How to hange panasonic viera th-42pv8m on the wall
I have universal wall mount but could not find the tv holes in the back
jerryg50
  • 1667 Answers
SOURCE: wall mounting emerson lc320em9 television
I don't know the model in particular, but most of these sets can be wall mounted if you have the screw holes for the mounting plate in the back of the set.
What I believe the tech was telling you would be that it is best to not wall mount the set. The reason is that we found that we have been seeing a higher failure rate from sets being wall mounted. This is because the surface of the wall reflects some heat back in the set, and thus causes it to internaly run warmer. This is also the same from running a set inside of a cabinet. The complete surface area behind the set being very close to the wall surface blocks cooler air circulation. It is best to run these sets on a stand that is out in the opened at least 1 foot away from any wall surface.
Jerry G.
Posted on Jun 28, 2008
pgh_pa_guy
  • 2992 Answers
SOURCE: What is the screw hole size in back of tv
The screw holes are metric. The set is supplied with M5x25 screws to attach the pedestal, so the wall mount screws will be in that same range.
Posted on Mar 01, 2009
SOURCE: Looking for a wall mount that fits the ProScan 26LB30QD
http://store.videomountstore.com/ has a tool at the top of the page that gives custom mount recommendations based on the mounting holes for your specific TV. Just choose PROSCAN and 26LB30Q from the list and it will show you the mounts they have that will work for that TV.
Posted on Apr 20, 2009
SOURCE: Wall mounting Panasonic Viera 32" tv
There's a little more elaboration required on the above post...You need to remember that the base has two long pins that go up into the TV. These pins are held in by two screws each. The screws are on each side of the TV (two vertical inline screws, inside a small inset section). Remove all four screws and the TV will come up off the base. Pull it straight and gently, but firmly, to unseat it from the pins.
Posted on Dec 28, 2009
Select TRNX
  • 4 Answers
SOURCE: wall mounting the LG 42LC2D TV there are holes in
There will be 4 big holes used to install a mounting bracket on the back of the TV.
Posted on Jan 10, 2010
I have a panasonic viera plasma tv model number TC-P60U50, where on tv do I put brackets to mount to the wall?
You will need to purchase a suitable wall mount separately. (You'll need one for LARGE TVs.) On the back of your TV set you'll see there are 4 holes in the lower-central region of the rear panel. They are about 20" apart (left-right) and about 12" apart (up-down) These should match up with the bracket that comes with your wall mount. You will need M8 metric screws that are about 1.25" long. These will also be included with the wall mount. (Which will include some general directions for wall mounting.)
Here is a manual for your TV:
PANASONIC Viera TC P60U50 Owner Manual Page 7
Feb 09, 2016 | Panasonic Televison & Video
I have a Panasonic TH-42PZ80U 42" plasma tv I would now like to mount on a wall. I have gotten conflicting information as to whether it is VESA or not. Can you tell me anything about wall mounts for...
Just purchase a mount for 42" and above They come in different styles for your likening and make sure the wall bracket gets mounted into the wall studs and your all set. No major job. I get $150 all day long for those installs.
Nov 26, 2010 | Panasonic Viera TH-42PZ80U Plasma TV
I bought a used panasonic TH-50PZ85U plasma TV that was wall mounted. I need a pedestal base. Called Panasonic 3 days ago and the have to "research it". Can you help? km
My ex-husband threw away the pedestal stand for the Polaroid Polaroid FXM-3211C TV DVD Combo which I now have. I need a pedestal stand....do you know where I can find one?
Jul 14, 2010 | Panasonic Viera TH-50PZ85U Plasma TV
How do i wall mount this tv
theres 4 fixing mounts at back of tv covered by plastic caps just remove those to mount
May 20, 2010 | Panasonic Viera TH-42PX80U Plasma TV
How do I wall mount the 65" TV. There are no instructions in the manual provided with the TV
You can buy a universal wall mount the will fit on that 65" plasma that comes with all necesary hardware and instructions to mount the TV to the wall. Now that 65" tv is really heavy so it needs good anchors to support the weight of the display.
Jan 02, 2010 | Panasonic VIERA TH-65PV500 65 in. Plasma...
Mar 01, 2009 | Panasonic Viera TH-42PZ80U Plasma TV
No screws for the tv to mount to the bracket
You will 4 m5x18mm and 4 m5x25mm machine screws. That should do the trick..
Can't find inserts/holes needed to wall mount the television.
i went thru this with my tv.. you can pop off those caps, if there's no obvious way to remove them
then when you shop for a mounting system, get a bigger/ higher capacity mounting system with generic connector system.
Dont go for the cheapeast price.
Nov 30, 2008 | Televison & Video
Televison & Video Logo
26 people viewed this question
Top Televison & Video Experts
Electro Med Services...
