Question about Stevens Pumps Stevens S5310 Submersible Sump Pump
Pump stopped working
Stopped working after days of rain, backup pump came on
08 town and country backup camera not working...
Since the trouble happened in heavy rain conditions I would suspect water induced conductivity in the wiring to and from the backup camera.
You will need to
1..get a shop manual for the car which details the location of the cable, plugs etc. to and from the camera.
2. Since the camera is located in the rear of the car I would look in the area where water spray from the highway may splatter into the wiring harness and ground connections to the camera.
3. I haven't done one of your year model yet so I can't tell you the exact location of the pieces.
4. Check with your local service manager for the brand and see if there is some news on troubles with this module in other cars
Good luck. It was the moisture and unsealed connections that broke it.
Jan 14, 2015 | 2008 Chrysler Town & Country
Stops working after rain
rain affected on wiring or electronic pcb. otherwise check up sensors
Nov 11, 2013 | LG LSN122HE / LSU122HE - 11,500 BTU 13...
Gmc savana gaz gauge dead but pump work
check all wire connections for water / moisture problems as it is stopping the current from activating all the electrical items
Nov 10, 2013 | GMC Savana Cars & Trucks
My wife and I were headed on vacation and got caught in a rain storm for a good part of the day. The next day was better, but we got caught in rain again. We thought luck was on our side when we finally...
Hi, Paul some bikes can handle moisture better than others depending on age and 99% of the ones that don't start after getting wet just need a little time to dry out then they are good to go. WD40 works wonders when sprayed in critical electronic areas, ie. coils, spark plugs, safety switches etc.
For more information about your question and valuable "FREE" downloads that you will need please click on the blue links below. Good luck and have a wonderful day.
Bike won start after transporting in rain GL1500 Information Questions...
Bike won start after the rain ninjette org
Honda Magna VF750C Service Manual
http://www.partsfish.com/page/oem-parts-for-honda
Honda VF750C Owner Manual
May 22, 2017 | 1995 Honda VF 750 C Magna
How to wire hunter rain clik rain sensor to r8816p101c
1) There are different rain clik model numbers shown in manual
Open 24 volt Rain clik manual:
http://www.hunterindustries.com/resources/pdfs/instructions/domestic/lit358w.pdf
http://waterheatertimer.org/pdf/Hunter-rain-clik-instruction-manual.pdf
2) The rain sensor has two wires.
And two additional wires are needed to run from rain sensor to sprinkler timer. For example, buy thermostat wire from local hardware store if wire is not supplied.
3) The rain sensor has a terminal block where wires are connected. .
Open manual above to identify markings on your terminal block.
For example Figure 1 shows SRC model, and with this model number, the rain sensor wires connect to terminals RS and C, and then two wires going to timer connect to terminals RS and and 1.
4) R8816P101C is 208-240Volt 24-hour irrigation timer.
Timer has two separate terminals for attaching rain sensor.
5) Timer power connections have 4 terminals. Do not connect rain sensor to power terminals.
Connect wires from sensor to the two sensor terminals.
6) Timer slide-switch must be set to ON position for rain sensor operation.
Sensor sends continuous 24Volts to irrigation timer.
When it rains, the rain sensor stops sending 24Volts to timer. Timer responds by not turning on power to irrigation pump.
To by-pass rain sensor, move timer slide-switch to off position.
7) Open following link for Intermatic replacement parts:
http://waterheatertimer.org/Intermatic-trippers-and-parts.html#sprinkler
8) Take a moment and rate answer:
And take advantage of fixya expert assistance live.
For a price, expert works with you while you work on timer or any do-it-yourself project.
Fixya is always less expensive than a service call.
Sep 05, 2011 | Intermatic R8816P101C -...
No spark
Yes replace your fuel pump relay,first
Jun 07, 2009 | 1991 Volvo 740
1999 Escalade won't start after sitting in rain
What engine? 5.7? If yes, replace the distributor cap.
Apr 06, 2009 | 1999 Cadillac Escalade
My 99 Suburban is intermittently starting.....
Unfortunately the fuel pump can still be bad. The pump has a check valve on it that wears out. The pump will continue to run but, struggles to supply enough fuel to start the engine. You can buy a fuel pressure test gauge from Auto Zone or that type of auto parts store and check the pressure. You can purchase a fuel pump from them too.
Dec 27, 2008 | 1999 GMC Suburban
99 chevy suburban intermittenly not starting....fuel pump is runn
Stevens Pumps Stevens S5310 Submersible Sump Pump Logo
Top Stevens Pumps Plumbing Experts
Donni Steen
Tom Chichester
Are you a Stevens Pumps Plumbing Expert? Answer questions, earn points and help others
