Question about Miele H398BP2 / H398B2 Electric Double Oven
Miele h606 timer - Miele H398BP2 / H398B2 Electric Double Oven
My Miele oven has a constant alarm going off every time I try to turn it on, it won't let me set the temperature
Oven keeps beeping:
As there is no reprogramming of most control boards try this, disconnect the power and wait 30 seconds and then reconnecting the power.
If it's an "F1" fault code this generally implies an electronic oven control (EOC) failure. Disconnect the power, wait 30 seconds or longer and then reapply power. If "F1" returns upon power-up, replace the electronic oven control.
The oven control can be accessed and replaced from the rear of the control panel.
NOTE:Disconnect the power cord from the power source before removing the panel from behind the console.
If its an F2 ERROR CODE, The F2 error indicates an open circuit in the oven temperature probe.
Your range has a resettable thermostat in series with the oven temperature probe. If this thermostat opens the clock will display F2 and the oven won't heat.
You can reset the thermostat by pushing in the reset button on top of the thermostat.
Some ovens have an alarm that will beep continuously every six seconds to alert you that the oven is still on. Usually, a kitchen timer that you have set will cause the beeping, but occasionally it can be an error with the oven's settings. If it is the kitchen timer, you can simply push the "Kitchen Timer On/Off" button to end the continuous beeping. If that does not stop the beeping, it is probably beeping due to an error. You can turn the continuous beeping off but you may still need to troubleshoot the issue that is causing the beeping noise.
Read more :http://www.ehow.com/how_12086370_ge-oven-stop-beeping.html
Nov 30, 2016 | Miele Ovens
How do I set the clock on the Miele oven?
I don't believe this model has a clock feature - just cooking timer. I checked through the operation manual and did not find any indication of a clock function. The manual is available here:
http://www.mieleusa.com/manuals_pdf/Residential/Ovens/H350-2_us.pdf
Mar 15, 2011 | Miele Novotronic H350-2B Electric Single...
Information for Miele oven DeLuxe H618 and timer. Thank you.
I have found the manual in German :
<a href="http://www.manuals.help/document_order_init.php?search=MIELE%20H%20618&doctype=1&lang=de">Miele H 618 Bedienungsanleitung</a>
Sep 21, 2010 | Miele H326-3 B Electric Single Oven
Manual for miele H373-2b
Here is the link to download a free owner's manual. It is the 7th item on the list. Once you download it on your computer, then you can print it up.
http://www.miele.ca/miele/canada/OperatingInstructions/manuals.asp?ParFolder=Ovens&SubFolder=Previous+models
May 16, 2010 | Miele Novotronic H373-2B Electric Single...
Water in oven's timer
Turn the power off at your house breaker, and let it dry out for a few days before you turn the power back on . If there is still a problem, you will have to have a technician repair or replace the part. Good Luck, Appliance Specialists
Jan 19, 2010 | Ovens
Replacement Door Hinges Miele Oven
hi the only place to purchase Miele spare parts is through Miele directly or from a Miele authorised service agent
Jun 14, 2009 | Miele DG 4080 Stainless Steel Electric...
Double oven will not switch on hotpoint ew91
Press 2 buttons at the same time on the the left of the the timer unit, and then press one otjher button on right of timer unit, this should bring it off auto setting.
Dec 25, 2008 | Miele Novotronic H350-2B Electric Single...
How to set clock and timer
reset clock, set clock on the right time by clicking + & -
Dec 30, 2007 | Miele Novotronic H350-2B Electric Single...
Miele H398BP2 / H398B2 Electric Double Oven Logo
71 people viewed this question
Top Miele Ovens Experts
Paul Bade
Dan Webster
Dan Webster
John
Are you a Miele Oven Expert? Answer questions, earn points and help others
