Question about KitchenAid KBFS20EVMS 36" french door counter depth refrigerator
Bottom of freezer is freezing and leaking onto the floor
  • 1122 Answers
SOURCE: water inside bottom of freezer after defrost cycle
your freezer drain is either frozen or clogged,remove stuff from bottom of freezer and you should be able to see the drainhole..if frozen use a hair dryer to melt,then to make sure it 's not clogged use a wire hanger to clear it out and you should be ok,let me know-mike
Posted on Oct 31, 2008
Sea Breeze
  • 4654 Answers
SOURCE: cooling sometimes, freezer leaking water when it stops freezing
That is a indication of a deefrost problem. Not sure if your model has circuit board, or defrost timer.I will do some checking on the Kitchenaid type refrigerator but there are many models. So please locate your model number and we will go from there. Look at following areas for the model number
  • Beneath Or Inside Food Compartment On Cabinet Frame
  • On Plate Lower Front Or Rear Of Cabinet
  • Beside Compressor Door On Right End
  • Near Rear Of Cabinet
  • Inside Liner At Top
Posted on Mar 31, 2009
  • 61 Answers
SOURCE: Water collecting in the bottom of freezer.
There's a small drain in the bottom of the freezer compartment. It will clog up from time to time and cause water to pool up, then run wherever it can. So, find that little drain (small hole about the size of a dime or so) and un-clog it. you can do this with hot water and a turkey baster!
Posted on Aug 31, 2009
  • 351 Answers
SOURCE: water is puddling and freezing in bottom of the
drain stop up or frozen up
Posted on Sep 30, 2010
SOURCE: my KitchenAid KBFA25ER Bottom Freezer French Door Refrigerator freezer is leaking water
just had mine repaired it is a duct bill grommet that is clogged. Found out it is common and easy to repair. My part was w10309238. Took the repair man less than 5 min. You need to pull the frig out, unplug take off the bottom pannel mine was bottom right. A small socket screwdriver is key, look for a funnel running top to bottom, in side there is the duct bill nipple that is clogged with debrie or stuck with stickly stuff like juice. Remove and replace then seal up and defrost for 24 hours by opening the freezer door.
Posted on Oct 26, 2012
How do I repair water leaking in the bottom of the freezer on Maytag model MBF2258XEW
Check your door seals. The air gets in, the moisture freezes then the defrost cycle turns it into water.
Sep 14, 2014 | Maytag Refrigerators
Frigidaire FFHS2311LWD has water pooling up and freezing bottom drawer and lower vent. Drain tube doesn't seem to be clogged. Water leaks onto floor some days.
the drain tube is most likely clogged. if the lower vent is freezing up there is no way to confirm because it is covered with ice. the reason water leaks onto the floor is, the refrigerator goes into defrost, frost melts and runs down the ice to the door. use a hair dryer to remove all ice, then use hot water to check drain. drain tube may be up to a foot long and may have a trap. you may have to go in through the back to gain access to the drain
Oct 22, 2013 | Kenmore Freezer 20.3 cu. ft. Frost Free...
Frigidaire Fridge Freezer forms huge iceblock inside fridge back wall. It freezes up whatever is stored in fridge i.e. vegtables, cheese. Water leaks onto the floor from under the vegetable containers. ...
the defrost drain pan is plugged up,you need to defrost it and run a wire down the drain tray hole so it can drain to the bottom as it defrosts otherwise it defrosts and runs everywhere else and re freezes
Jun 05, 2011 | Frigidaire GLRT86TES Top Freezer...
Water leaks into bottom of freezer. it re freezes, and then also
hi there,
there a leak somewhere in there. there is no way you can fix this yourself, call the repairman or LG's customer service.
Jun 07, 2010 | LG LRFD22850 Bottom Freezer Refrigerator...
Freezer drain not working. water accumulates and freezes in bottom of freezer compartment and sometimes will melt/leak onto floor
use hot water and turkey baster . force the water down the drain till it clear's to prevent it from freezing again install drain heater . some model's need them.
Jan 18, 2010 | Refrigerators
Water setteling on bottom of freezer side and freezing also leaking. 2 fridges both doing the same thing . leaking on the inside and freezing and underneath water is leaking.
Clean out the defrost drain. There is a drain in the freezer that lets all the defrost water run under the fridge. If that gets clogged then all the water runs into the freezer and can even leak onto the floor
Sep 13, 2009 | Refrigerators
My freezer has water that leaks into the bottom and freezes but water also leaks out onto the floor
Inside the freezer at the bottom in the back there's a drain hole that must be clogged and the water from every defrost cycle freezes up and make it worse , so first pour hot water into the drain to melt the ice and keep pouring until it goes through .Keep the drain clean doing this every 3 or 4 months.
Aug 10, 2009 | GE Refrigerators
Freezer malfunction
Drain hole is clogged behind the panel that covers the coils. I found a peice of solder blocking mine. Water was freezing on the bottom of the freezer and leaking out to the floor.
Aug 04, 2009 | Maytag MSD2756G Side by Side Refrigerator
Freezer leaking on Ge Profile
The drain is frozen over and water cannot escape when it defrosts. You will need to remove the back panel inside the freezer and run some hot water down the drain until it has thawed. Hope this helps
Sep 24, 2008 | Refrigerators
KitchenAid KBFS20EVMS 36" french door counter depth refrigerator Logo
100 people viewed this question
Top KitchenAid Refrigerators Experts
John Tripp
John Tripp
mike cooper
Todd Arndt
Todd Arndt
Are you a KitchenAid Refrigerator Expert? Answer questions, earn points and help others
