Question about Dell 2150cdn Laser Printer
Installed a new 2155 dell image drum and the toner still leaks
After install the new 2155 cdn image drum the toner still leaks out
  • 46 Answers
SOURCE: Dell 1600n has been ghosting lately
The 1600n AIO (all-in-one) is a laser printer. Laser printer use a statically charged "drum" to place toner on the paper. Your ghosting problem may be from the drum itself becoming too charged or simply dirty and not the cartridge. Servicing laser printers is tricky business because they use a lot of wattage/voltage to create the static charge and also "bake" the image onto the paper. A very quick fix would be to de-ionize the drum and clean it thoroughly.
First, make sure you have the unit completely unplugged for, at least, ten to fifteen minutes before proceeding to ensure that all static charge has had a chance to dissopate.
Second, remove the toner cartridge and place it on some newspaper or paper towels. Inspect it for any residual toner and/or damage that may be causing the ghosting (look for cracks/grooves/lines in the cartridge that shouldn't be there).
Third, take a used dryer sheet (or one that's had most of the chemical fabric softener rinsed off and then completely dried) and wipe the entire drum to completely remove any static charge. Then, using denatured alcohol and static-free, lint-free wipes clean the entire drum to remove any remaining detritus. Allow to dry thoroughly before proceeding.
Last, wipe the drum down, one final time, with a clean dryer sheet or lint-free cloth. Reassemble the unit and replace the toner cartridge.
Run a few clean sheets (blank prints or copies) to further remove any particles knocked loose and check for any more "ghosting."
Final printing will be necessary to check for inconsistencies or success.
Posted on Nov 08, 2007
SOURCE: Pages full of toner / toner streaking
First off, this is a comment from a random person who may or may not know ALOT about these printers and toner/printer design in general. All toners are not designed to the same specification. Toner is a combination of plastic "pigment" and iron like shavings to make it magentically attracted to the electrical charges within the unit. Different toners conform to different grades and mainly size of the particles within the blend. The manufacturer doesnt only recommend that you use their toner to make them money, yes of course it makes money, but its because when the unit is designed it is designed to use a certain grade of toner, trust me if you put the non-branded toner vs the branded toner under a microscope you would see quite a difference. Often the non-branded toner is much larger in particle size (obviousely because its cheaper to make at this spec). This causes a variety of issues from excess toner not being cleaned off of developer rollers, IDT rollers, or clogging of toner dispenser tubes in the unit and the micro filters contained at the toner dispenser assy and developer assys. Also as for the issue not changing when switching to dell branded toner - the dispenser tubes within this unit contain up to 500-1000 pages worth of toner, making no change in toner you make immediately visible. Also depending on the damage caused by the previous toner, it may not be able to be fixed until all the components in between the toner and final delivery (drum cart) are replaced. In this case more than likely the toner dispenser assy, all developer assy's, and drum cartridge need to be replaced, and than be sure to stick with factory branded toner :)
Posted on Jul 17, 2008
  • 53 Answers
SOURCE: toner mess on one side of paper dell 1720 printer
The transfer roller may have toner on it that is making that mess. Remove the toner and drum, look inside the printer, there is a grey roller towards the back of the printer. Is there toner on the right hand side that corresponds to the print out? If there is, cleaning it may only make it worse. Replacing it would be the best solution. You would want to make sure that the drum is clean after replacing the roller, if it is not ,then it will transfer to this roller once again.
Posted on Jul 03, 2009
SOURCE: Unable to remove imaging drum - Dell 5110cn Color Printer
When you open the front cover it is possible for the transfer roller assembly to remain latched against the imaging drum assembly, making it impossible to pull out the imaging drum. The drum should lift out very easily. If it doesn't, try closing the imaging drum cover and then the front cover (ie: put everything back the way it was). Then open the front cover again, pressing firmly on the front cover latch. When open, check that the transfer roller assembly stayed with the front cover and swung out of the way of the imaging drum (you may have to swing it yourself. When the front cover has opened properly, the imaging drum's cover will unlatch easily and the drum can be pulled out.
