Question about YouTube Videos
PARTS FOR ROX GREASE GUN - YouTube Videos
How to load grease in it?
The model 1056S will accept the standard grease cartridge available at any parts store. I have to use a razor blade and cut off the metal pull tab end. Then push the cartridge into the cylinder from the top. The real trick is to guide the rubber seal into the cartridge; it can be done, I load mine this way. Use the little lock to hold off the long plunger, allow just enough to work with inorder to insert rubber seal into cartridge. Only after the rubber is in the cartridge, then screw on the bottom cap. Then release the long plunger rod. You noticed that the plunger rod will rotate out of the rubber seal assembly, rotate it so the rod can be pushed into the cylinder without pushing the rubber seals. The sping will push the rubber seal to ensure grease is mover to the top. Very powerful PSI, do not blow out the rubber cups around the zerk fittings. Good luck
Jul 05, 2014 | Alemite Lever Gun Model 1056s
Tip
Sewing Machine Maintenance
Sewing machines need specific grease & oil to keep parts moving freely. Never use 3-in-1 Oil, or white lithium grease. 3-in-1 turns into a sticky, yellow residue. White lithium grease thickens, then crystallizes on the gears. Always use clear sewing machine oil, and a clear synthetic grease like Tri-Flow.
on Mar 05, 2015 | Tri-Flow Synthetic Food Grade Grease,...
Hyundai sonta we're is the grease fitting
Good Morning! If you remember years ago, all vehicles had grease fittings all over it. Then in the late 70's going into the 80's they were slowly removed. This didnt mean that the parts didnt need to be lubricated, only that the manufactures cut costs by taking the grease fitting out and meant more repair parts being sold. Eventhough there is no grease fitting, you can still lubricate this parts if it has a boot to protect it. Most equipment manufacturers (Alemite, Balcrank, Graco, Lincoln, Samson, etc) make a Injection needle, You can pick one up for less than $10 at Napa or any parts store. It is actually the same needle used for IV's with a grease fitting pressed on the end of it. You can snap it on your grease gun and insert the needle through your boot (including CV joint boots). Be careful NOT to over lubricate. Normally two or three strokes of the gun is enough. Dont pump so much that the boot bursts. Then you defeated your purpose. Hope this helps and good luck!
May 05, 2014 | Cars & Trucks
How grease to grease ball joints on a 1998 dodge Dakota sport
You need a grease gun and a tube of grease for your particular vehicle make. You can purchase both at any auto parts store. If you haven't replaced the ball joints since the vehicle was made then you probably wont be able to grease them. Most vehicles come off the line without access. However aftermarket parts have points where you can grease. Take your grease gun and stick the end over the nipple,(sorry can't think of the name for the **** things that you grease into, so Im calling them nipples.) Anyway, pump the gun until grease comes out from the joint and that should do it. Really pretty simple operation provided you have the nipples at the joints already. Hope this helps.
Oct 26, 2012 | Cars & Trucks
What kind of grease to use on fr350 nail gun for piston o ring
Use white grease or silicone paste. White grease will stay in the gun longer . Silicone paste is cleaner will cost more however will break down with water that enters the gun and will tend to dry out. In either case, the grease will wash out of the gun if you use too much oil on a daily basis. For best results, install an oiler that will introduce oil mist into the gun (not expensive).
Nov 15, 2011 | Porter Cable 60074 Overhaul Kit For FR350...
I installed a new grease cartridge in my grease gun and grease does not come out when triggered.
If the gun was working properly before you changed the cartridge, The gun is air-locked
Two things: 1. Make sure the bottom rod is pushed in. 2. Holding the gun by the handle on the top left of the gun, below the hose there is a little metal valve. Push that vent valve down and pull the trigger repeatedly until grease starts to come out.
If that doesn't work. Remove the grease hose, hold the vent valve down, pull the trigger a few times. Then release the valve and pull the trigger until grease comes out. Replace the hose.
And if that doesn't work. Sometimes when you put in a new cartridge the metal "washer" that actually pushes the grease up the cylinder will get caught at the bottom of the new cartridge. Make sure the washer will move freely into the cartridge.
That should do it!
Jan 14, 2011 | Lincoln Automotive Pneumatic Grease Gun...
Hear and feel a grinding noise when turning,(either way) in my 2003 Ford Expedition
tie rods need grease. chances are you have a sealed system so if you crawl under there with a grease gun you will not see anyzerks. Go to a parts store and ask for a hypodermic needle for a grease gun and ou can punch a small hole in the rubber boot and give it 4 squirts of grease. allow a day or two to work it in and the grinding should go away. It will not leak or damage the boot to have the hole in it. all 3 of my fords have one.
If the noise doesnt go away then check the sway bar bushings and the control arms.
Oct 14, 2009 | 2003 Ford Expedition
Is there a specific type of grease gun ad grease I
There is really no special grease gun to get. Any type of grease gun will work. I personally use a high temp. grease at the shop I work at. When greasing anything never over grease a joint , it causes a mess and will cause premature failure. All that is needed is three pumps of the grease gun.
Aug 16, 2009 | 1993 Lincoln Town Car
Spray gun tips
RECOMMENDED SPARE PARTS FOR EACH GUN * Air nozzle, needle and tips * Packing and gaskets * Hoses and fittings * Gauges * Proper lubricants * Filter screens * Diaphragms for pressure regulators
Aug 27, 2008 | Grizzly H7670 Mini Hvlp Spray Gun,...
YouTube Videos Logo
67 people viewed this question
Top YouTube Computers & Internet Experts
Rizwan Hanif
Level 1 Expert
Michael Terence...
Michael Terence...
Are you a YouTube Computer and Internet Expert? Answer questions, earn points and help others
