Sharp aquos LC-70LE845U will not connect to wireless system. Finds SSID, but enter password and doesn't connect. Laptop, iPhones, iPad, and printer all set up without problems.
kakee
  • 1269 Answers
SOURCE: attempting connection of a hp photosmart 7200 printer
What is the brand of your wireless router? Just make sure the SSID (signal's name) is configured on the wireless setting of your printer. They should have the same SSID configured. If the correct SSID is already configured on the printer's wireless settings, try to change the channel on your wireless router. Use channel 11. You can also try to do a power cycle. Turn off your wireless router and printer for about 1 minute. Power on router first, wait for the lights to stop blinking, then power on your printer.
Posted on Oct 14, 2008
  • 59 Answers
SOURCE: My wireless name (SSID) and security settings keep changing on their own!
hi,
well i saw the problem u r facing
and the only soution for it is the upgradation of the firmware ....
i was facing the same one on my router and it got corrected ....
otherwise u can call the customer care no of the the routers company and they will give u the replacement
Posted on Oct 23, 2008
Yomitako
  • 70 Answers
SOURCE: WRT300N Router Issue
What I would recommend, would be to give the router a factory reset. To do so, you'll need a paper clip first. On the back of the router, you should see a pinhole-sized rubber nub of a button labeled reset. To reset, unplug the router from power, then press and hold that little reset button in, and plug the router back into power (you might have to do some nifty acrobatics for this one, or get a friend to give you a hand). Keep holding the reset button in for about 20 seconds, and let go. If I recall, you probably won't see any real indication on the router itself that it worked, however, you should be able to log back into the router manually, and set your connections back up again, in the event that the settings may have become corrupted somehow. If this doesn't work though, then there may be further problems, in which case, you may need to get onto Linksys' website, and download the most recent firmware for your model of router, and then try setting it up again. If that doesn't work, then the router may be experiencing some kind of hardware failure, in which case, if you are within the manufacturer's warranty, contact Linksys for repair or replacement (or through your place of purchase). If you are not within warranty, then buying a new replacement router may be your only other option. Hope this helps!!
Posted on May 22, 2009
  • 117 Answers
SOURCE: Can't connect wifi with my NetGear WNR3500 Router
which operating system, you are using
Posted on Mar 18, 2010
leitusdotcom
  • 172 Answers
SOURCE: create a password for wireless internet connection
Hi. Open your browser and go to http://192.168.1.1
the default username and password is admin / admin.
Once you are inside the router, you will see on the left the menu such as network map, operation mode, advanced settings. Under advanced settings you will see the Wireless configuration where you can change the SSID (name of the wireless network) to any name you want. Then on the security you can select either WEP or WPA, i would recommend WPA and you set the password (letters and numbers or just letters) and save the settings and that's it.
Try to do this on a computer directly connected to the router (via ethernet cable) because any change on the wireless will disconnect you.
I hope this helps. Please do not forget to write and provide positive feedback for our fast/free support today. :D
Posted on May 25, 2010
HOW do i use wps on my ipad with WNR2000
Depending on your browser, download or display the pdf of the WNR2000 manual ( http://documentation.netgear.com/wnr2000/enu/202-10397-01/pdfs/FullManual.pdf ). The manual might also be found on the CD that came with the router.Follow instructions Chapter 2 Page 7 to enable/setup WPA2-PSK (AES).Make sure you SAVE/APPLY the settings before proceeding. Follow instructions Chapter 2 Page 17 to Disable Router's PIN. When you do, make sure you leave the box checked to "Keep Existing Wireless Settings".Make sure you SAVE/APPLY the settings before proceeding.Here's a work-around ff the above doesn't fix the issue for you. Sorry I don't have iPad-specific instructions, but I don't have access to an iPad/iPhone at the moment. I've done the following on iPads, iPhones, Android phones and tablets, Windows phones and PC's - it works on virtually all Wi-Fi-capable devices..:
Instead of letting your iPad find the network and trying to connect with the password, try manually creating a new Wi-Fi network connection by typing in your Wi-Fi network name (SSID), selecting WPA2 (AES) encryption and entering the Wi-Fi password your configured in STEP 2 above.Please note: You'll have to forget the Wi-Fi network in your iPad's settings if you keep your Wi-Fi network name (SSID) the same as it is currently.
May 25, 2016 | NetGear WNR2000 Wireless Router
Iternet functions not working
Is the internet working on other devices? If not your internet is down.
Aug 31, 2014 | Sharp AQUOS LC-70LE845U 70" HDTV
How do you change the channel
I think first you need to setup wi-fi and enter the SSID code. setting wi-fi in iphone and ipad are all most same process..
