Question about Welding Tools
What is correct pressure setting for cutting torch with Harris tip 6290-2
2 Suggested Answers
  • 13 Answers
SOURCE: safety light flases on a lincoln pro-cut 80 and mashine wont work
sounds like the torch tip is not tight.with a hypertherm you have to turn of the machine to reset .
Posted on Jan 06, 2009
Cooker wiring diagram
Sounds more like the orifice needs cleaned instead of the wiring. It's getting fuel but obstruction slows fuel delivery and it cuts out, meaning the tip needs cleaned. Take the tip off and clean it with a set of torch tip cleaners from a place that sells torches, like "Keen".
Aug 31, 2014 | Kitchen Ranges
Torch doesn't have correct flame
Without knowing the specific torch tip you're working with and what you're welding/soldering the only thing any one can suggest is cleaning the tip. You can get welding tip cleaning files any where that sells welding supplies.
Dec 23, 2013 | BernzOmatic Welding Tools
What do i have to do to convert a n acetylene torch to use propane?
usually I have just changed to the appropriate brand of propane tip for that style torch IE: if you use a victor torch take out the acetylene tip and replace it with a propane one making certaing the seats are correct.
Mar 27, 2011 | Victor ® 000TE Replaceable Tip End ®...
Only cuts for 3 seconds, device still on
Possibly an internal short in the torch tip... the expendable components failing in the tip will cause the sensors in the machine to register a "no cut" or "free air arc" state and kill the power to the tip to prevent damage to the unit. Replace the tip components and double check the grounds connections.
Apr 03, 2010 | Hobart Airforce 250ci Light Weight Plasma...
No power to the cutting torch when the trigger is pressed
check to make sure all torch parts are in good shape and is put in correctly
Mar 11, 2009 | Welding Tools
Safety light flases on a lincoln pro-cut 80 and mashine wont work
Nov 26, 2008 | Lincoln Pro Cut 55
Thermal dynamics cutmaster 50 2004 yr.
Check contacts in tip and be sure it is all lubed correctly. If you have good air pressure and flow it should arc after pulling the trigger for about 2-3 seconds.
Sep 27, 2008 | Welding Tools
Welding Tools Logo
Top Welding Tools Experts
Bill Boyd
Are you a Welding Tool Expert? Answer questions, earn points and help others
