Question about Jensen LXA400 Car Audio Amplifier
Amp fuse what size fuse does it use
What size fuse do you need for a Legacy Sapphire LA-695 4 channel amp?Doesn't say fuse size on the amp
Is there a 20 or 30 amp fuse plugged in to the amp near where the 12 volt connection is?
Usually, if an amp blows a fuse: something caused it.
You must remove that cause, before you replace the fuse or it will just pop another one
Mar 03, 2018 | Legacy Car Audio & Video
Jandy Lite 2 LJ pool heater FL4 Fuse amp size
if blown they are 220 volt 3 amp you can also remove them
May 20, 2015 | Jandy Pool & Spa
What is the difference between a ATC fuse and a ATM fuse ?
ATC Fuse
  • ATC fuses were created before ATM fuses. An ATC fuse will be larger than an ATM fuse in physical size. This is considered to be the regular size. An ATC fuse will be found in late-model electronic devices.
ATM Fuse
  • An ATM fuse is considered to be a mini fuse and it came out in the early 1990s. The only difference is it is smaller than an ATC fuse in actual size. It generally cannot be used in a fuse block that is made for an ATC fuse, as it will not fit in properly.
Apr 24, 2015 | 2002 Mazda Protege
Find out what size fuse for my Peugeot partner van
the amp size of the fuse is on the fuse. when you take it out look at it and you will see the number. some of them are on the fuse by the fuse itself.
Mar 02, 2015 | 2006 Peugeot 405
Is it ok to put a 15 amp fuse on a 10 amp starter fuse for a 2004 grand am
You should never increase the size of the fuse in anything because you can potentially cause a fire. Are you sure the original fuse was 10 amps? It sounds like if it is for a starter the fuse size should be substantially larger. Check the fuse panel just to make sure that the original was only 10 amps
Dec 16, 2014 | 2004 Pontiac Grand Am
Location of fuse box
There is no way on earth to answer your question without knowing what year, make and model vehicle you are asking about. Also, You ask what size fuse. There are many size fuses. Are you asking about interior lights, signal lights, tail lights, stereo, a/c or what?
Nov 08, 2014 | Cars & Trucks
IZE FUSES GO INTO A BALLY STRIKES AND SPARES PINBALL MACHINE
There are several fuses. All are 3AG size. On the Rectifier board you need:
F1=10 Amp 32V
F2=3/4 AMP, 250V SLO-BLOW
F3=4 Amp, 32V
F4=5 Amp, 32V
F5=20 Amp, 32V
F6=3 Amp, 32V SLO-BLOW
On the solenoid driver board you need:
F1=3/16 Amp
Nov 01, 2014 | Video Game Consoles & Games
What size glass fuse do i need to relace one in my warfedale 5000 amp
more than likely its a 30 amp fuse but if you look at the old fuse it should tell you the fuse size
Sep 19, 2014 | Audio Players & Recorders
I'm hooking up my connex4600 turbo to batteries
The fuse size will protect the wiring depending on its size but the question is what amperage does the system draw/use and therefore what size wire is needed and the fuse will be the size of the system amperage draw and the wire size also determined by the amperage draw because if the amperage draw exceeds the capacity of the wire the wire will melt so the fuse should project the wire by cutting the current flow when it exceeds the wire siaze but the system needs the cureetn flow, amperage it is designed to use.
Sep 08, 2014 | Car Audio & Video
What causes back up light fuse to blow when replaced with a new one
the fuse is the wrong size or the manuals suggested fuse is not the correct size. Try replacing the fuse with one size larger . xoxo
Jun 29, 2013 | 2007 Ford Expedition
Jensen LXA400 Car Audio Amplifier Logo
20 people viewed this question
Top Jensen Car Audio & Video Experts
xxxxxx xxx
Are you a Jensen Car Audio and Video Expert? Answer questions, earn points and help others
