Question about Car Audio & Video
No problem just questions
What is the best amp for my 2013 Ford f-150 FX2 super crew with Sony audio if I am adding 2 P3S-1X10 PUNCH SHALLOW loaded subwoofers. I would like to know what the best amp would be for just the subs and also the best amp with the subs and speakers added.
sparky1500
  • 1066 Answers
SOURCE: JBL Sub Amp Wiring Please
it seems rather redundant to bridge a mono amp. Unless the instruction manual states otherwise, i would assume that one speaker output is identical to the other (ran in parallel, like an A or B speaker, not like Left or Right), and you would present the amp with a two ohm load by wiring one speaker to each output. Bridging it may or may not work, but, again, it just seems redundant.
Posted on Mar 01, 2008
  • 4 Answers
SOURCE: How much would installing a headunit, amp, and subs usually cost?
hows it going so you need it to be installed or you can install this yourself? well the best bet fund to get stuff done cheap is t get the stuf you will need to do an install like a install wiring kit and tools and post a installer help on craigslist.org iin your local area would be the cheapest way or just go to your local audio stereo shop thanks again and i hoope this help have any more questions please feel free to contact me if you need a step by step install i can help you in that and save you big bucks thanks again. always forward jcbproducts
Posted on Dec 03, 2008
SOURCE: subwoofer/speakers are hooked up to my amp but making bad noise
it sounds like you have some wires crossed or a bad ground
Hope this helps
Posted on Jan 26, 2009
  • 56 Answers
SOURCE: can a 1000 watt amp run 800 rms subs and best wiring option
yeah it will run them but you won't get your full power because the rms for your subs is high. try bridging them with some 8 gauge wire, and of you got a crossover it will help you out alot
Posted on Feb 22, 2009
etirbynnor
  • 655 Answers
SOURCE: amplifier loads
Hello ronnieyannon,
A single 4 ohm speaker wired to each channel, like you have them wired, presents a 4 ohm load. And it appears that you have them connected properly. The 401s is only stable to 4 ohms when bridged, so if you were to parallel the 2 4 ohm subs in bridged mode, the load would be 2 ohms and the amp would most likely overheat and go into protection.
I'd wire them the way you have them wired.
Each channel of the amp outputs only 100 watts into 4 ohms. That is adequate for regular full-range speakers, component speakers, mid-range drivers, and even some small subs. But it is a little low on power for most subwoofer applications.
Hope this helps.
Posted on Apr 23, 2009
This is what my question says. some scientists estimate that there are 100 billion stars in the milky way galaxy.In standared form,100 billion is 100,000,000,000. write 100billion in exponential form.
1=10^0
10=10^1
100 (2 zeroes after the 1)=1x10^2
1000 (3 zeroes after the 1)=1x 0^3
1000 000 (one million) =1x10^6
1 billion =1 000 000 000 =1x10^9
100 billions =100x 1000 000 000=(1x10^2)x(1x10^9)=
1x(10^2)x(10^9)
Now use the power multiplication rule (a^n)x[a^m)=a^(m+n). Thus
1x(10^2)x(10^9)=1x10^(2+9)=1x10^(11)
100 billions =1x10^11=10^11.
Sep 10, 2013 | Computers & Internet
A ticking sound on a 06 ford f150 super crew 5.4L
Ticking sound could be coming from a Coil-on-Plug, or a pcv valve, or (hope it's not) a valve lifter which could be sticking. Sticking lifter noise often disappears when rpm's change, or the noise comes & goes. try changing the motor oil & filter right after adding an Engine-Flush Treatment to the motor oil, running the engine for 10 minutes at idle with treatment added to the oil, then draining the oil & changing filter while oil is still very hot. That last part is very important, so be careful not to burn your hands - be careful. -- The sticking lifter is a likely cause if motor oil has not been changed at frequent intervals in the past (every 3-4K miles) -- dirty oil causes sticking lifters.
Aug 10, 2012 | Ford Cars & Trucks
It was hooked up to a 2 or 1 ohm load now it dont work
if it was hooked to a 1 ohm load its most likely fried. what watt were you trying to push?
May 29, 2011 | Rockford Fosgate 25 To LIFE Punch 150...
No crank/no start
try adding some fuel additive for cold weather starting
Mar 11, 2010 | 2003 Ford F250 Super Duty Crew Cab
Where is the fuel filter located on a 08 ford f-150 super crew FX2?
Under your truck on the inner side of the frame rail on drivers side. All 5.4L, 4.6L, 4.2L all the same.
Dec 31, 2009 | 2008 Ford F 250 Super Duty 4WD
Auto dash remove
I would go to autozone.com, they have access to free online manuals. you will need to register and provide information about your vehicle, it is FREE! once that is done, you can access the manuals and get step by step instructions on how to remove the heater core. Good Luck!
Mar 20, 2009 | Metra Ford F 150 Truck 1999
Dec 03, 2008 | Rockford Fosgate 25 To LIFE Punch 150...
F-150 lights / Electrical problem...
If you are talking about hooking the truck to an engine diagnostics computer that will not likely diagnose the problem. The dealer wil have to troubleshoot the wiring and that can get expensive if the tech is not super proficient in that area.
Have you had ANY non factory modifications added such as alarms, remote starts, aftermarket lights, or trailer wiring connections? If so I would start there. you may email me with more details at bkbell@brianbell.net or visit www.brianbell.net. Please elaborate and I will do what I can to help you.
Jan 04, 2008 | Sony CDX-M800 CD Player
Car Audio & Video Logo
663 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
