Question about Video Game Consoles & Games
Why i cannot play justcause 2 game with black cat gamepad?
4 Suggested Answers
SOURCE: How do you configure a Logitech Chillstream gamepad?
I don't think you can...
Posted on Aug 03, 2008
SOURCE: USB GAMEPAD NOT WORKING!!!
I used one like that for my windows xp home PC (It looks just like the Playstation 2 controller) and it worked with MAME (original arcade games that were downloaded on my computer) It comes with a little CD that has the drivers on it...Look on ebay..they are very cheap coming from China and Hong Kong
Posted on Apr 24, 2009
SOURCE: My Logitech Dual Action Gamepad
Go into the Advanced Properties of your gamepad, and run through the configuration!
Posted on Sep 04, 2011
Trying to add a Bluetooth device but it's not connecting. I read that I might have the 'ADD NEW DEVICES' turned off. but I can't seem to find where to turn it on... or if that is my problem at all.
Connecting a Bluetooth Gamepad
(MENU/123) MENU System Device Manager Bluetooth Gamepad Settings
You can play the games downloaded and installed using the Smart Hub service with a Bluetooth gamepad. Select Bluetooth Gamepad Settings, and then place your Bluetooth gamepad close to your TV. The TV scans for available Bluetooth gamepads automatically. (DualShock®4, a gamepad optimized for PlayStation, is recommended.) After scanning, you can use the Bluetooth gamepad to play games.
  1. This function is not available on certain models in specific geographical areas.
  2. If the TV fails to find your Bluetooth gamepad, place it closer to the TV, and then select Refresh. For more information on pairing, refer to the Bluetooth gamepad's operating manual.
Feb 22, 2017 | Option Computers & Internet
Ive just bought a saitek p380 dual analog gamepad. When playing all games if i press left it goes up and right it goes down. Ive tried everything. i have windows 7. Is that the problem do you think?cheers
it usualy the settings in the game. just try to reconfigure the x and y axes to do the right thing inside the game you are playing and that should solve the problem. i did it and it worked fine for me
regards.
Dmitry
May 21, 2010 | Saitek P380 GamePad
Why doesn't my controller work on my pc for modern warfare 2 the game
Most latest games for PC do not support Logitech gamepads by default. There are various reasons to it, but using Logitech's Profiler software you can get your gamepad to work with any game. I help people make "profiles" for their games. All you have to do is download them, read the instructions and start playing. I ve already made one for Modern Warfare 2.... here's the download link:
Call of Duty Modern Warfare 1 & 2 Rumblepad 2, Dual Action and Precision Gamepad Setup
Enjoy.
Apr 04, 2010 | Logitech Dual Action for Pc (963292-0403:)...
My logitec precision gamepad is not working in NHL 2009.
Thank you for your time and attention. Can I use a Logitech Precision gamepad to play online video games? I plugged in the USB in the front of my pc tower, but I can't control the games with it. The games only respond to my keyboard. Is there something I need to do or is it that I can't use it to play online videogames? Please help.
Mar 04, 2010 | Logitech Precision USB Gamepad PC Game...
Gigaware controller on vista
You don't (and can't) disable DEP for the controller (a gamepad controller isn't an application, it's a device which uses a driver, Data Execution Protection applies to applications ie .exe files), it's the game or emulator you disable DEP for, so that you the game can run, completely free of security bindings, and then you would be able to go into the game configuration menu and select your gamepad, and calibrate it. Calibrating means the game detects you gamepad and applies the specific functions to each button.
One way to be sure is to disable DEP for everything, then install a game, and THEN plug in your gamepad. Then start the game/emulator and go to the configuration menu within the game/emulator and set up the gamepad calibration in there.
If it doesn't work, then you haven't installed the drivers for the gamepad properly, or haven't installed the correct driver.
Before doing any of that, you would have checked in Control Panel and Gamepad Controllers, double clicked the Gamepad in the list and pressed Calibrate, to enable generic gamepad functionality.
If you hadn't done that, do so now.
If it still doesn't work, then NOW disable the DEP (either all DEP or for the game/emulator you want to play). Unplug the Gamepad and load up a game. Then plug the game pad in. Set up the gamepad from within the game/emulator config menu, which differs from game to game, of course, but is more or less the same.
If it doesn't work.. re-install the correct driver for the gamepad.
Also make sure your operating system is fully updated and you're plugging the gamepad into a usb2.0 port. and have rebooted after installing the gamepad usb driver.
