Question about Dell Dimension 4500 PC Desktop
When I boot from a boot disk I am unable to change to another drive tells me each drivce is invalid. Also unable to boot from cd. I have 1) a drive (uncheck or check to turn off or on) 2)hard drive same chcek and 3)cd rom. When I uncheck the first two I still can not boot from a cd.
  • kaytee77 Mar 12, 2009
    When I boot all the way to desktop all drives work and I can see and read them. Just have a problem at A prompt. Not even able to read or change to C drive. I will check cables just in case. I do have two cds so I will disconnect one.
    Novelist:
  • 148 Answers
Check the cabling between the drives. Make sure the BIOS sees your drives. Try swapping the ribbon cables between the drives and the motherboard. If you have to, disconnect each device and test them one at a time. This process should isolate the problem device. Make sure that the drives' jumper settings are correct, too (per cable if two devices, one master and one slave, or both devices set to cable select).
Posted on Mar 11, 2009
Invalid system disk
The computer TRIED and FAILED to boot from the hard-disk, and now is expecting you to insert a "bootable" CD-ROM into the optical drive. Replace the "dead" hard-disk.
Dec 01, 2013 | Compaq Computers & Internet
I am tring to format my hard drive but when I try to load windows but it will not go to my dvd rom when I turn it on it says invalid disk
you need to set your bios to boot from CD/DVD first.
turn on your computer and hold either the f2 or del key to get to the bios.
then look at the settings for a option to change the boot drive order
make CD/DVD rom first then hard drive second.
Mar 31, 2011 | Samsung (SP1203N) 120 GB Hard Drive
Dear expert! I m having the system P4 Desktop.I am having the error invalid disk error and it is not booting with os.Please help in this regards. With regards Abhishek
This can happen for several reasons:
1. Your hard disk is fried.
2. You have BIOS configured so that you can boot from other devices instead of Hard Disk, like USB, CD, other hard disk.
Please remove all USB devices that are plugged in and any discs from your DVD, CD drive and try again. If the problem persists, you'll need to buy another Hard Drive.
Feb 23, 2011 | Computers & Internet
Ibm deskstar model dtla-307015 invalid system
For some reason, the computer isn't able to read the hard drive and Windows isn't being found. If this computer has a floppy disk drive, make sure there's no disk in it. (Some people still use floppies, and the normal setting for systems with floppy drives is to try booting from that drive first. You may have a disk in it that isn't bootable.) Other possible causes are hard drive failure, a virus or other malware program has damaged the drives boot sector, or a motherboard problem. The most likely cause would be the hard drive; as a mechanical device they are more prone to fail than other parts.
Mar 08, 2010 | IBM NetVista M42 PC Desktop
Formatting problems.
Remove any 3.5" diskette from the diskette-drive in the computer.
Insert the Recovery Disk into the CD-ROM device.
Restart your computer, and *FORCE* it to *FIRST* try to "boot" from the CD-ROM drive, rather than trying to boot from the 3.5" diskette or from your C: drive.
Nov 26, 2009 | Toshiba Satellite A75-S226 Notebook
IBM THINK PAD 390X LAP TOP INVALID SYSTEM DISK
check that you have no floppy disks in the drive and also no usb memory sticks/Hard drives plugged in as if they are and are not bootable you will get the error you describe
Dec 11, 2008 | IBM ThinkPad T40 2373 Notebook
Cd/dvd problem on toshiba m45-S165 laptop
Is you new hard drive lager than you old on and was the disk drive a factory replacement cause with those disks if you even change just that they will not work
Dec 09, 2008 | Toshiba Satellite A45-S250 Notebook
Booting error
What I would do is take the hard drive (1) out of that machine and put into an another pc - xp would be fine. Now go to the root of harddrive (1) and edit the boot.ini file. you will see an entry similar to this ......
[boot loader]
timeout=30
default=multi(0)disk(0)rdisk(0)partition(1)\WINDOWS
[operating systems]
multi(0)disk(0)rdisk(0)partition(1)\WINDOWS="Microsoft Windows XP Professional" /FASTDETECT
All you need to do is make sure you know which disk you're using (c drive is 0 usually) and the partition should be set to 1 for regular installations.
Did you add any drives lately? or make any changes to your OS?
Jun 14, 2008 | Microsoft Windows Server Standard 2003 for...
Invalid system disk--dell latitude 6600
A few possibilties on this:
1. Check to make sure both the floppy and CD drive do not have any media in it.
2. This is a used computer and its hard drive was erased to protect old info from being seen. If this is true, you will need to get an operating cd disk (ie. windows XP, windows vista, etc) and boot up from that drive. Follow the instructions from there.
3. Hard drive has failed and needs to be replaced.
Apr 27, 2008 | Computers & Internet
Unable to reformat tablet pc with targus external drive
Can you get into the bios, and change the boot order, make the CD Drive the first boot device. Make sure your CD is a bootable CD.
Mar 19, 2008 | Computers & Internet
Dell Dimension 4500 PC Desktop Logo
56 people viewed this question
Alun Cox
