Question about IBM ThinkPad R40 2722 Notebook
My pcs quality & display has turned bad after
I got it repaired ,,, there was some kind of problem in the mother board ,, & now its fonts , display , appearance all seems outdated & poor ..!! help me out if any1 can ..!! will it work if i will change software .. i currently have windows xp ,, 2002 !! HELP ME.!!
    Problem Solver:
  • 14 Answers
1. What did the repair shop say about the problem?
2. Have you checked the system settings/system appearance and manager settings, as well as your power saver settings?
3. A reinstallation of your base operating system, after loading your important files elsewhere should reset things to initial conditions.
Posted on Apr 18, 2009
Were is the video card located on my gm5478
If your VGA lead plugs into the motherboard, where the cluster of connectors are, you probably have on board graphics which means essentially it is built onto the mother board and is not physically removeable but if you fit a better quality display board, you can turn the onboard graphics off.
Hope that helps
Jan 23, 2011 | Gateway Computers & Internet
Maytag neptune washer font load will not drain
just had sears here to fix mine for the same problem. $434. the mother board and also they replace the motor at the same time. Motor and board come together in the repair
Jun 25, 2009 | Maytag Neptune Washer
No display on computer
First thing is do you have a beep when the system boots? Sounds like you may have a BIOS issue I would start there........your RAM and processor are more than likely NOT the problem
Apr 15, 2009 | HP Pavillion a818n Desktop PC (Refurb)...
HCL HCM780M CIRCUIT DIAGRAM
SIR..., regarding monitor...display block characteristics which is operated manually by buttons situated bottom of monitor is anytime coming at the centre of monitor display... The settings block comes on suddenly and we are unable to exit from the same sometimes the block goes off without any action and everything is fine till it is back again and it is come again and again.....by all this i did'nt work on my PC...all result it's useles......please sir giving your suggestion as soon as possible....... This has been happening for the last 1 year and is a real pain Please send some solution
Jan 23, 2009 | Computers & Internet
Display settings not working.
fisrt of all you need the mother board cd. put the cd in the cd rom or dvd rom. install the graphics driver. right click in the desk top. selece properties. then go to settings then adjust the screen resolution and colour quality.
Thank you
Jan 21, 2009 | Mercury Electronics KT266A Motherboard
LG32LC2D - Sound slow to start
This is indicative of a bad main board that will need replaced. For this model make sure the repair person has the full product code (from the back of the unit) so that they can get the correct main board ordered (there are multiple versions depending on the product code). Hope this helps.
Jan 05, 2009 | LG 32LC2D Television
I need to reduce the fonts in word processor
With the graphic capability of computers and printers today, there are many fonts to choose from when writing documents.
  • Important category that fonts can be divided into are:
    • Monospaced fonts: Monospaced fonts are fonts in which every character uses the same amount of horizontal space, like this sentence.
    • Proportionally spaced fonts: Proportionally spaced fonts (also called variable pitch fonts) use up only the amount of horizontal space that is required for the letter. Therefore, the letter W would take up more space than the letterI. Standard HTML text font, like this sentence (bad example for those unfortunate lynx users :-), is an example of this kind.
Using these kinds of fonts requires formatting to be done correctly. Aligning text should never be done by using spaces. Since character width varies with proportional fonts, assume that it will never line up correctly using spaces. It is possible that on the screen it looks perfect, but remember that the resolution a monitor provides is not even close to the quality that a laser printer can produce. Even if monospaced fonts are used, spaces should be avoided in the event that the font is changed to a proportional font later. Instead of using spaces, use tab stops, indentation markers, and other features to align text.
  • Fonts can also be divided into:
    • Scaleable: Scaleable fonts, such as the popular TrueType fonts, are rendered by applying a fancy mathematical algorithm to represent each character. This allows the fonts to be used at any point size with uniform quality. These fonts are actually printed as graphics and therefore can be printed on any printer that can support graphics.
    • Printer: Printer fonts are the default fonts that come already installed with the printer.
    • Soft: Other fonts can be used by downloading soft fonts.
If there is the possibility that fonts used in the document are not going to be available on another printer, techniques such as embedding or substituting can be used.
Nov 05, 2008 | Gateway Computers & Internet
Hp pavilion dv2000 notebook will not boot up
hi,
i m in Hong Kong. The stupid HP repair center charged US 90 just for inspection!!!!! They they said the whole motherboard had to be replaced, thts additional US 630 dollars, the thing is just 1.5 yr old. They also said i don get to keep the broken mother board after replacement. This is simply irresponsible, unethical, sleazy and UNJUST!!
Thanks. right now the computer is fixed for US70. when i hv time, i'll open it up and see if i can figure it out how it was fixed. The shop suggested tht the computer wont last too long. This is such bad quality for HP... Sorry, i hv to do the following for other victims to find this easily:
(can some creative netizen bring this to the public light to pressure HP to do the ethical things??)
bad quality HP. hong kong HP pavilion dv2000 series manufacture problem. HP unethical.
Sep 21, 2008 | Computers & Internet
Sound quality
The sound quality built in to most mother boards is not the best quality. It is a compromise. The best solution is to install a high quality sound card in an available slot.
For video quality, it is the same issue when it comes to high quality video.
Before installing the new sound card, uninstall the existing sound drivers and sound software for the built in sound as necessary. You may have to go in to the BIOS set-up and dissable the mother board's built in sound. It is best to consult the instructions for *********** board to know the details for the particular mother board. You should contact the dealer for your computer to have proper details.
Turn off the computer, and disconnect the AC cord. Open the case, and install the new sound card according to the instructions that come with it.
When the computer re-starts, it should tell you that it found new hardware. Go through the installation procedure. There will be drivers and some software and drivers that must be installed.
If you are not used to this type of procedure, it would be best for you to take the computer to a computer service place and have them do the installation for you.
Jerry G.
Sep 13, 2008 | ASUS Intel 845 Chipset P4B (P4B WOA)...
IBM ThinkPad R40 2722 Notebook Logo
Top IBM Computers & Internet Experts
Alun Cox
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