That's everything you need to know..
Good Luck!
Chris (ziraffa)
Dec 27, 2008 | Video Game Consoles & Games
I want cheat codes of sims 2 pets
  • Cheat Gnome While at home or on a lot, press L1(2), R1, X(2), Up. Then, enter one of the following codes to activate the corresponding cheat function:
      10,000 additional Simoleons Enable the "Cheat Gnome" code, then press Up, Left, Down, Right, R1 while playing the game. An option to advance time by six hours will now appear on the Cheat Gnome. Select the Cheat Gnome, then cancel the selection. Press Up, Left, Down, Right, R1 again. A "Give Sim Simoleons" option should now appear.
      Pet Points Enable the "Cheat Gnome" code, then press Triangle, Circle, X, Square, L1, R1 while playing the game. A "Pet Points" option will now appear on the Cheat Gnome.
      Pet Emporium fully upgraded Enable the "Cheat Gnome" code, then press Right, Down, Right, Up, Right, Down, Right, Up while playing the game.
      Advance time by 6 hours Enable the "Cheat Gnome" code, then press Up, Left, Down, Right, R1 while playing the game. An option to advance time by six hours will now appear on the Cheat Gnome.
  • Alternate opening sequence At the EA logo, press X, Circle, Triangle.
  • View developers At the credits screen, press Right, Left, Up, Right, Down, Right, Down, Right.
  • Bonuses At the codes screen under the "Game Options" menu, enter one of the following codes to activate the corresponding cheat function:
    Result Code
    Collars
    Black Dot Cats ZZZ11ZZZ9Q11Q91ZB1A or EEGJ2YRZQQ1IQ9QHA64 Black Dot Dogs ZZZ11ZZQHZ11Q91ZB1A or EEGJ2YRQZZ1IQ9QHA64 Black Smiley Cats ZZZ11ZZQ9Z1AQ91ZB1A or EEGJ2YRQQZ1RQ9QHA64 Black Smiley Dogs ZZZ11ZZZ9QAAQ91ZB1A or EEGJ2YRZQQARQ9QHA64 Blue Bones Cats ZZZ11ZZQHZAAQ91ZB1A or EEGJ2YRQZZARQ9QHA64 Blue Bones Dogs ZZZ11ZZZHZ11Z91ZB1A or EEGJ2YRZZZ1IZ9QHA64 Blue Camouflage Cats ZZZ11ZZZHQ11Q91ZB1A or EEGJ2YRZZQ1IQ9QHA64 Blue Camouflage Dogs ZZZ11ZZZHZ1AQ91ZB1A or EEGJ2YRZZZ1RQ9QHA64 Blue Star Cats ZZZ11ZZQ9Z11Z91ZB1A or EEGJ2YRQQZ1IZ9QHA64 Blue Star Dogs ZZZ11ZZQHQ11Q91ZB1A or EEGJ2YRQZQ1IQ9QHA64 Green Flower Cats ZZZ11ZZZ9ZA1Q91ZB1A or EEGJ2YRZQZAIQ9QHA64 Green Flower Dogs ZZZ11ZZQHZ1AQ91ZB1A or EEGJ2YRQZZ1RQ9QHA64 Navy Hearts Cats ZZZ11ZZZ9Z11Q91ZB1A or EEGJ2YRZQZ1IQ9QHA64 Navy Hearts Dogs ZZZ11ZZQ9Z11Q91ZB1A or EEGJ2YRQQZ1IQ9QHA64 Orange Diagonal Cats ZZZ11ZZQ9ZA1Q91ZB1A or EEGJ2YRQQZAIQ9QHA64 Orange Diagonal Dogs ZZZ11ZZZ9Z11Z91ZB1A or EEGJ2YRZQZ1IZ9QHA64 Pink Vertical Strip Cats ZZZ11ZZQ9QAAQ91ZB1A or EEGJ2YRQQQARQ9QHA6 Pink Vertical Strip Dogs ZZZ11ZZZHZA1Q91ZB1A or EEGJ2YRZZZAIQ9QHA64 White Paws Cats ZZZ11ZZQ9Q1AQ91ZB1A or EEGJ2YRQQQ1RQ9QHA64 White Paws Dogs ZZZ11ZZZ9Q11Z91ZB1A or EEGJ2YRZQQ1IZ9QHA64 White Zebra Stripe Cats ZZZ11ZZZHQ11Z91ZB1A or EEGJ2YRZZQ1IZ9QHA6 White Zebra Stripe Dogs ZZZ11ZZZHZ11Q91ZB1A or EEGJ2YRZZZ1IQ9QHA64
