Question about Garden
HONDA HRR216VXA LAWNMOWER-CABURETOR & CHOKE ADJUSTMENTS
3 Suggested Answers
kel1guy2002
  • 3740 Answers
SOURCE: lawnmower w/auto-choke stops when choke closes
Hi an welcome to FixYa. I am Kelly.
What has happened is that when the system cavitated the engine drew debris into the Jet orifice in bottom of the carb. You will have to remove the float bowl by removing the 4 mounting scres and the bowl nut.
Once you have the bowl off the Jet / Orifice is located in the very bottom of the carb. It will be recessed about 3/8 inch inside the ventrui. It is BRASS. It can be removed with a flat bladed screwdriver. When you get the jet out hold it up to the light. You should see a pinhole in it. No light.. JET is clogged. Just clean it and reinstall it.
After you have cleaned the jet... take a l;ook at the bowl nut. There are 2 holes in the side of the nut assy that must also be clear. Before you re-install the float bowl turn on the gas and gently lift the float \ensuring that fuel flow stops. Then as you let the float down it should pass fuel. If you do not have feul flow at this point then check the gas tank outlet for obstructions. Once you have established fuel flow reinstall the float bowl, nut and mounting screws.
It should work just fine after this.
A word to the wise.... DO NOT disconnect any linkages unless you have to...! Take a digital picture of the link connections BEFORE you remove them. Thrust me you will be glad you did!
Thanks for using FixYa,
Kelly
Posted on Apr 10, 2010
kel1guy2002
  • 3740 Answers
SOURCE: Honda HRR216TDA lawnmower--Carburetor adjustment
Hi and welcome to FixYa. I am Kelly.
Have you removed the air cleaner and briefly tested the engine to see if the problem persists? Air cleaner is usually on the left front corner of the engine as you stand behind the mower. A dirty air cleaner will cause the exact same symptom you describe. A sticking or not disengaging choke will also cause the symtom you described.
Ok having said all of that.... Your carb item 34 this link: http://www.lawnmowerpros.com/Honda/Honda-GXV160-Engine-Parts-Diagram.asp
can be cleaned by you.
Before you start.... if you have a digital camera take "close up" PICTURES of the linkages and springs attaching to the carb. If this is your first time you will be so glad you did. You can always delete them later if you don't need them. :)
Here is what you need to do:
1. Fuel selector off
2. Remove float bowl mounting screws and nut
3. Remove the BRASS Jet / Orifice in the very bottom of the venturi tube inside the pickup tube. (Flat blade screwdriver) Hold the Orifice up to the light. You should see a pinhole. If it is not clear clean the orifice but do not force anything through the hole.
4. Underneath the Orifice there is yet another BRASS tube that you need to remove. (Flat blade screwdriver) Make sure all of the holes in the tube are clear. The tube will be over 2 inches long. Clean it and reinstall it.
5. Reinstall the Orifice.
6. Using a catch fuel container turn on the fuel selector. Fuel should flow at a good rate. GENTLY lift the float assy level and make sure fuel flow shuts off. When you drop the float again fuel should flow.
If you do not have fuel flow at this point the needle and seat will need to be inspected. Fuel selector OFF.
(The following procedure is to be done only if there is no fuel flow with fuel selector on.)
a. Remove the silver float pivot pin retaining screw
b. Drop the Float down (The needle will come off with the float. NOTE the position)
c. Inspect the tapered rubber of the needle If should be pointed. If it is not pointed then the rubber tip is stuck inside the seat.
d. Clean the seat hole ONLY if obstructed. (Easily damaged)
e. FUEL Selector on then off fuel should rapidly flow through the needle seat.
f. Renistall Float and needle making sure to get the pivot / hinge pin installed correctly and reinstall the silver retaining screw.
g. Fuel selector ON. Raise and lower float checking for free movement with fuel flow when lowered and stopped when the float is raised level.
7. If there still is no fuel flow at this point remove the fuel hose from the carb and check fuel flow. If no flow check that gas tank exit hole, fuel filter (if installed) and the selector valve assy for obstructions.
Reassemble connections.
