Question about Philips SA5125/37 MP3 Player
Wont turn on or even charge? what do i do if i restart it does it wipe the memory ?
  • Anonymous Mar 24, 2009
    it won't charge i rreset it it still won't work what do i do now or where do i get a new battery?
    Scholar:
  • 150 Answers
Restarting shouldn't wipe the memory because it is a solid state drive not a RAM drive. You can try doing that to see if that fixes the problem but you probably need to replace the battery.
Please rate, Thanks!
Posted on Mar 11, 2009
My iphone wont turn on or charge
mY Dear:
First:
restore your Phone Settings
IF Restart problem not Solved So
Secend Option:
Please Format Your Phone
we can solve this problem but i need you to backup the whole DATA that you have in the phone and perform this reset procedure.
*#7370# or *#7780#
Default security code is 12345
release some memory then it will b opened
your phone or memory card get attack by virus. pls do a format phone and memory card.
If Problem Not Solved So
Very Best Solution:
flash new software install in the phone problem will solved quickly
Sep 10, 2012 | Apple iPhone 3G
My phone simply wont turn on or charge. Have had no problems with it whatsoever and was in perfect working order until yesterday. I turned it on but the screen froze. I then took out the battery and ever...
Hi, I am an owner also of a nokia 5530 xpress music. . I have that same kind of problem once and to be honest it had me worried that it might not start again. but I check in the internet for tips on other ways turning it on. Here are some simple tips : 1#. try taking off the memory card before restarting it and it will automatically restart again. 2#. If it wont start then try reformatting the memory card or have your nokia 5530 checked out by an expert technichan.
Hope that helps. take care. . Dominic :))
Mar 04, 2011 | Nokia 5530 XpressMusic Smartphone
MY CAMERA WONT COME ON THE TELESCOPE LENSE WONT GO BACK IN IT DOSNT SEEM TO CHARGE
Please try the following: Don't forget if you're charging though the computer NOT to turn the camera on. 1. Clean the battery contacts. a. Remove the battery/batteries and the memory card from your camera, then wipe the battery contacts with a soft, clean cloth. b. Reinstall the battery/batteries into your camera. Please make sure that you are installing a fresh/ fully charged battery c. Turn the camera on. 2. Without the memory card, turn your camera on. (If it works then it?s your memory card that is faulty) 3. Please test with the a different battery If you do not have access to another battery Try these steps instead: Please take the battery out of the camera. b. Insert the charger into the unit from the main socket and turn the camera on. If the camera works you will need to replace the battery. If you camera doesn?t switch on you will need to order a no power repair with KODAK or a new cable.
Jan 27, 2010 | Kodak EASYSHARE M1063 Digital Camera
Camera wont stay on, new batteries and even tried wiping out the inside with a cloth and that only works for a few shots.
Here are the steps for the no power problem: 1. Make sure you will install a new or fully charged battery/batteries into your camera. Please use lithium batteries Ni-Mh or rechargeable Batteries (2000 M.Amp or higher). 2. Clean the battery contacts. a. Remove the battery/batteries and the memory card from your camera, then wipe the battery contacts with a soft, clean cloth. b. Reinstall the battery/batteries into your camera 3. Turn on your camera without the memory card. (If it works then it?s your memory card that is faulty)
Jan 07, 2010 | Kodak EasyShare Z1275 Digital Camera
Wont turn on
Dec 31, 2009 | Kodak Easyshare C813 Digital Camera
Wont turn on used new batteries and still wont turn on
Here are the steps:
1. Make sure you will install a new or fully charged battery/batteries into your camera.Pls. use lithium batteries Ni-Mh or rechargeable Batteries (2000 M.Amp or higher).
3. Without the memory card,turn on your camera.
Contact KODAK:
http://www.kodak.com/eknec/PageQuerier.jhtml?pq-path=14563&pq-locale=en_US&_requestid=3490
Dec 02, 2009 | Kodak Easyshare C813 Digital Camera
My Kodak EastSgare CD40 will not come on, even
Here are the steps:
If issue persists, call 1.800.235.6325 for repair.
Thanks.
Neerak21
Sep 28, 2009 | Kodak EasyShare CD40 Digital Camera
Kodak 10.3 camera lance wont fully extend when
Here are the steps:
clean cloth.
Thanks.
Neerak21
Sep 25, 2009 | Kodak EASYSHARE M1063 Digital Camera
My Kodak af 3x optical aspheric lens camera won't turn on. it was fine yesterday but today it wont turn on. I've charged it and everything but it doesn't do anything. Help!
Here are the steps:
Sep 24, 2009 | Cameras
My camera wont turn on even with fully charged batteries
Make sure that you have the correct battery type installed, and that the batteries are fresh/fully charged. If the problem persists, you may have corrosion on the battery contacts inside that camera that is preventing full battery power from flowing to the camera. Remove the batteries and wipe the inside camera contacts firmly with a dry cloth (heavy corrosion may require cleaning with a wire brush, steel wool, or sand paper). Remove any residue that may have fallen into the battery compartment during cleaning, then wipe both ends of the batteries and reinstall them in the camera. This cleaning solves the problem about 90% of the time, and I hope it works for you.
Sep 13, 2009 | Samsung Digimax D53 Digital Camera
Philips SA5125/37 MP3 Player Logo
78 people viewed this question
Top Philips Audio Players & Recorders Experts
Gyula Lacz
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
