Question about Princeton Digital VL1918 Monitor
Looking for the manual for Princeton Digital VL1918 monitor
  • 20 Answers
SOURCE: will Princeton monitor VL1918 support NVIDIA GeForce 6150 SE
Hi Alvie
I Just checked the specs on both the card and the monitor. It should work no problem. If for some reason you notice some lag or flicker in the monitor, go to this page and download the updated ForceWare graphics drivers.
http://www.nvidia.com/object/winxp_169.21_whql.html
Posted on Mar 27, 2008
  • 1684 Answers
SOURCE: I have a Princeton VL1918 LCD monitor. Need help
You have a monitor with a common problem. After a few years some LCD monitors will blow a power supply. The problem is caused by parts called capacitors overheating in the confined space of he monitor. If you are good at electronics repair/soldering you can usually fix he problem. Check out a few pictures on my web site www.ccl-la.com/badcaps.htm You can take the back cover off your monitor and look for the bad parts, replace any that look like the pictues and your monitor should work fine. The capacitors do need to be installed with the correct + and - connections, note the stripe on the old one and insert the new one the same way. If you don't want to try the repair yourself we offer a repair service for $35 plus shipping. If you don't see any bad capacitors then the next thing would be bad CFL (backlight tubes) in the screen itself. If it is that then the monitor needs to be replaced because of the tech skills needed to replace then. I hope this helps, if so please rate my solution.
Buddy
Corporate Computer
www.ccl-la.com
Over 21 years of computer and printer support/repair
Posted on Jun 29, 2009
  • 60 Answers
SOURCE: same problem
Check the Inverter card Connector which goes to pannel,Next Panel to AD card signal Cabble,..
Posted on Jul 10, 2009
SOURCE: princeton vl1918 flashes on than off
See previous solution for Princton Monitor cycling on and off.
Solution: Change out 3 capacitors.
Posted on Aug 19, 2009
  • 732 Answers
SOURCE: My Princeton monitor VL1918 keeps blinking on and
eben161, you might try replacing some "electrolytic filter capacitors" on the "switch-mode-power-supply" printed circuit board. Try to obtain new ones that have temp rating of 105 deg centegrade. remember to replace them + to + and - to - !!! don't screw it up!!! here are some of the values you will need to purchase. 470micro farad (uf) and 2200uf and all should have a voltage rating no lower than 35vdc please report back with the name of the manufacturer you find on the original "failed" ones you remove from the unit. even if they don't look bad (swollen, leaky) replace them all with new one's. If you won't do the work you can also check to see if Princeton can swap you a refurbished unit for your old+cash. But first you should read all the posts that have been written on this model lcd monitor and how they were fixed! I'm 12fixlouie If this response was helpful to you, please rate it on fixya. Bye for now.
Posted on Nov 09, 2009
HOW TO HOOK UP PRINCETON VL1916 MONITOR
You'll get the manual here :
https://www.google.fr/url?sa=t&rct=j&q=&esrc=s&source=web&cd=1&ved=0CCQQFjAA&url=http%3A%2F%2Fsomemanuals.com%2FPRINCETON%2CVL1916-FE%2CDFFHI.PDF&ei=BewCVJy6FeWc0AWMsoCQCQ&usg=AFQjCNF_tw-Zz4qDTUP8Gs9fhVCdaSVSqA&sig2=hzPNSlSA0Noya_Uh88bwpA&bvm=bv.74115972,d.d2s&cad=rja
Aug 24, 2014 | Princeton Digital VL1918 Monitor
Hello I can't get anything on my screen except
Your PC is putting too high resolution for he VL1918 to display.
You need to set your PC video out put to the native resolution of the VL1918, which is 1280x1024 @60Hz.
You will have to hook up your old monitor (crt type?) and set the new resolution.
Or boot up in safe mode (hit f8 during boot up), and set the resolution to 640 x 480, reboot into regular mode, then rest the resolution to 1280x1024 260Hz.
Also watch out for bad caps in this monitor: http://s807.photobucket.com/albums/yy352/budm/Princeton%20VL1918W/
Apr 07, 2010 | Princeton Digital VL1918 Monitor
Need to download drivers for a princeton vl1918 HELP!
open the internet and open the link www.softwaredriverdownload.com/princeton_graphics_vl2018w_driver.html - United States and you can instantly download the drivers
Mar 28, 2010 | Princeton Digital VL1918 Monitor
Princeton vl1918 flashes on than off
Jul 15, 2009 | Princeton Digital VL1918 Monitor
Same problem
Jul 10, 2009 | Princeton Digital VL1918 Monitor
How is the cover removed from the Princeton VL1918
Theres sort of clips that clips to the side of the monitor's frame, use a flat screwdrive to care fully push through the sides of the LCD to unlock the clips.
Nov 15, 2008 | Princeton Digital VL1918 Monitor
Will Princeton monitor VL1918 support NVIDIA GeForce 6150 SE
Hi Alvie
Mar 27, 2008 | Princeton Digital VL1918 Monitor
Princeton monitor
check www.badcaps.net - they have a tutorial on their site for replacing caps, it's for motherboards- but the technique is the same.
I ordered caps for the Princeton Monitor VL1918 from Mouser.com and got their item # 647-UHE1E471MPD6
The 470uf 25v caps size- 10x16 mm
Mar 11, 2008 | Princeton Digital VL1918 Monitor
Princeton Digital VL1918 Monitor Logo
94 people viewed this question
Top Princeton Digital Computers & Internet Experts
Josh Whitehead
Josh Whitehead
William Ward
Level 1 Expert
Daniel Dollive
Daniel Dollive
Are you a Princeton Digital Computer and Internet Expert? Answer questions, earn points and help others
