Question about Sta Rite Pool & Spa
Sta Rite Pool Pump
Ran my pump for 24 hrs. after cleaning the filter. Got up the next morning and the pump sounded as if it was running, but when I got closer realized that there was no water running through the system and the pressure gauge was at 0. Checked pool level, it is little more than half way up the tiles. Filter is clean. Ran hose through the system (the pump) and the water returns back into the pool, so don't seem to be a blockage. Turned the pump off several times and restarted it to see if the pump would start pumping the water through the system No Luck. No suction, no water flowing through the system, and the pressure gauge still reads 0. The pump sounds like before possibly just a little quieter. Please Help!
  • 5,245 Answers
Probably need new pump if the impeller broke.
If impeller broke, then motor will run, but no water circulates
Call pool company.
Motor resources:
http://waterheatertimer.org/Color-codewire.html#motor
Posted on Apr 19, 2013
  • 61 Answers
SOURCE: Pool pump will not fill back up
It sounds like you are sucking air into the pump. Make sure strainer baskets and pump baskets are clear, and the valves are in the right position. Also check the water level in the pool, and make sure that the pump is not sucking the skimmer dry. Next try lubricating the gasket on the pump lid, or if it is in bad shape (flattened/cracking) replace it. If this does not solve the problem put silicone around the inlet to the pump (silicone is a temporary fix that could last days or months--for best results replumb with teflon tape and sealant). If all that fails you could have debris stuck in the impeller.
Posted on Apr 05, 2009
  • 128 Answers
SOURCE: Hayward super pump II low pressure 10 psi suction and return low
You have a clogged impeller
Posted on Aug 23, 2009
Testimonial: "thanks for the response. That is exactly what it was. Got frustrated and just started taking things apart, but you are right on the money! tks again."
  • 128 Answers
SOURCE: Our Jaccuzzi Magnum Force pump extremely low pressure
Giving it a good cleaning probably clogged the pump impeller. If you vac'd the pool and the pump basket was packed with debrie it probably passed through and clogged. Split the pump and inspect the eye of the impeller. Low pressure means low flow.
Posted on Aug 30, 2009
  • 12650 Answers
SOURCE: My sand filter has great flow for awhile, and then
one of the internal pipes broke or rotted away put in bypass mode and unbolt top slide out unit head repair or replace damage pipe
Posted on May 06, 2010
smartr10U
  • 1305 Answers
SOURCE: Help low pressure in pool pump and filter
I can relate so well to your problem. My pool is surrounded by pines and deodora trees... all the needles seem to find their way through the baskets, strainers and into the inlet of the pump. It became a daily routine of having to reach into the inlet and clean the debris if I wanted a filtered pool.
Here' s a solution that will work!
Purchase an extra debris scoop ...the kind you put on the pole and scoop debris from the bottom of the pool.
Cut the net out of the frame and wrap the netting around the skimmer's debris basket and secure it with an oversized rubber band or zip ties, then replace the basket back in the skimmer.
Your skimmer will keep the debris out of the pump!
This will make a world of difference in your pump's pressure!
Give it a try and see if you're not working better!
Posted on Jun 03, 2010
Testimonial: "Thank you very much I will give it a try. I know this will stop the debris for sure. Again thanks"
How do i set up the hoses on the BHR170 pump?
front of pump goes to skimmers and main drain if inground pool skimmer if above ground top goes to inlet of filter then outlet of filter goes to pool returns
Jun 01, 2014 | Sta Rite Sta - Rite 24" Sand Filter & 1 Hp...
BHR170 hose set up
in form skimmers out to filter in to out of filter to returns
I have a Sta-Rite Max-E-Therm High Effiency - Propane Heater - 400,000 BTU and the pool pump and heater work fine untim the next morning. The pool pump comes on and the heater does not. The service light...
How old is the heater?
When was the last time it worked correctly?
Does the pool reach the set point? If not, how close does it get?How long will the heater run (hours)?
What model pump are you using?
May 29, 2014 | Sta Rite Sta-Rite Max-E-Therm High...
Installed new pump unit starts and runs for 15 minutes then trips breaker what should I check
When the pump nears the 15 minute mark, check the housing to determine whether it is running hot. Also listen for changes in pumping sounds as something may be causing restriction.
Nov 22, 2013 | Sta Rite Sta - Rite Dyna - Glas Pool Pump...
We accidently left our Sta-rite pool pump on when we went out of town for 4 days. It ran dry during this time. Now when we turn the pump on, water shoots out of the top under the handle and makes sounds...
sounds like the heat from the pump melted the seals in your multiport replace multiport and pump you should be ok you will need to replace some of the pvc pipes they expand when heated you wont be able to put fittings on them
Sep 07, 2013 | Sta Rite Sta - Rite Dyna - Glas Pool Pump...
Looking for manual on Sta Rite Sand filter Model HRP830
Here is a copy of the users manual for Sta Rite BRPB30 pool filters.
http://www.pool-filters.com/pdf/Sta-Rite-HRPB-Filter-Manual.pdf
Apr 16, 2011 | Sta Rite Sta - Rite 31" Sand Filter & 1.5...
Sta-Rite Dyna Glas Pool Pump
debris may have gotten into pump or pump is air bound need to check pump first try to bleed pump if water comes out and not pumping hard possible burnt up impeller or seal
Apr 03, 2010 | Sta Rite Sta - Rite Dyna - Glas Pool Pump...
Sta-rite problem
Pump is heating up and kicking the breaker try cleaning the pump filter and let me know by posting to this solution.
Sep 29, 2009 | Sta Rite Sta - Rite 1hp Dura - Glas...
Pool & Spa Logo
103 people viewed this question
Top Sta Rite Pool & Spa Experts
Jay Finke
Jay Finke
john h
Jim Goldsmith
Jim Goldsmith
Are you a Sta Rite Pool and Spa Expert? Answer questions, earn points and help others
