Question about Fisher Price 2-in-1 Swing n Rocker - City Park CITY PARK
Creaking noise during swining
When I have it in swinging mode the plastic begins to creak loudly.
I have recently bought an Eldiss Affinity 482 caravan. When on road it makes creaking noises which are very loud. Has anyone else had this problem
I would need to hear this noise to ascertain what is causing it. As a guess I would think the rubber bushings in the suspension are in need of replacing. As far as this model it is not sold here in the USA that I know of.
Jun 22, 2017 | Cars & Trucks
How to stop seat from creaking.
well have you ever thought about loosing weight because if you sit in a chair and it creaks that means that the chair is just trying to hold you up.
Jul 17, 2015 | Other Ab-Doer Twist Abdominal Trainer
Creaking noise from front left when turning
check the wheel bearings and adjustment. check cv joints.
Mar 26, 2014 | 2006 Ford Mustang
Loud creaking noise(s) from front wheels when braking.
Well if the brakes are good (I'm not convinced) I would look at some of the bushings associated with the front end (control arm, sway bar .etc)
Oct 06, 2012 | 2003 Chrysler PT Cruiser
I have taken my 2003 GMC Envoy in to a GM dealer more than 6 times to be repaired for a very loud creaking noise in the front end. When I brake, the creaking noise starts. Or if I go over a bump, the...
My wife drives a 2003 GMC Envoy and has been complaining about this same creaking noise upon breaking or going over speed humps. I researched this topic on the internet high and low and tried everything I read to no avail. I was about to give up and then realized it could be the motor mounts since when you break or go over bumps the engine does have some movement. Sprayed the most interesting looking motor mounts I've ever seen with silicone spray and the noise was gone! My wife has been complaining for years about this noise and now looking back what a simple solution!. By the way my motor mounts where not worn out, the rubber portion of the mount just needed a little lube.
Dec 31, 2010 | 2003 GMC Envoy Xl
"Creaking noise from front right side of jeep"every time hit bump
If it is new take it back to the dealler for warranty repair. No new vehicle should have any noises . seriously, take it back for repair.
Jul 23, 2009 | 2008 Jeep Wrangler
Creaking noise when I step on the brake (Honda Element)
have the brakes looked at at your nearesr honda dealer or reputable repair shop. sounds like ur brake pad sensor is contacting ur rotor...
Apr 04, 2009 | 2008 Honda Element
A creaking noise when the freezer is opened & then closed
In some freezers they build up excessive vacuum which pulls the plastic housing away from the internal polyurethane insulation, hence the creaking sound. You can make a vacuum breaker by attaching a small stick or similar to the bottom of the door gasket, this will break the vacuum without losing temperature.
Mar 12, 2009 | Refrigerators
Loud creaking/shifting noise from fisher pycall frost free fridge.any ideas
This is likely ice dislodging during the defrost cycle.  You will probably notice that there are no fan other mechanical noises when you hear this.
Nov 11, 2008 | Refrigerators
Fisher Price 2-in-1 Swing n Rocker - City Park CITY PARK Logo
29 people viewed this question
Top Fisher Price Baby Gear Experts
romney2012
Lyle Siemens
Lyle Siemens
Josh Whitehead
Josh Whitehead
Are you a Fisher Price Baby Gear Expert? Answer questions, earn points and help others
