do I fix this problem?
if it is saying DNS error it is not a problem with the PSP, most likely a setting with your wireless router. or a problem with teh internet at the time of trying. check wireless settings on the PSP and make sure it has a number listed for DNS server.
Nov 24, 2009 | Sony PlayStation Portable (PSP) Console
sounds to me like you have the security turned on . Just type in your security key on PS3 and it should connect. Best of luck!
Jan 11, 2009 | Video Game Consoles & Games
TomTom One V3 - Problem connecting to TomTom Home
I have the same problem in NL.. TT Home has problems downloading over Wireless connections.
Try connecting the computer to the internet via a cable. You may have to restart TTHome or maybe even your PC. The download should be quicker and more reliable :)
The problem is related to the MTU size and working around that can be very technical.
Dec 27, 2008 | Tomtom ONE 3rd Edition GPS
Check to make sure that your router has gotten an IP Address from your ISP. Because you PS3 is telling you that it has an IP from your router. This means that the Router to PS3 connection has layer 3 connectivity, but what about from your router to your ISP? check that in the router by logging into the router's web page and going to the status page it should have your information from your ISP if it does not make sure that the main page is set to the proper settings either get IP automatically (Cable Modem) or Get PPPOE (DSL) connection (Make sure that your password information is correct to).
Now after checking these items make sure that you set the router up as the DNS for your network buy setting this on the status page then in your PS3 (set the DNS setting to point to your router, and set your router up as a caching DNS server).
Then power cycle the router after saving everything, and power cycle your PS3 after setting everything. This should clear up your problem.
Thank you,
Shuttle83
Oct 24, 2008 | Linksys Wireless-G Broadband Router
Ps3 error 80710723
This same problem happened to me awhile ago. The way I fixed it was I went under settings to network settings. Then went down to media server connection and disabled that. Once I did that I had no trouble at all updating games. Hope this helped :)
Oct 18, 2008 | Sony Playstation 3 (PS3) Console
Hi All,Trying to synchronize with sap getting server failed
From my personal experience with a program we support, when we get that kind of error the Palm is unable to initially connect to the internet.
You may need to check the settings that the applications uses to connect to the internet/program.
You may also need to check the Palms connection set up for internet/wireless.
Jan 04, 2008 | RIM BlackBerry Pearl 8100
Denon Rcdn7 Ceol Ipod Cd Receiver In White With Integrated - rcd-n7 Logo
Top Denon Audio Players & Recorders Experts
 Grubhead
Grubhead
Electro Med Services...
Are you a Denon Audio Player and Recorder Expert? Answer questions, earn points and help others
