Question about Fisher and Paykel Refrigerators
F&p e249t fridge freezer fridge freezing food
Fridge freezing food
HVACRH20
  • 237 Answers
SOURCE: icemaker is not freezing ice, freezer not freezing food,
The ice maker won't work if the freezer is warmer than 17 degrees so that's not an issue till you get the freezer cold again. I would guess that your unit is stuck in the defrost cycle. This could be the defrost timer failing. See if you can find the defrost timer in your unit and advance it by hand if possible. http://www.partselect.com/PartSearchResults.aspx?modelnum=jcd2295hes&mfgmodelnum=&fkmfgid=1&hint=defrost
Posted on Dec 04, 2006
  • 21 Answers
SOURCE: I have an RL33SBSW fridge
Good day..
I would Double-check the part.. before I did anything else.
I would recheck my model no. just to make sure I was right.... I would want to find out if the part I was sent is the one it is supposed to be... it probably is.... It may seem silly, but it happens more often than it should.
When a Refrigerator doesn't defrost like it should, a common condition would be to hear that some foods in the frig side freezing, why, is because the control which cycles both freezer and frig, is located in the Fresh food side, there is not enough air movement to cycle the thermostat, so it runs all the time. Cold air drops, and usually the freezing occurs down below in the veg. drawers and/or vent ports involving air transfer between the two compartments... as more time passes... ice on evaporator thickens, air flow circulation reduces even more, now conditions begin to reverse.. and exactly what you state above begins to occur... look inside your Freezer, the back wall... you'll see ice (like a snow-cone) forming.. if so... you could have a defective PCB, I doubt it.. 95% probability, it's the bi-metal termination thermostat.. the other 5% would be your def heater. I have found more PCB prone to be at fault under these circumstances then that the thermostat.. I wouldn't toss out that PCB... If you keep this unit for a long time, it will be the likely thing to be needed, in the next round..
Posted on Feb 25, 2008
22yooper
  • 828 Answers
SOURCE: ffa70 hotpoint fridge freezer
Adjust the temperature control for the freezer to a normal setting. Fast freeze is only for when new products are put in that need to be frozen. This locks the system into a continuous run mode and could be responsible for the freezing condition in the refrigerator section. Check the temperatures with a thermometer as the sensor for the freezer temperature could be bad causing the light to come on.
Posted on May 18, 2008
WeListen2You
  • 538 Answers
SOURCE: Hotpoint Fridge freezing the food.
thermostat is buried behind the walls of that unit, are you ready to run this one..takes quite a bit of time..but
will get the item, if you can supply the actual serial number from inside or back of that unit..
Posted on Oct 26, 2008
  • 5 Answers
SOURCE: Freezer not freezing properly, ice on back wall
Ice on the back wall indicates a problem with the defrost cycle. The ice builds up and starts to choke off the air flow, so your symptoms would indicate that may be happening.
Defrost problems are usually any of the three components, the heater element, the defrost termination temp switch, or the defrost timer.
Posted on May 29, 2009
What causes food to freeze in the bottom of the refrigerator & meat & cheese tray
See if there is a temperature setting on the side of the drawer. Mine has a small lever that opens a hole to the freezer to keep that drawer colder. If it's opened too far the food will freeze.
Jul 26, 2014 | Jenn-Air Refrigerators
I have a ffa90 futre fridge & bottom frezzer. the fridge is frezzing the food in the door & in the fridge. have tryed water in botles & they get ice on it .in the door the food frezzers so
Find where the supply air is coming into the fridge part. It comes from the freezer and could easily be supplying -18 air direct to the door. This would give you a 2 in the fridge but anything in the direct air path could freeze.
Sep 07, 2012 | Hotpoint FFA90 Bottom Freezer Refrigerator
Whirlpool 6wmv43ns/02 Fridge Too Cold & Freezing Food
I would first try replacing the control in the fridge. If that doesn't remedy the situation, I would try replacing the thermostat next.
May 14, 2012 | Whirlpool Refrigerators
Fridge is set at 44 ,freezer is -4 and the food is frozen in the fridge. can't get fridge to stop freezing all the food,what temps do I need to set?
There can be many reasons why your refrigerator is freezing your food. To see what could be happening and to figure out how to possibly fix your problem. Take a look at this tip which contains many of the causes and solutions to fix the problems.
Refrigerator is Too Cold and Freezing Food
heatman101
Feb 01, 2011 | LG LRFD22850 Bottom Freezer Refrigerator...
Freezer not freezing food,and fridge not getting cold.
Hi, both compartment of the refrigerator (freezer & fridge) not freezing and getting cold means you have low or empty freon (gas) in the compressor of the refrigerator and you need to refill it as soon as possible.
Take care
Jul 14, 2010 | Frigidaire FRT17G4B Top Freezer...
My daughter's mini fridge has a freezer compartment. Her issue is, if she turns it up high enough so the freezer freezes, the fridge compartment also freezes everything; if she turns it down so that the...
This is a drawback of most mini-fridges. Start by defrosting everything. Then fill ice cube trays with water and keep lowering the setting until the water freezes. Just go a little lower, no more. Fridge should not freeze food. If the fridge stays closed all the time food will freeze. Also if the freezer element gets ice buildup it must be defrosted. Not automatic like home fridge. Most kids today weren't born when the last fridges that had to be defrosted were in service.
Sep 01, 2009 | Refrigerators
Freezer not freezing food and fridge not staying cold enough
Check the compressor with a volt meter, if the compressor is getting proper voltage then check the relay. But this sounds like a problem with the compressor
Feb 12, 2009 | Whirlpool GB9SHKXL Bottom Freezer...
Ffa70 hotpoint fridge freezer
May 18, 2008 | Hotpoint FFA70 Bottom Freezer Refrigerator
Food is freezing
usually there is an adjustment at the back for the difference between the fridge and freezer compartment. Often is just a vane that blocks freezer air, too much air would freeze the food. Normally you set the fridge thermostat for a normal food temp, then adjust the air to keep the food warmer than the freezer.
Jan 28, 2008 | Arctic Air R22CW Refrigerator
Malfunctioning American Fridge Freezer
Is it freezing. Sometimes those led's go out.
Dec 21, 2007 | Freezers
Refrigerators Logo
56 people viewed this question
Top Fisher and Paykel Refrigerators Experts
Brian Coughlan
Charles T Nevin
Charles T Nevin
Are you a Fisher and Paykel Refrigerator Expert? Answer questions, earn points and help others