Here is a blog to setup iphone and ipad with wi-fi
http://blog.vtechsquad.com/2013/02/28/how-to-connect-your-iphone-to-wi-fi/
Apr 08, 2013 | Belkin Play N600 Wireless Dual Band Router...
Iphone 4s will not accept password to d-link di-524
Some later model wireless routers have the Password(ie.Encryption key) and the SSID already configured in the wireless router andthis information is printed on a label on the bottom of the router.
These settings can be used to configure the wireless card and wireless adaptersin your computer/laptop.
If these settings do not suit you, then it can be changed to suit yourrequirements.
The encryption key secures your data and wireless connection from unauthorizedaccess.To configure the wireless settings in the router, connect a LAN cablefrom your computer to the wireless router, then open a Browser on your computerand enter the router's configuration IP address, then enter the admin login andpassword and then go to the wireless settings and configure the SSID andEncryption key.
The router's encryption key can be a Passphrase or the WEP or WPA or WPA2key.If you use the Passphrase method select either WEP or WPA or WPA2 togenerate the encryption key. You can enter the WEP or WPA or WPA2 key with 8 to63 ASCII characters or 64 Hex digits.
Most people use Passphrase which is easier to remember eg. I was born inJanuary 1988.
The strongest and latest security is WPA2, the weakest and oldest is WEP. To connect to your wireless router from the computer/laptop,configure the wireless card in your computer/laptop with the router's wirelesssettings ie SSID, plus the WPA or WPA2 encryption key. Then computer/laptopscan communicate with your wireless router.
Jul 15, 2012 | D-Link AirPlus DI-524 Wireless Router
Can't connect iphone to dlink router
When my ipod tries to connect to my computer wirelessly, it asks for the password. I enter it, but it won't accept password. It finds the router ok, just says password is incorrect. I've checked and it's the right one. Any suggestions?
Nov 27, 2011 | D-Link DIR-615 Wireless Router
Random wi-fi dropping
Go to the linksys website, see if they have a firmware flash for the router, that may help in some connectivity issues. You may also find that the ipad/iphone may drop connections when battery levels are low
Nov 02, 2011 | Linksys WRT54G2 Wireless Router
Wirelss router won't allow other devices to connect to it - eg kindle, iphone, but internet works fine on computer (which it's plugged into)...
Before you start :
The Following Steps Should be done on the computer that is connected to the router (Plugged with a cable)
Step 1 : Make sure you have internet access
Step 2 : Open Router Setup by typing http://192.168.2.1 in the address bar of Internet Explorer
Step 3 : Once you are at the router setup .. on the left side underneath Wireless you can find Wi-Fi Protected Setup
Click it
Step 4 : If it is asking for a password .. leave the password field blank and click submit
Step 5 : Disable Wi Fi Protected Setup and click apply changes
Step 6 : Now on the left under wireless click Security
Step 7 : If it is asking for a password .. leave the password field blank and click submit
Step 8 : Change the Security mode to WPA-PSK (you can also choose WPA-2 but sometimes it doesnt work )
Step 9 : Type a password (8 Characters , It is Case Sensitive)
Step 10: Click apply Changes
Step 11: On the left , Under Wireless Click Channel and SSiD
Step 12: Change the SSiD to a Different name , Change the Wireless Channel to 11
Step 13:Click Apply Changes
Turn On the Wireless Switch on the Computer (If you are using a Laptop to Connect between router)
Now try to Connect to this new network on both your wireless Computers and Ipad
Let Me Know if it Works
Aug 24, 2011 | Belkin (F5D5231-4) Router
G + MIMO Wireless Belkin Router - I cannot connect to the internet with my iPad. It will not accept the password to my network at home. How do I connect my iPad to my home network?
Did you configure the router, to select:
1. SSID, the "name" of your network;
2. encryption-level. Hint: use 'WPA' or 'WPA2'.
3. password to your network.
If so, then enter the SSID/password on the iPad, to connect to your network.
Jul 30, 2011 | Belkin Wireless G Plus MIMO (F5D9230-4)...
Wifi discovery problem. I have installed a Motorola SBG900i. All my wifi devices have had trouble discovering the SSID. When I do a scan available networks it does not exist. I forced 2 laptops to...
Assuming you haven't changed your modem's settings...
  1. Access the modem by typing http://192.168.100.1 in your browser.
  2. Enter the default username admin and password motorola
  3. On the left frame, click Wireless
  4. Click on the Security tab
  5. Under the tab, click Advanced
  6. Untick Disable ESSID Broadcast
May 13, 2011 | Arris SURFboard SBG900 Wireless Router...
Computers & Internet Logo
106 people viewed this question
David Payne
David Payne
