Question about Kenmore 62602 Electric Dryer
Half of the heating element has continuity, is it a goner?
Half of the heating element has continuity. does it need to be replaced? or is it possibly something else that wont let the dryer heat up?
  • 5 Answers
The heating element is simply a single strand of resistive wire, so saying "half of it has continuity" makes no sense. If half of it only has continuity then that would mean this area in the middle you are calling half must be burned open and it would be bad. If you are accurately stating what you mean. I would set your meter you are using to do a voltage reading, check and see if you have your voltage at the 2 wires connecting to the heating element. If you have full voltage there and its not heating then your element needs to be replaced. If this dryer has a large plug going to the wall you will read roughly 240 volts AC, there. If it has a normal looking plug going to the wall (not likely) then you should be reading roughly 120 volts AC on those 2 wires connecting to the heating element. If it has a large plug going to the wall and you are only reading 120 volts or less on those 2 wires then your problem is somewhere else.
Posted on Mar 11, 2009
  • Rusty Voils
    Rusty Voils Mar 28, 2014
    What if when you take the wires off of the element and test them they have 240volts across them but when you put them on to the element and test them they read 0 volts but 120volts from each leg to ground,but not 240 together when hooked up?
Heating element for model mv2010
It may be just a bad emmbedded thermal fuse gone bad.
Checked and confirm continuity of the heating element first before even thinking about replacing. it. If possible remove the thermal fuse and check its continuity with an ohmeter
Jul 17, 2017 | Cars & Trucks
Tip
Electric dryer will not heat?
If the electric dryer does not heat at all then there are some possibilities that have to be checked to confirm the fault.
1)check whether you are getting power to the dryer from electric out let to which the dryer is connected. The power problem can also occur if the fuse is blown or the circuit breaker is got tripped.
2) Other possibility for dryer not heating is the blown thermal fuse. The thermal fuse is located to the exhaust duct inside the back cover panel. This fuse blows out if the dryer gets overheated or any short circuit occurs in the house when dryer is in working.
3) The other possibility if the power is ok and if the thermal fuse is ok. Then the problem can be due to fault in the heating element. The heating element looks like a long coil of special wire. You can check heating elements continuity with an ohm meter. If there is no continuity that means the element is bad and you need to replace it. The heating elements cannot be repaired it should be replaced if faulty.
4) But if all the above mentioned possibilities checks out OK, and still the same problem, then there is a fault in the wiring. Check the main power cord of the dryer which you connect in the electric out let. If the power wire is got internally burned out or got cut in between the dryer will not get proper power and will not work Due to partial power.
This will help. Thanks.
on Mar 23, 2010 | Dryers
Dryer won't come on. Wire block burned. Wires test good. Heating coil lookes burned
A good heating element should have continuity. When the heating element breaks, there is no continuity between the heater terminals. But sometimes, the broken ends of the heating element can make contact with the metal heater housing (from vibration) and draw a large current, causing the symptoms you have described.
To confirm a "short" between the heating element and the heater housing, check for continuity between the housing and each heater terminal. (The shorted part of the heating element is usually welded to the housing.) Occasionally, the short will not be welded, but a visual inspection will verify (welding scars and black soot) that a short has occurred, intermittantly.
Replace the terminal block, heater, damaged internal wiring, and possibly the thermal fuse, thermostats, and power cord.
Good luck
Mar 06, 2017 | Dryers
Ge medallion 850 new elements and thermostats still not heating up
see this possible causes:
1) You must shure the heating element show continuity see the video>
2) Test for continuity the thermosta see the video how to do it
3)TEST THE thermal fuse, for open and replace.
4) Test any WIRES for loose, or broken or burn and repair.
5) If anything is o.k see the diagram. You must test the contact from the a) Timer for open, or dirty, or wires loose, broken or burn b) Test the selector temperatur for defective in order to get the heating element to work, and replace if necessary. God bless you
Jun 09, 2012 | Dryers
Wall oven bake element split
Was there a burning smell before at the time when it heated up slowly?A burning smell suggests there was a (possibly continuous) spark at the splitted place.If it was split earlier then the slower warming up was possibly due to a continuous spark, because then there won't be much energy left for heating.It's like an added resistance.So it could've been there for a while already.