I hope this helps someone! I had to say many bad words before I figured this out. Good thing I had a second 5100cn handy to look at for comparison. - B.Till
Posted on Dec 03, 2009
SOURCE: My Dell 5110CN printer is printing a double image
I am having the same problem, and I am using the original toner cartridges that were supplied with the printer, so yes, they are genuine Dell toner cartridges.
Posted on Jan 31, 2010
Warming-up
MODEL #######################
Power off the machine. Then remove the toner bottle, be careful the hole might be on the bottom and the toner is going to go everywhere. Then close the toner cover and turn on the machine. Let the machine go through it normal routine. When it asks for toner install the toner bottle correctly. If THE KNUB on the side of the bottle is damage put a new one in. That KNUB is what the toner motor uses to turn the bottle, if it damaged you get a code. If that does not work, you might have a bad motor or the home sensor or actuator for the toner bottle is bad worse case the control board is bad.
OR
Have you had the developer and drum replaced or does the screen say Replace PC Drum? There are certain house chores the copier does before "Ready to Copy" it is waiting for them to get done, so that equals "Please Wait". One big item is making sure the developer and toner are properly mixed inside the image unit underneath the drum. Might want to have the developer replaced and drum/cleaning blade normally done all together, then run the F8 procedure and make sure the counters where cleared. Did you recently replace the drum and the developer if so did you clear the counters for the drum and developer, FIRST? IF not then the copier thinks the new drum and new developer are old. The copier works on the counters that is how it knows it got a new drum and developer. Get new developer and a new drum and have it installed correctly. Counters are clear before the unit is yanked out of the machine, then you remove the image unit/drum unit replace the developer/drum and cleaning blade. (DO NOT USE A VACUUM CLEANER WHEN REPLACING THE DEVELOPER static electricity can destroy the sensor located below the developer unit. Then reinstall and RUN F8. Make sure the fax line and Ethernet cable is removed can't print anything until the F8 is run. Or you will start all over again with new developer and a new drum.
Try this site for parts as a start
Precision Roller Printer Toner Cartridges Parts and Supplies Office...
Apr 02, 2014 | Konica Minolta Office Equipment & Supplies
Please wait message on bizhub 164 machine at startup
1. Power off the machine. Then remove the toner bottle, be careful the hole might be on the bottom and the toner is going to go everywhere. Then close the toner cover and turn on the machine. Let the machine go through it normal routine. When it asks for toner install the toner bottle correctly. If THE KNUB on the side of the bottle is damage put a new one in. That KNUB is what the toner motor uses to turn the bottle, if it damaged you get a code. If that does not work, you might have a bad motor or the home sensor or actuator for the toner bottle is bad worse case the control board is bad.
2. Have you had the developer and drum replaced recently, or does the screen say Replace PC Drum? There are certain house chores the copier does before "Ready to Copy" it is waiting for them to get done, so that equals "Please Wait". One big item is making sure the developer and toner are properly mixed inside the image unit underneath the drum or next to it depending on the series. Might want to have the developer replaced and drum/cleaning blade normally done all together, then run the F8 procedure/Developer Charge, and make sure the counters where cleared. Did you recently replace the drum and the developer if so did you clear the counters for the drum and developer, FIRST? IF not then the copier thinks the new drum and new developer are old. The copier works on the counters that is how it knows it got a new drum and developer. Get new developer and a new drum and have it installed correctly. Counters are clear before the unit is yanked out of the machine, then you remove the image unit/drum unit replace the developer/drum and cleaning blade. (DO NOT USE A VACUUM CLEANER WHEN REPLACING THE DEVELOPER static electricity can destroy the sensor located below the developer unit. Then reinstall and RUN F8/Developer Charge. Make sure the fax line and Ethernet cable is removed can't print anything until the F8 is run. Or you will start all over again with new developer and a new drum.
Jan 05, 2014 | Konica Minolta bizhub Office Equipment &...
Dell CDN 5130 has an error code 092-670
Use the wand on the front door. Insert it into the four slots behind the front panel.. These are the laser lenses or RoHS.. There is probably toner on the glass beneath the image drums.. Your particular error is for the Yellow try that first. Still best you wand all 4 colors.
