Question about Primo 900172 1.0 Gallon Industrial Water Dispenser
Water is pouring slow from the dispenser - Primo 900172 1.0 Gallon Industrial Water Dispenser
The detergent door will not open on Electrolux model fbd2400kb8b Soap does not dispense
It may be sticking from soap residue, pour boiling water slowing into the dispenser and see if that clears it. Be careful
Feb 16, 2017 | Electrolux Dishwashers
My Kenmore ice and water in the door refrigerator has the ice in the storage bin freezing into big clumps of cubes and the dispenser forces the bin out of position. It acts like the icemaker is getti
There may be ice forming in the water chute causing water to spill out of the chute and pour onto the ice in the bucket. Sometimes the water valve has a slow drip or is slow to shut off. the valve may need replacing. I doubt it is the icemaker but it could be.
Oct 04, 2014 | Refrigerators
Water leak electrolux
Good Morning atgltd,
So I understand that your water dispenser continues to release water for several minutes after pouring a glass of water and that it also randomly dispenses water. It sounds like something could be going on with either the dispenser module or the water actuator. Give the refrigerator a hard reset. You can do this by either unplugging it or by switching the breaker off that it is connected to. Leave it off for 3-5 minutes. Connect the power back, and if you are still having the same troubles of the dispenser releasing water, I would suggest that you contact a local authorized technician to see what exactly is causing the water to continuously dispense.
-Best Regards-
Jan 24, 2014 | Frigidaire FRS3R5EMB Side by Side...
Does anyone have a easy method for refilling lotion dispensers? Trying to pour lotion into a dispenser, I have been using a funnel. It's a very slow process.
You can try using pouring the lotion first in an icing bag then squeeze it into the lotion dispenser. If you don't have an icing bag use a sandwich bag or any plastic. Just cut a hole in the bag.
Jun 26, 2011 | Health & Beauty
Fabric softener dispenser does not drain
It's clogged. Get a tea kettle, heat it to boiling, and slowing pour the hot water into the dispenser until it clears.
Oct 18, 2009 | GE Washing Machines
No water going in the ice maker but water dispener
Pour about 2/3 cup of water into icemaker . If it freezes and does not dump , replace the icemaker . Check to make sure the coils are clean of dust , lint , pet hair , etc . If it does dump , and does not refill with water , replace the water inlet valve ( piece behind refrig where the wall water line connects to on the fridge ) . Check to make sure the fill tube that fills the icemaker is not blocked with ice , still indicating a bad water inlet valve ( slow seep ) .
Aug 29, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Water is pouring out of where the soap dispenser is. Can anyone help?
its pouring out because the dispenser is getting clogged in somewhere and not letting the water to the drain pump so its pouring from the soap dispenser. Remove the dispenser, pour water into the opening and make sure water can get into the machine freely. Inspect the opening for soap build up.
If water goes down slowly , open the washer door and feel around the bellow for anything blocking the water inlet port into the washer (socks can sometimes get wedged up there and cause a blockage).
If it all checks out ok, make sure the machine is properly leveled and not leaning forward.
Hope that helps!
Jul 09, 2009 | Kenmore 43142 Front Load Washer
Water pouring from waterdispenser in side by side refrig
Dispenser leaking----Probably replace the water inlet valve on the back where the water supply comes in. Disconnect the water line to the dispenser there and see if it keeps dripping when you try the dispenser
Jul 01, 2009 | Kenmore 5553 / 655532 / 55534 / 55539 Side...
Water Pouring out of the soap dispenser
ckd the line from dispenser into tub start inside tub first look for clothing caught at inlet point pull dispenser drawer out and ck from dispenser end may try pouring water in from that end also if happen to use dry detergent an undisolved lump may be caught somwhere in between
Nov 08, 2008 | Washing Machines
Could SOAP DISPENSER be caked with soap???
POWDERED DETERGENTS GET CLOGGED ALOT IN THOSE DISPENSERS. I ADVISE CUSTOMERS TO FILL THERE WASHER AND ADD SOAP WHEN IT STARTS TO AGITATE WHEN USING MORE THAN A 1/2 CUP OF POWDER ... THEN ADD YOUR CLOTHES ... THE WASHER HAS A SAFTEY SWITCH WILL STOP MOST WASHERS WHEN AGITATING OR IN SPIN CYCLE,SO YOU CAN LOAD CLOTHES ... OTHER THAN THAT ... ALL YOU CAN DO IS KEEP THAT DISPENSER FLUSHED OUT WITH HOT WATER AFTER EVERY WASH. JUST POUR HOT WAYER TROUGH IT ... IF THE WATER BACKS UP (EVEN WITH A SLOW POURING) THE DISPENSER IS PLUGGED AND NEEDS TO BE FLUSHED OUT WITH A HOSE. GOOD LUCK AND STAY DRY !!!
Apr 29, 2007 | Whirlpool Calypso GVW9959K Top Load Washer
Primo 900172 1.0 Gallon Industrial Water Dispenser Logo
60 people viewed this question
Top Primo Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Irene Tulloch
Are you a Primo Kitchen Appliances - Other Expert? Answer questions, earn points and help others