The element just needs to connect again where it splitted and should stay there, then it should work again.
Jan 22, 2012 | Dryers
My maytag neptune dryer is not drying/ what do I do first
to check the element you need a continuity test this test insures there aren't any breaks in the heating element that you can't see. If there is continuity then you possible could have a hi limit switch (this looks like a small round button about the size of a dime, located in the housing holding your element) burnt out. If the element is burnt out there will be no continuity on the element. If there is continuity then take the hi lmit swithch out and replace it. Take the model and serial numbers to an appliance parts store for replacement. Good Luck
Dave
Jul 21, 2009 | Maytag Neptune MDE5500AY Electric Dryer
Hot water lasts half the time
How old is the heater?
It may be something as simple as just needing to flush the tank to remove any sedemints....and hopefully so because this is the easiest/cheapest thing to do.
If this is not the case go ahead and remove the heating elements and check for wear. Replace them if necessary. I would also replace the thermostats that accompany each of the elements.
Checking and replacing both of this requires you to drain the tank completely and should be close to $25 total....last time I checked.
Apr 27, 2009 | General Electric Water Heaters
Wirlpool dryer heating poorly
Make sure you have got it set to full heat and not half heat, you may have a faulty heat selector switch.
Dec 09, 2008 | Dryers
Gas dryer
Welcome jessegonzales
Check the outside vent leaving your house does not have a screen on it.
Take the screen off. Even half blocked and the dryer will not dry well.
Possible solutions
1. Defective Heating Element
The heat produced from heating elements is measured in watts and a normal heating element will produce about 4500 watts of heat. If the heat element is shorted to the case, this will cause the heating element to operate on 110v and use only about 1/2 of the element wire. In effect, the heat produced will be only about 1/4 of the amount that should be produced and the end result is an increased drying time.
The normal method for checking a heating element is to check it continuity. With the element unplugged you can check the continuity from one wire post to the next. If the circuit is open, thent he heating element is faulty.
However keep in mind that the element could be shorted to the case as described above. In this situation it is possible to have continuity, but the element still be the source of the problem.
Let me know.
Please remember to leave a rating
2. Defective Heating ElementThe heat produced from heating elements is measured in watts and a normal heating element will produce about 4500 watts of heat. If the heat element is shorted to the case, this will cause the heating element to operate on 110v and use only about 1/2 of the element wire. In effect, the heat produced will be only about 1/4 of the amount that should be produced and the end result is an increased drying time.
the heating element is faulty.
3.Defective Thermostat
The thermostats are responsible for maintaining the proper temperature in the dryer. Check the exhaust temperature of the dyer and if the temperature is above 150 degrees, you will most likely need to change the operating thermostat.
The thermostat can also fail in the opposite mode. It can prevent the element from heating at all. A failed continuity check at room temperature will verify this condition.
There are some special thermostats that are single pole double throw. These thermostats are often used to control the timer when set to the Automatic Dry cycle. If the dryer timer will advance in the Timed Dry cycle but not the Automatic Dry cycle, then the thermostat could be the problem.
4. Defective Gas Valve Coil (Gas Dryer Only)
If the gas dryer will light once but will not relight until it cools down, it is likely the gas valve coils are faulty. These coils loose some strength when subjected to heat. When they become old, the addition of heat may be enough to prevent them from opening the gas valve when hot. However the coils still work when when cool.
An easy way to diagnose the coils when the burner is not lighting, watch the ignitor. If the the ignitor glows for 10 to 15 seconds but no flame is created, then the coils are faulty. If the ignitor is not glowing the problem is elsewhere.
Recent Customer Symptoms:
The dryer burner doesn't always come on when starting. If the burner does come on, once it goes off if won't come on again until the dryer cools down.
One of these will solve the problem!
Thank You
Huuum.
Jul 29, 2008 | Frigidaire FGQ332ES Gas Dryer
Kenmore 62602 Electric Dryer Logo
78 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
