Question about HP Officejet J4680 InkJet Printer
Change language on a hp touchsmart c4680 printer
don_farr
  • 1011 Answers
SOURCE: HP Phhotosmart c4680 install issue - Printer
I have to ask this question of you, just to make sure this is not an issue. Are you using a factory new ink cartridge?
Please consider the following:
If you are using a refilled or third party cartridge that may well be your problem. Most manufacturers build logic into their products to prevent the use of “Other Equipment Manufactured” cartridges as well as re-filled cartridges.
They do this to prevent problems from contaminated inks causing problems with print quality or damaging the physical printhead.
If you are using factory new cartridges, then please call the manufacturers Technical Support for assistance with the warranty on the cartridges
Don
Posted on Dec 17, 2009
michaelshaun
  • 126 Answers
SOURCE: I have a new HP C4680 printer. When I print from
try printing a test page from the printer and if it works fine you need a software(HP smart web printing )
and you will get the software in the following website :
www.hp.com/go/smartwebprinting and there would be instructions given in the same page download and install the printer software and try printing from the internet using teh software and it shoul print perfect though it is complicated but this has been the best resolution for printing online
hope you liked the software and everything works fine
if you still have questions get back to us and we will surely help you
thanks
regards
Hamid
Posted on Feb 20, 2010
  • 142 Answers
SOURCE: Printer HP Photomaster C4680 caused error.
* Install the printer first and perform the following steps:
1. Click on Start >> Run (or in the 'Start Search' box).
2. Type MSCONFIG
3. Click on 'OK'. The Configuration Utility should open on the screen.
4. Click on the 'General tab'.
5. Choose 'Selective startup'
6. Check 'Selective startup'
7. Click on 'STARTUP' tab.
8. Uncheck all the programs which start with 'HP' or 'hp' except for 'hpqtra08'.
9. Click on 'OK'. Restart the system
If you are getting a message "System Configuration Utility, you are using the selective startup for troubleshooting your system", I suggest you check the check box in that window and click on 'OK'. This occurs if you are using the Selective startup option and not using the normal startup to reduce the number of startup programs.
Now verify the result
:) Dr Tony
Posted on Apr 20, 2010
  • 739 Answers
SOURCE: HP C4680 Goes Offline
Hi
Just a thought, did you use the HP CD that came in the box?
Go to Apple's website and look under the support - downloads section. You'll find a mega-sized download of up-to-date HP drivers. Download it and install it.
Then open the print and Fax setting in system preferences and remove the existing HP printer, You should then have no printers listed in the printer box.
make sure the printer is connected to the macbook and switched on and then use the Plus symbol to add a new printer. In less than a moment your printer name should appear in the empty space. Select it and wait. You should then get a thing saying 'Print Using...." It should fill in automatically with info about the driver being used.
Do what ever it asks and then close the window and see if you can print without the earlier problems.
Posted on May 04, 2010
  • 1575 Answers
SOURCE: need users manual for hp photosmart c4680 printer
Hi
Download the manual from the link below.
h10032.www1.hp.com/ctg/Manual/c02240492.pdf
Hope it helps.
Posted on Feb 19, 2012
Testimonial: "thanks for the download i have already found the manual keep up the good work"
Print cartridge problem hp c4680
1. remove all the ink cartridges from the printer and then clean the copper contacts with a lint free cloth put it back in and check if that helps..
2. then unplug the power chord from the back of the printer without turning off the printer and then press and hold the power button for 30 sec. then release the button and then plug in the power chord at the back of the printer and check if that helps..
3. try changing the ink cartridges as it might be an issue with the ink cartridges... however if you have already done that then most probably its an issue with the printer hardware.. you should call HP and ask for replacement...
Oct 21, 2013 | HP C4680 All-In-One Inkjet Printer
Hp photosmart c4680
The HP C4680 is a powerful all-in-one printer that combines an easy interface and connection process with powerful printing capability.
With a small time investment and minimal effort, even the least tech-savvy home user among us can have their HP C4680 up and running in no time, and take full advantage of all of its printing power.
Connect the AC adapter from the AC terminal on the upper right-hand side of the back panel of the printer to an electrical outlet or surge protector.
Power on the printer using the power button on the front panel of the printer and specify language and country preferences using the prompt on the main display of the printer.
Remove the pink tape from the print heads on the provided ink cartridges.
The tape should come off easily with gentle pressure.
Install the cartridges by opening the main door on the front of the printer and placing the cartridges into the cartridge cradles.
The HP logo should be facing up. Push the cartridge into the cradle until it clicks into place.
Attach the USB cable from the printer's USB port to a USB port on your computer and power on the printer.
Install the setup CD that came with the printer into your computer's CD-ROM drive and follow the steps for installing the printer software on your computer.
Your HP C4680 is now set up and ready to use.
HP Printer Driver Packages
http://h20000.www2.hp.com/bizsupport/TechSupport/ProductList.jsp?lang=en&cc=us&taskId=135&prodTypeId=18972&prodSeriesId=25523
Aug 09, 2013 | Computers & Internet
How do i change the language back to english on my HP C4680
I've got the same problem. I've been spending hours looking around on the web but there is no real solution. The solution pressing the three buttons in the sequence doesn't work. The only solution is to learn the foreign language. :)
Jan 01, 2013 | HP Photosmart C4680 Q8418A InkJet MFC /...
I lost my CD installer of my HP printer C4680
Hi
Download the drivers from the link below.Remember to select your Operating System to download the corresponding drivers.
h10025.www1.hp.com/ewfrf/wc/softwareCategory?cc=us&lc=en&dlc=en&product=3739150
Hope it helps.Thanks!
Feb 26, 2012 | HP C4680 All-In-One Inkjet Printer
Carriage jam on HP C4680 printer after putting in new ink cartridges
Have you checked to see if you have a paper jam in the back entrance of your printer. Make sure there are no pecies of paper jamed on the roller.
Jan 20, 2011 | HP C4680 All-In-One Inkjet Printer
thanks
regards
Hamid
Feb 18, 2010 | HP C4680 All-In-One Inkjet Printer
HP Officejet J4680 InkJet Printer Logo
35 people viewed this question
Seeker5211
Seeker5211
