Question about Car Audio & Video
Install 05 Dodge magnum headlights - Car Audio & Video
    Problem Solver:
  • 9 Answers
Open hood undo lights just a simple twist and pull will do then undo mounting screws for headlights then pull light out then put the new light in position put lights and plugs in first then reinstall mounting screws
Posted on Apr 19, 2013
Find the headlight relay on a 2005 dodge magnum
The headlights are operated by the front control module, part of the integrated power module
Dec 09, 2012 | 2005 Dodge Magnum
How do you replace the headlight bulb on a 2005 Dodge magnum ?
1) pop hood
2) Look at the back of headlight assembly, if you cannot get to the bulb wiring you are going to have to remove assembly
3) remove assembley and disconnect headlight wiring
4)turn bulb retainer counterclockwise and remove bad bulb and install new
5)if you can reach the bulb wiring without taking out headlight assembly all the better you dont have to do step 4
Mar 09, 2011 | Dodge Magnum Cars & Trucks
What problems does a crank sensor do on a 05 dodge magnum
The crank sensor on mine went out at around 80,000 miles and caused the car to stall upon stopping. Replacement of the sensor appears to have fixed the problem over the last 5,000 miles.
Sep 04, 2010 | 2006 Dodge Magnum
Change headlight bulb 2007 dodge magnum
Disconnect the negative battery cable. Turn the nut on the cable clamp counterclockwise to loosen it and then slide the clamp off the negative terminal.
  • Step 2 Open the hood and remove the electrical connector from the back of the headlight housing ballast.
  • Step 3 Turn the headlight counterclockwise and pull the headlight out of the housing. You may have to angle the bulb up at a 45 degree angle to clear the frame and headlight housing
  • Feb 18, 2010 | 2007 Dodge Magnum SRT8 Wagon
    I have a 05 dodge magnum v6 3.5 where is the fan relay located
    located in the PDC (power distribution center) under the hood
    Jul 07, 2009 | 2005 Dodge Magnum
    05 Dodege Magnum blinkers and wipers not working
    Both of these work from the turn signal switch. Replace the switch.
    Jun 29, 2009 | 2005 Dodge Magnum
    05 Dodge Magnum new long block
    Might be a bad mass air flow sensor. Need a little more info. I am a crysler master tech so give a bit more info,plz
    Jun 20, 2009 | 2005 Dodge Magnum
    Firing order for an 05 dodge magnum 2.7 liter
    i do know #3 cyclinder in middle on pass. side
    May 04, 2009 | 2006 Dodge Magnum
    How do i install driver side fog lights
    I bought the factory kit from Ebay. It came with clear instructions including the new headlight switch assembly that includes the fog light switch. I think it was under $150. Once installed, you have to see the dealer so they can program the computer to run the new lights.
    Dec 26, 2008 | 2007 Dodge Magnum SRT8 Wagon
    Car Audio & Video Logo
    Top Car Audio & Video Experts
    xxxxxx xxx
    Are you a Car Audio and Video Expert? Answer questions, earn points and help others
