FixYa.com
Tags:
Nikon BUCKMASTERS 3-9X40 RIFLESCOPE MATTE
Best way to mount Nikon 3-9x40 UCC?
By M0nica L - usenet poster
I have a Nikon Monarch USS 3-9x40 rifle scope.  What hardware should I
use to mount this on a .30 '06 Winchester Model 70 Classic
Featherweight? Is anything specifically the "best" or preferred way,
without starting any arguments?
The scope is really nice, but the barrel is only 134 mm from bell to
bell, so I'm a bit stumped.  It wouldn't fit on my Savage Model 110,
which is why I'm trading up to the M70.
TIA any suggestions.
Dave
REC.GUNS supports Marylanders for the Preservation of Firearms Ownership!
Your donation could win a premier  FULTON ARMORY RIFLE SYSTEM   while you
defend our Second Amendment Rights. Click on www.direct-action.org today!
Learn about rec.guns at              http://www.recguns.com
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Solution #1
posted on Aug 04, 2005
Not Rated (0)
man1
man1 - usenet poster
Rank:Apprentice Apprentice
Rating: 0%, 0 votes
Dave Oshel  <dcos @mac.com> wrote:
#I have a Nikon Monarch USS 3-9x40 rifle scope.  What hardware should I
#use to mount this on a .30 '06 Winchester Model 70 Classic
#Featherweight? Is anything specifically the "best" or preferred way,
#without starting any arguments?
I'm putting together a page just on mounts, it's not really done yet:
http://www.charm.net/~kmarsh/mounts.html
Most any mount system will do. The only catch is if there is problems
lining-up. If large windage (L to R) adjustment is needed, it is best
to do it with the mounts/rings and not in the scope. Some setups don't
allow any windage adjustments.
If there is elevation problems, you have too look at either shims or
filing or machining the mount.
In general, I like windage adjustable systems, because I can fine-tune
them to the point where only a few clicks of adjustment is needed to
finish sight-in.
#The scope is really nice, but the barrel is only 134 mm from bell to
#bell, so I'm a bit stumped.  It wouldn't fit on my Savage Model 110,
#which is why I'm trading up to the M70.
A common problem with the 110. Extension rings will usually fix it.
Sometimes you need only one, sometimes you need to. The are offset a
half inch or so forward (or back) of their mount point. Everyone makes
them but I have a special liking for the Millet brand for Weaver mounts.
They are strong, steel, and incorporate a windage adjustment that most
Weaver style rings lack.
Because of the windage adjustment, you have to be more careful not
to kink the scope when mounting. It should drop all the way in the
lower ring halves without interference.
If there is a local gun shop that sells a complete line-up of mounts and
rings, including extensions, it might be worthwhile to bring in your
rifle and scope, and eyeball the setup before plunking down the money.
If the shop has a collimator and scope lapping equipment, it may be
worth the $25-$75 to have them mount it. Sometimes you can get a
discount on that by buying the mounts, rings and some ammo while you are
there.
Ken.
  Don't call your civil war  | Mail: kmarsh at charm dot net
    our War on Terrorism.    | WWW:  http://www.charm.net/~kmarsh
Learn about rec.guns at              [url=http://www.recguns.com]http://www.rec
Was this solution helpful? Show your Appreciation by rating it:
Solution #2
Not Rated (0)
Kim1
Kim1 - usenet poster
Rating: 0%, 0 votes
Dear Dave:  Have your considered extention rings?  Nearly every maker
sells them.  With one in the front extending back and one in the back
extending forward, you could narrow the gap. - CW
Solution #3
Not Rated (0)
Bouncy
Bouncy - usenet poster
Rating: 0%, 0 votes
# I have a Nikon Monarch USS 3-9x40 rifle scope.  What hardware should I
# use to mount this on a .30 '06 Winchester Model 70 Classic
# Featherweight? Is anything specifically the "best" or preferred way,
# without starting any arguments?
# The scope is really nice, but the barrel is only 134 mm from bell to
# bell, so I'm a bit stumped.  It wouldn't fit on my Savage Model 110,
# which is why I'm trading up to the M70.
# TIA any suggestions.
# Dave
If I were mounting any scope, I would take a close look at the Burris
Signature rings. They allow perfect alignment of the scope with the rings,
without putting unnecessary stresses on the scope tube. They come with
synthetic inserts that fit within the steel rings. The inserts can rotate to
align with the scope tube when the rings themselves may not be in perfect
alignment. This is often the case, especially with two piece bases.
The inserts can be obtained with built in offsets so you can get your scope
on POA with the scope optics centered. A side benefit is that the inserts do
not leave marks or scratches on the scope tube.
You can check this out at the Burris site
http://www.burrisoptics.com/solidrings.html
RW
Can you Help with these Spotting Scopes problems?
Spotting Scopes
Crossman Mark 1 CO2 Pellet Gun
I live in Huntsville, Ontario,... Answer This...
Spotting Scopes
Borescope
Need circuit diagram for... Answer This...
Spotting Scopes
Assembly
how to put together a Crossman... Answer This...
unable to register scope in
unable to register scope in... Answer This...
300win mag
just put a new scope on my gun... Answer This...
Repair Service
Find Spotting Scope Repairman Near You:
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