FUEL FLOW IS GOOD
8. BEFORE you install the float bowl inspect the bowl nut. There are 2 holes in the side of the nut where it screws in to the bottom of the carb that must be clear.
9. Install Float bowl mounting screws and nut. Check for leaks.
10. Test engine.
That should do it. (carb cleaning 101)
Thanks for using FixYa.
Kelly
Posted on Apr 20, 2010
Can u send me the Honda gcv 160 cc and 21 lawnmower engine start video step by step in my mail id
1 - make sure ignition switch is on
2 - make sure that gas switch to motor is in "on" position
3 - Set choke to start position
4 - fill with gas
5 - Pull on starter till starts then push choke back in.
Jun 10, 2017 | Honda Garden
Automatic choke wont engage
check to see if the return springs are still attached to the stationary post and the choke lever.
Jul 19, 2014 | Honda HRX217VKA Lawnmower
Etesia lawnmower
Check to see if choke is closing and opening properly, if yes, adjust the carburetor as it appears you are not getting enough fuel flow with the amount of air intake.
Jun 07, 2013 | Garden
I have an old Honda Harmony HRM-215 lawnmower. The first time I used it this year it worked fine, now I have to leave the choke on fully just to get it to run. Even after an hour of running, choke must be...
The air filter may be dirty, have a look at these tips for troubleshooting lawnmower startup problems:
http://www.fixya.com/support/r9118692-lawnmower_not_starting
May 25, 2011 | Honda Garden
I have a MTD Honda Lawnmower that is having idling trouble. It starts great, but once the chock has disengaged itself the engine surges. If I continue to hold the choke on just a little, it runs just...
Generally this indicates a "lean" condition in the carburetor and there are no adjustments. Depending on your abilities, the best fix is to remove the carburetor and clean all the metering passages/jets. In some cases you are better off just replacing the carburetor. I have seen some Honda carbs. as low as $15-$20. Hope this helps to some degree.
Mar 08, 2011 | Mtd 22" Yard Machine Push Mower
I can't start my honda lawnmower, checked the oil, put new gas use choke,it gives litle sound but not enough to start
Try a touch of starting fluid right into the carburator by taking the air filter off. If it then starts but wont run or stay running, the reservoir below the carb should be removed to clean at and the pinhole in the intake tube above the bowl nut. This is the most common problem with lawnmower start problems, the pinhole can be unplugged with one wire from a wire brush. Be careful with the gas, at least pinch off the gas hose with a vise grips while removing the carb bowl.. Never use a droplight around gasoline. most lawnmowers have no mixture adjustments, so it is a matter of cleaning the carb, tank, gas lines. Some oils in gas mix systems settle and clog after less than one season. Spark can be tested by sight, remove the plug and use a clip-on ground wire from spark plug body to metal on the engine with the plug wire connected.
Jun 10, 2010 | Honda Gxv160 55hp 55 Hp 25mm Dia Lawn...
I have a Honda GCV 160 LAWNMOWER IT WILL ONLY RUN WHEN FULLY CHOKED
BEFORE you go thru all of the advice and look at most other Honda web info.....go and buy a brand new spark plug and start with that! It appears Honda used a NGK spark plug in the past that fails after some time....giving the syptoms of problems with the carb, runs for 10-30 seconds, sticky valve, etc. Do not try to clean and use the old spark plug!! Check this out....it was the answer I was looking for after hours of work, reading, and talking to Honda dealers ---- http://forum.doityourself.com/outdoor-power-equipment-small-engines/261743-honda-lawnmower-starting-then-cutting-out.html
Mar 31, 2010 | Husqvarna 160 CC Honda OHC Engine 21 in
Not getting gas to my caburetor on my riding lawnmower
If you have an overhead valve engine I suggest you remove thevalve cover and check your pushrods to see if they are bent or out of adjustment, They should be gapped at .005 top dead center
Nov 17, 2009 | Toro Lawn Mower With Toro Power Tools
My honda HRR216VXA will not work.
Hi there are 3 model transmissions and looks like assy only i would check the belt first you can check it out at this web site called pats small engines.
Jun 06, 2009 | Garden
Garden Logo
110 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
