Question about Maytag Neptune MDE5500AY Electric Dryer
What is the CU. FT. of the MD3000 - Maytag Neptune MDE5500AY Electric Dryer
What is the cu ft of the drum
Shirley, you answered your own question.
Kenmore (((((3.8 cu. ft.))))) HE3 Front Load Washer
3.8 cu ft. drum
Feb 21, 2016 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
What is the width od a whirlpool fridge model number ET20DK
Hi Dennis:
Looks like the hermit answered this a while back.
hermit58
  • 33 Answers
SOURCE: can you give me the measurements height width
Depth Cab. Width Door Width Cab. Height Overall Height
Model size "A" "B" "C" "D" "E"
STANDARD MODELS
19 cu.ft. 30 3/4" 29 1/2" 29 3/4" 65 1/2" 66 1/4"
21 cu.ft. 29 3/8" 32 1/2" 32 3/4" 65 1/2" 66 1/4"
22 cu.ft. 30 3/4" 32 1/2" 32 3/4" 65 1/2" 66 1/4"
INTEGRATED MODELS
19 cu.ft. 31 1/2" 29 1/2" 30 1/8" 65 1/2" 66 1/2"
22 cu.ft. 31 1/2" 32 1/2" 33 1/8" 65 1/2" 66 1/2"
ARCHITECT® SERIES MODELS
19 cu.ft. 32 7/8" 29 1/2" 29 3/4" 65 1/2" 66 1/4"
22 cu.ft. 32 7/8" 32 1/2" 32 3/4" 65 1/2" 66 1/4"
Jul 08, 2015 | Whirlpool Refrigerators
Need to know how many cubic feet my frig is so I can compare when shopping for another.
This is the information I could find.
Refrigerator Type Side-by-Side Total Capacity Cu. Ft. 21.7 Cu. Ft. Refrigerator Capacity Cu. Ft. 14.40 Cu. Ft. Freezer Capacity Cu. Ft. 7.30 Cu. Ft. Energy Star® Qualified Yes
for more information try this link.
Whirlpool Appliances for the Home Kitchen and Laundry Room
Bob
Mar 16, 2015 | Whirlpool Refrigerators
If a caton is 18" X 24" x24" how many cubisc feet is it
Quickly the calculation can be done easily in your head. 2 ft x 2 ft x 1.5 ft = 6 cu. ft.
In inches, 18 x 24 x 24 = 10368 cu. in. Divide this by cu. inches in 1 cu. ft (12 x 12 x 12 = 1728) giving you a result of 6 cu. ft.
Sep 26, 2014 | Universal Office Corrugated Kraft Shipping...
What is the wattage of a goldstar ma- 960m microwave
The Goldstar MA-960M (also 961M and 963M) is 850W, 0.9 Cu.ft. The MA-1080M (1081M and 1083M) is 850W, 1.0 Cu.ft; MA-1280M (1281M and 1283M) is 900W, 1.2 Cu.ft; MA-1523M is 900W, 1.5 Cu.ft. Source: Technical Specifications listed in original user manual for MA-960M.
Jan 31, 2014 | Goldstar MA-960M Microwave Oven
MAYTAG FREEZER CAPACITY
I cannot find a MQU8057AEW in the Maytag library. I did find a MQU2056AEW that is 20 cu ft.
May 05, 2010 | Maytag 20 cu. ft. Upright Freezer MQU2056B
Can you give me the measurements height width depth of the KTRC19KK?
STANDARD MODELS
INTEGRATED MODELS
Jul 07, 2009 | Refrigerators
Size of boxes
Wow you are in luck, I used to be an Audiobahn dealer. Designing sub enclosures is my fulltime job. So here you go.-
If you are looking for sound that is very smooth, and has a very low end shaking everything setting off car alarms. You will need a PORTED BOX that is 3 CUBIC FEET FOR EACH SUB WOOFER. It actually calls for 2.7cu.ft but after you add speaker displacement and bracing it should be at least 3 cu.ft. The port can be either round or square made of plastic or 3/4" wood respectively. My port suggestions are dependent on how much space you have. The shortest round port might make some noise (too much pressure!). So think about that first. Anyway the short port is 3" diameter and 15.5" long. The longer port is 4" in diameter and 28.25" long. The rectangular wood port can also be either (port measurements are inside diamensions) 3" w x 3" w x 18.5" long (short port) or 2 w x 10.5 h x 48' long. The second longer wood port is recommended most but will take up a lot of space. The fact that you have to subtract the port volume from the box makes for space issues in cars. Also the second wood port sounds better and won't make much wind noise, but takes up .75 cu.ft worth of space. So in plain english your box will have to have an internal volume of 3.75cu.ft. An example of this could be made of 3/4" thick MDF, have 1" x 1" internal bracing and measure (box dimensions are external and assumes the use of 3/4" MDF) 12" h x 18" w x 30" deep. The port is an integral part of the box fitting inside. I'm sorry I can't provide any drawings to make things easier. Now this box size is one that I ran through a computer program I use. So it is not the same as the manufactures recommendations. I will list those as well.
The second box is an example using a round short port and also uses 3/4" MDF, 1 x 1" bracing, the 3" dia x 15.5" long port, and measures 12" x 18" x 24" externally.
If space is an issue try checking out the information below. -I got it from Audiobahn-
If for some reason it doesn't show up or you need assistance let me know. Good luck and enjoy your new setup-I'm sure you'll be happily disturbing the peace soon!
-Dynami
Model # AW1006T
Ported
Air Space (Cu. Ft.) 0.65
Port Size (Inches) 2 x 6.5
Port Vel. (%) 48.31
-3dB (Hz) 31.5
Tune Freq. (Hz) 40
Sub Disp. (Cu. Ft.) 0.21
Port Disp.(Cu. Ft.) 0.01
Total Vol. (Cu. Ft.) 0.75
Ported
Air Space (Cu. Ft.) 1.4
Port Size (Inches) 3 x 6.75
Port Vel. (%) 24.19
-3dB (Hz) 30
Tune Freq. (Hz) 39
Port Disp.(Cu. Ft.) 0.024
Total Vol. (Cu. Ft.) 1.5
Ported
Air Space (Cu. Ft.) 2.4
Port Size (Inches) 4 x 6.25
Port Vel. (%) 14.39
-3dB (Hz) 29
Tune Freq. (Hz) 39
Port Disp.(Cu. Ft.) 0.04
Total Vol. (Cu. Ft.) 2.5
EBP 74 80 80
Sealed NR NR NR
Minimum (Cu. Ft.) 0.5
Maximum (Cu. Ft.) 1
SPL (dB) 80
All sealed boxes already include the displacment for the subwoofer. NR = (Not Recommended)
Mar 08, 2009 | AudioBahn AW1006T Car Subwoofer
Kitchen Aid Superba Model KSRS22D
Hi-
The Kitchenaid Superba KSRS22D has 14.4 cu.ft. refrigerator space and 7.1 cu.ft. freezer space for a total of 21.5 cu.ft. Hope this helps... -Syren
Jul 02, 2008 | Refrigerators
Maytag Neptune MDE5500AY Electric Dryer Logo
55 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