Jun 26, 2013 | Cell Phones
Printing blank page even in test mode. hplaserjet 1200
Checking the toner cartridge
Image formation defects are many times the result of problems in the toner cartridge. If there is any doubt, always replace the toner cartridge before troubleshooting image defects.
Use the following checklist to make sure that the toner cartridge is still operable.
" Make sure that the toner cartridge is seated properly.
" Inspect the toner cartridge for toner level.
" Check the expiration date stamped on the toner cartridge box.
" Check the toner cartridge to see if it has been disassembled or refilled.
" Inspect the toner cartridge to see if toner is leaking through worn seals.
" Check the surface of the photosensitive drum in the cartridge to see if it has been damaged or scratched. Touching the drum contaminates the photosensitive surface and can cause spotting
and image defects.
" Blurred areas on printed pages indicate that the photosensitive drum in the cartridge has been overexposed to light. Because overexposure to light causes permanent damage to the photosensitive drum, the cartridge should be replaced.
Note A toner cartridge weighs approximately 863 grams (30.5 oz) when it is full, approximately 766 grams (27.0 oz) when it first fades, and approximately 742 grams (26.2 oz) when it is empty.
To redistribute toner in the cartridge
Before installing a new cartridge or when toner begins to run low, redistribute the toner by rotating the cartridge back and forth five or six times.
Jul 27, 2011 | HP LaserJet 1200 Printer
My hp laserjet m1005mfp printer is not printing document while i replace its cartridge twicely so give me solution urgently
Checking the print cartridge
Image-formation defects are frequently the result of problems in the print cartridge. If the source of the defect is not immediately evident, always replace the print cartridge before troubleshooting image defects.
Use the following checklist to make sure that the print cartridge is still operable.
? Make sure that the print cartridge is seated properly.
? Check the print cartridge to see if it has been disassembled or refilled.
? Inspect the print cartridge to see if toner is leaking through worn seals.
? Check the surface of the photosensitive drum in the cartridge to see if it has been damaged or
and image defects.
? Blurred areas on printed pages indicate that the photosensitive drum in the cartridge has been
To redistribute the toner in the print cartridge
Before installing a new print cartridge or when the toner begins to run low, redistribute the toner by
Jul 22, 2011 | HP LaserJet M1005 Printer
Hi I have a brother HL-4040 CDN -- I had to clean off the imaging drum by rotating the gear manually now it is telling me that all three of my new colours of toner are suddenly at their end of...
For getting proper guidance to fix this error plz call me at +1800-243-0051 ' 1800-243-0019. Because its not possible to fix the error on here. May be we fix it with doing some work together.
May 19, 2017 | Brother HL-4040CN Laser Printer
HP 2550n laser - black "toner" on imaging drum.
try replacing your Black toner cartridge first
repost here if it doesn't fix it.
May 05, 2010 | HP Office Equipment & Supplies
OKI 3300 Image Drum Problem
Did you remove the plastic tape from the new cartridge?
Feb 16, 2009 | Oki Electric Industry C3300n Laser Printer
Hp2820 noise when printing
Try substituting a new imaging drum. The problem may be a bad bearing.
Oct 09, 2008 | HP LaserJet 2820 Printer
Toner disappears!
ok, this issue is not toner related actually. the toner bottles you have removed, I am sure still feel the weight of a nearly full one.
The issue, is most likely, the Image Drum, the toner volume, is actually measured by toner flow resistance by a device within the Image Drum, I can explain it in detail, but will take a page..
toner cartridges, only have a chip transmitter in then, that tell the machine a code when it is first installed into the machine, this resets the toner volume processor only, then the yoner flow resistance inside the Image Drum signals the processor as to how the toner is travelling..
Replace the Drum, and then enjoy using all those almost full toners...
Aug 21, 2008 | Xante Ilumina Digital Color Press Printer
Dell 2150cdn Laser Printer Logo
133 people viewed this question
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Electro Med Services...
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
