Question about Fisher and Paykel 24 in. DD603H W Built-in Dishwasher
Dishwasher showing F5 with a spanner - Fisher and Paykel 24 in. DD603H W Built-in Dishwasher
  • Fisher and P... Master
  • 3,247 Answers
F5 code involves the drawer lid seal and will need a bit of effort to check and fix.
Take the drawer out and inspect the inside of the top panel for a rubber strip. If it is broken or not responding to up down movement then it needs to be replaced. In addition the actuator motors on each side that drive the seal could be faulty.
If you are not comfortable with repairing slightly complex apliances then you may have to call the technician.
Posted on Apr 18, 2013
Looking for answer to error code F5 on Whirlpool Dishwasher ADG 8200
Fault Code F5 or Five Flashes
Cause: Spray arms are blocked/clogged or otherwise malfunctioning.
Action: Spray arms are easily removed so take them out of the dishwasher and wash in the sink to clear out any gunk (using descaler should help shift any stubborn debris). Whilst doing this run the dishwasher on a short program without the spray arms to clear any further blockages.
Jul 14, 2016 | Whirlpool ADG8200 Dishwasher
My ifb dishwasher show F5 and could not complete it's cycle
If your IFB dishwasher is a Neptune DX model, Error code F5 according to the owners manual is "Inadequate water supply"
F5
Inadequate water supply • Make sure the water input tap is totally open and that there is no water cut.
• Close the water input tap, separate the water input hose from the tap and clean the filter at
the connection end of the hose.
• Restart your machine, contact the service if the error resumes.
Oct 01, 2015 | Dishwashers
Washer keeps blinking with a spanner and F1 function
F1 is a flood error. Below is a link to a video that you can download that shows you how to repair your dishwasher.
Solution
Good Luck
Feb 25, 2011 | Fisher and Paykel 23 in. DD-603SS Built-in...
F1 flashing with a spanner showing
Hi..
F1 code indicates a leak,you will find the water under bottom drawer.Might be the lid probably not sealing well. You have to seal it well properly to fix this error in your dishwasher.
Thank u !!
Jun 17, 2010 | Fisher and Paykel 24 in. DD-602 Built-in...
The unit flashes F1 with a spanner sign showing on both drawers
Refer your problem with fisher and paykel DD603 dishwasher. Please clarify how are you able to assess the motor is driving in top gear. Which lights are flashing?
Is this problem in both drawers or just one?
May 30, 2010 | Fisher and Paykel 23 in. DD-603SS Built-in...
My dishwasher is showing signs of a spanner
I am slightly unsure if your double drawer dishwasher is the prefinished model (self standing with LCD display) or the integrated model with no LCD display.
The spanner symbol on the top drawer is telling you that a fault code is actuated. But I am not sure where this symbol is on your unit if it is built -in (integrated model).
You will have to check which red light (from the left) is coming on.
I assume there are 5 lights on the inside of drawer.
With the bottom drawer - again you will have to check which light from the left comes on sometimes as you mentioned.
If you have a user manual you should be able to tell what Fault code it is - something like F1 or F2 etc. Is it continuously beeping when the red light is on? How do you turn the beeps off?
The scrubbing bush symbol on bottom drawer may not be a problem. It appears the drawer is programmed to a particular option. But I am not sure where this symbol is showing if you do not have an LCD display panel. You can reset the option - possibly auto lock or auto power or dish cleaned (depending on your model) if you follow the user manual.
happy to take you through a possible cause of the problem if you post answers to my questions above.
Jan 18, 2010 | Fisher and Paykel 23 in. DD-603SS Built-in...
HI my fiser and paykel dishwasher is flashing f1 and is showing a spanner whay does this mean
The F1 error means a flood switch has been activated in the drawer. The spanner means you need to call a technician.
The possible causes are that the solenoid that controls the water inlet does not shut off or the sensor that detects the water level is not working. Also it is possible the water pressure is not optimum for the setting on your unit.
Nov 05, 2009 | Fisher and Paykel 23 in. DD-603SS Built-in...
Hi My Fisher and Paykel Soft Touch dishwasher on a daily basis shows the error code F5 and beeps until I pull it out from the wall and turn it off and on again. How can I fix this?
there is no f5 fault in any of the soft touch f7p dishwashers, sure its not something else whats the model no , i fix f&p for a living
Oct 27, 2009 | Dishwashers
Hi again
Hi BBNJ try this 1. To select the Service Mode The service mode is selected when ?FUNCTION?, ?ORIGINAL SIZE? and ?3? keys are sequentially pressed, then F1 will appear in the display. 2.press number 5 to get f5 on the screen then press green start button 3.you should see `c00` on the screen key in 70 the screen should read c70 press green start again key in 0 and then green start button this should switch off the spanner 4 2. To exit the Service Mode The service mode is reset when the ?FUNCTION? and ?CLEAR? keys are pressed simultaneously kind regards Dr Bob1
Mar 29, 2007 | Panasonic Workio DP-150PA Copier
Fisher and Paykel 24 in. DD603H W Built-in Dishwasher Logo
142 people viewed this question
Top Fisher and Paykel Dishwashers Experts
Brian Coughlan
Are you a Fisher and Paykel Dishwasher Expert? Answer questions, earn points and help others