    Fur colors
    Blue Cats ZZZ11ZZQHZA1Q91ZB1A or EEGJ2YRQZZAIQ9QHA64 Blue Dogs ZZZ11ZZQ9Q11Z91ZB1A or EEGJ2YRQQQ1IZ9QHA64 Deep Red Cats ZZZ11ZZQ9QA1Q91ZB1A or EEGJ2YRQQQAIQ9QHA64 ° Deep Red Dogs ZZZ11ZZQHQ1AQ91ZB1A or EEGJ2YRQZQ1RQ9QHA64 Goofy Cats ZZZ11ZZQHQ11Z91ZB1A or EEGJ2YRQZQ1IZ9QHA64 Goofy Dogs ZZZ11ZZZHZAAQ91ZB1A or EEGJ2YRZZZARQ9QHA64 Green Cats ZZZ11ZZZ9QA1Z91ZB1A or EEGJ2YRZQQAIZ9QHA64 Green Dogs ZZZ11ZZQHQA1Q91ZB1A or EEGJ2YRQZQAIQ9QHA64 Light Green Cats ZZZ11ZZZHQ1AQ91ZB1A or EEGJ2YRZZQ1RQ9QHA64 Light Green Dogs ZZZ11ZZZ9Q1AQ91ZB1A or EEGJ2YRZQQ1RQ9QHA64 Neon Green Cats ZZZ11ZZZHQA1Q91ZB1A or EEGJ2YRZZQAIQ9QHA64 Neon Green Dogs ZZZ11ZZZ9QA1Q91ZB1A or EEGJ2YRZQQAIQ9QHA64 Neon Yellow Cats ZZZ11ZZZHQAAQ91ZB1A or EEGJ2YRZZQARQ9QHA64 Neon Yellow Dogs ZZZ11ZZQ9QA1Z91ZB1A or EEGJ2YRQQQAIZ9QHA64 Pink Cats ZZZ11ZZQHZ11Z91ZB1A or EEGJ2YRQZZ1IZ9QHA64 Pink Dogs ZZZ11ZZZ9Z1AQ91ZB1A or EEGJ2YRZQZ1RQ9QHA64 Purple Cats ZZZ11ZZQ9ZAAQ91ZB1A or EEGJ2YRQQZARQ9QHA64 Purple Dogs ZZZ11ZZQ9ZA1Z91ZB1A or EEGJ2YRQQZAIZ9QHA64
    Fur patterns
    Bandit Mask Cats ZZZ11ZZQHZA1Z91ZB1A, TB6IPB1IAFDMRIQT6DG, or EEGJ2YRQZZAIZ9QHA64 Bandit Mask Dogs ZZZ11ZZQHQAAQ91ZB1A or EEGJ2YRQZQARQ9QHA64 Panda Cats ZZZ11ZZQHQA1Z91ZB1A or EEGJ2YRQZQAIZ9QHA6 Star Cats ZZZ11ZZZ9ZAAQ91ZB1A or EEGJ2YRZQZARQ9QHA6 Star Dogs ZZZ11ZZZ9ZA1Z91ZB1A or EEGJ2YRZQZAIZ9QHA64 Zebra Stripes Dogs ZZZ11ZZZHQA1Z91ZB1A or EEGJ2YRZZQAIZ9QHA64
  • Dec 21, 2008 | Sony PlayStation 2 (PS2) Console
    Logitech controller not working
    I have same problem, spoke to manufacturer who stated it will only work with games that are played from a disc and can not be used to play online flash games as they are not programmed to accept gamepads. does anyone know how to change settings or something on flashplayer to accept gamepad ??
    Mar 01, 2008 | Logitech Rumblepad 2 Vibration Feedback...
    Emulator Project64 plays Nintendo 64 Games
    sory don't have a solution i have the same prob i have a logitach wingman extreme gamepad controller and it says it is working fine but dosent work with pj64 games like perfect dark or golden eye but i can play them with my keyboard wtf ?
    Feb 14, 2008 | Logitech Rumblepad 2 Game Pad
    Video Game Consoles & Games Logo
    Top Video Game Consoles & Games Experts
    James Wishart
    Are you a Video Game Console and Game Expert? Answer questions, earn points and help others
