Question about Air Tools & Compressors
Need to know what order to and how the parts go to put my blue-point AT 123 impacg wrench
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 70 Answers
You can download a parts list which will show in which order the parts go in.
www.snapon.com and select parts catalog.
Posted on Apr 28, 2013
What size are the spoke nipples on 2007 Yamaha ttr90
Hi, Anonymous for this situation I would call my local dealer or reputable shop's service/parts department and inquire about any possible quick fix, answers, or parts inquiry. For more information about your issue and valuable "FREE" downloads that you will need please click on the blue links below. Good luck and have a wonderful day.
do need to use spoke wrench
Motion Pro Spoke Wrench
YAMAHA TT R90 Owner Service Manual
OEM parts for Yamaha
YAMAHA TT R90 Owner Manual
Aug 22, 2012 | 2007 Yamaha TTR 90 E
Release and change bit ?
Hello Joey, I am assuming your chuck is jammed .Use a pair of pipe wrenches and rags to pad the jaws.Place one wrench under the back part of the chuck on left side with drill pointed at you.Put the top wrench in same direction on the front of the chuck.This should look like this _ >o_.Now tap the top pipe wrench handle with a hammer so you don't hurt your hands.I were gloves while doing this.Please let me know if you have any questions.THANK YOU for picking FixYa.com....Darryel
Jul 17, 2011 | Black & Decker 18V Cordless Drill/Driver
I need to know how to put my serpentine belt back on?
So you have it off now . Did you replace the belt tenisioner at this point this would be a vary good idea its a ware part and sooner or later will need it . Look at the front of the tenisinor under the pulley there is a square slot you can put a 3/8s extention for a 3/8s scoket wrench in this slot and hook it to the 3/8s drive wrench and push the tenisioner to the middle of the engine its spring loaded then you will be able to put the belt over the pulley on the tenisiner and then relese the force from the scoket wrench . You just to do the belting routing correctly but there should be a decail that will show you this somewhere under the hood if not you can ask the dealer it olny fits one way and needs to be a tight fix
Feb 10, 2011 | 2004 Pontiac Grand Prix
Removal of fan clutch
go to your local major parts house and they will usually loan tools free of charge. What you are asking for is a clutch fan wrench set. It will come with directions and when you go to put the new one on, use blue(medium strength)locktite on the threads and simply give the fan and clutch a turn or 2 and start the engine. Make sure the clutch is on the shaft. Once you start the engine, the clutch will walk right on and secure down tighter than you could do with the wrenches. Let me know if you need anything else.
Aug 11, 2010 | 1998 GMC Sierra
Do I require the fuel tank sending unit wrench number 310-123 in order to remove/install the fuel pump sending unit on a 2002 F150. Can a brass (non-sparking) punch be used instead? If the wrench is a...
i fixed my windstar fuel pump problem.. fuse number 5 was blown.. replaced the fuse and all is better.. however i do hear an electrical spark when the fuel pump disengages .. (turning the key to the acc position)
Dec 29, 2009 | 2004 Ford F150
Two left side front wheel studs nuts broken.
They are replaceable.
You can knock the broken studs out with a point chisel (wear safety glasses). Take the pieces and nut to an auto parts store in order to get the same nut size (don't want to use two tire tools/wrenches).
Sep 25, 2009 | 1996 Nissan Quest
I need to order a part for my Air Nesco 3/8'' impact wrench, and can't find it anywhere
Try this web site the carry a lot of the parts and manuals for air tools, and let me know if this helped.
http://www.justtools.com.au/prod1770.htm
Sep 23, 2009 | Air Tools & Compressors
123 Service Fuser Error - Lexmark C762 Colour Printer
This error refers to a thermistor error with your machine (assuming that you meant 923 error and not 123 error). Chances are that you will have to replace your fuser. Part number is: 56P2851.
To replace open the right side door (the one with the blue handle) and the lower door below it. Your fuser is the one with the 2 blue clips. Pull clips down and remove fuser. Replace fuser and push clips into locked (upright) position and that is it.
Hope that helps.
Mar 19, 2009 | Lexmark C762 Laser Printer
I cant put my surpatian belt back on i would like to know how to release the tension on the fan belt on the 1994 buick lesabre custom in order to replace the alternator
Put an 18mm, or whatever size is correct, socket on 1/2" drive bar, or ratchet , and put it securely on nut in center of tensioner pulley. Standing in front of car, you need to pull it upward, with bar on right side, or from passenger side, pull toward you with bar pointing upward. If no socket, try a long wrench same size that will fit on nut good & snug, be sure in each case to pull as straight as possible to avoid wrench slipping off.
Feb 16, 2009 | 1994 Buick LeSabre
Plug wire order for a ford f150 4.2 engene
driver side from front 564 pass side 123 cylinders on truck run pass front to back 123 drivers side front to back 456.the first part of this paragraph is the coil pack wiring
Jan 30, 2009 | 1999 Ford F150 Regular Cab
Air Tools & Compressors Logo
57 people viewed this question
Top Air Tools & Compressors Experts
John Trevino
Joe Garcia
Joe Garcia
Are you an Air Tool and Compressor Expert? Answer questions, earn points and help others
