Question about Hotpoint Refrigerators
Hotpoint HSM25GFRE SA freezer not Cooling. First the Icemaker stop making ice. Next the freezer door and left side of freezer became very warm to the touch
  • 833 Answers
SOURCE: Hotpoint Ice diamond fridge freezer both green & red lights on.?
bulmer...it takes about two days to fully defrost these units unless you take the freezer section cover off and use a heat source. If you do...be sure to protect yourself against water and electricity mixing....not healthy. See below for another note.
clean the condenser coils below the unit.
check for the amount of gas in the unit. It must be off for half an hour. Remove the back fiber panel. The big thing is the compressor. Clean off the largest pipe coming out of it. Plug the unit in...watch out for the fan! The pipe should frost up and then clear off or stay wet after about 5 minutes. It should not be frosty. If it is, you need refrigerant.
Note: If you do remove the inside freezer panel and defrost, you can see how much refrigerant you have in your unit. Start the unit. Wait 5 minutes and observe the coils. They should be evenly frosted end to end. If approximately so, you're good. If not, you're low on gas.
Posted on Dec 18, 2007
SOURCE: area around freezer door is very hot to the touch. ice maker works, but after awhile the ice will melt. freezer is freezing.
http://www.askmehelpdesk.com/other-home-garden/refrigerator-frame-hot-touch-31680.html
Here's a link re the refrigerator symptom you describe.
Posted on May 27, 2009
mgprice
  • 744 Answers
SOURCE: fridge/freezer cooling inefficiently
Either the repair guy did not wire up the heater correctly or he replaced the wrong part, if the heater was good it was likley to be the defrost thermostat...I would call the repair guy back to check.
Posted on Jun 23, 2009
SOURCE: Icemaker does not make ice
Sometimes an icecube gets caught up in the tray causing a 'rattling' noise when it tries to operate and also causing it to not produce ice. Lift up the lid, take out the wedged ice cube and it should start to work again.
Posted on Jul 07, 2009
SOURCE: Hotpoint Ice Maker Stopped Making Ice
hotpoint hss25gfpjww stopped making ice..leaking ?rust from under dispenser..please help
Posted on Sep 07, 2009
Hsm25gfre sa
u need to replace the water inlet value
Apr 06, 2014 | Hotpoint Refrigerators
Have a Hotpoint model HSM25GFRA SA Ice maker stopped did some checking ond found the water solinoid to ice maker was open and replaced it. But still no ice, have removed ice maker, cleaned and defrost
Check to see if there is ice blocking the tube to the icemaker. Sometimes when the valve is giong bad or the icemaker sits too long without making ice the tube will freeze and block up with ice.
Feb 14, 2014 | Hotpoint HSS25GFP Side by Side...
I have a Hot Point HSM25GFRF SA refrigerator, first the ice maker / water stopped working then the the refrigerator started making a clicking noise and every time it clicks the fsn does one rotation then...
I have the exact same problem.
It stopped dispensing water and ice, then it started to make a clicking noise and now the freezer and the refrigerator don't work.
It's interesting that this failure occurred 3 months after the 5 year warranty expiration.
Apr 13, 2010 | Hotpoint Refrigerators
I have a Hotpoint, model # Hsm25gfre sa, that is cooling and freezing unevenly. Everything onthe bottom half of the freezer is frozen and the top half is thawing. Also, the water in the ice maker is not...
Make sure that the freezer fan is working and circulating the cold air. Then check the damper assembly to make sure that cold air is being circulated into the refrigerator. And lastly make sure that the self defroster is working - if not the evaporator will freeze up, freezer temps go up, and ice maker will not work if freezer temps are 10 degrees or higher. A digital refrigerator thermometer will confirm freezer temps being high.
Aug 26, 2017 | Hotpoint HSM25GFRSA
Fridge/freezer cooling inefficiently
Jun 23, 2009 | Hotpoint HSS25IFMCC / HSS25IFMWW Side by...
Icemaker making small amount of ice
I RESET THE SWITCH ON THE ICE MAKER AND TURNED THE TEMP TO 9 FROM 5 AND IT STARTED MAKING MORE ICE. I'M NOT SURE WHAT WAS WRONG BUT IT APPEARS TO WORKING FINE NOW.
Dec 04, 2008 | Hotpoint HSS25IFMCC / HSS25IFMWW Side by...
Icemaker making too much ice & Freezer frosting up.
Hi gpss,
It sounds like you are getting large amounts of warm moist air into the freezer. This can be caused by the door being left cracked open or the door seal not sealing properly. Check your door gaskets on both sides of the refrigerator. One other possible is the ice chute. If it is not closing all the way it will cause the same problem. You will get alot of frost forming in the freezer then it will melt when the refrigerator defrosts. Let me know if this helps, and if you have anymore questions.
Mike
Sep 30, 2008 | GE GSH25JSTSS Stainless Steel Side by Side...
Friend,
ngfam1 At your service!
I came to your service on fixya.com some days ago!
And gave you some good advice!
But, I did not receive a rating from you yet!
Can you please give me a rating at our fixya.com site!
Bless, You ngafm1
PLEASE GIVE ME A GOOD RATING BEFORE YOU SIGN OFF
Jul 04, 2008 | Hotpoint HSS25GFP Side by Side...
Water leaking inside freezer ice maker
sounds like the line was frozen but the water fill indicator is faulty.
Jun 05, 2007 | Hotpoint HSS25GFP Side by Side...
Refrigerators Logo
66 people viewed this question
Top Hotpoint Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Sal De
Are you a Hotpoint Refrigerator Expert? Answer questions, earn points and help others
