Question about Tview D65TSG 6.2" In-Dash Navigation
My settings is saying i need a password what is it
How do I remove a bios boot password off my Toshiba c55 laptop
Almost all motherboards use a small coin sized CMOS battery to store all BIOS settings along with the password.
To reset the password, remove the battery, open the cabinet and remove the CMOS battery, short circuit its terminals with piece of wire for few seconds only then put CMOS battery back and reassemble everthing back as it was.
It'll reset all BIOS settings as well as the password and you'll need to re-enter all settings again.
PS: DON'T DO IT IF YOU DON'T KNOW HOW TO OPEN YOUR LAPTOP OR IF IT IS STILL UNDER WARRANTY.
Sep 23, 2017 | Toshiba Computers & Internet
How to set my password server
this would be in mail settings in phone settings - account properties
. POP Server or
IMAP Server Authenication required.
user name and password needed.
Feb 20, 2016 | Samsung Galaxy Note 10.1
I have an A8 POWER DZ09 Gear S Bluetooth Smart Watch. It says I need a phone password. I never set one. It will not allow me to use it with one. Can I factory reset it manually so I may use me watch?
Hello, maybe you need to set a password for the first time you will be using it try putting in one and if it says something like reenter password to confirm well that will probably solve it or you could try a default password like 1234 or 0000 and that may unlock it :)
Dec 30, 2015 | Cell Phones
Password
There is no other way to change the password to this model set. You have to consult the dealer for further advice, as its manual says.
Jul 08, 2012 | Panasonic TH-42PX6U Plasma TV
My face book page has a virus it keep posting things over and over to friends facebook page
I hope I can help!
Just to be clear, your facebook cannot technically have a "virus." There are two possible situations. Either you have been "hacked," or you have installed a malicious app accidentally (facebook game or other app). This should have a relatively simple solution.
1. In the case that you have been "hacked," you need to change your password. Really, you probably should do this regardless. When you log into your facebook page, click on the tab in the upper right corner that says "Account." Then click on "account settings." In these options should be one that says "password." To the right right of that should be a link that says "change." You need to click that, and when it gives you the option, enter your old password, and then a new password. You need to then click the button that says "change password." I strongly suggest you make your password a minimum of 8 random characters, preferably 12 or more.
2.To deal with a malicious app or facebook "program" that could be doing the posting (the most likely situation), you need to click on the "account" tab on the upper right corner of your facebook page. Select "privacy settings." On the bottom left should be a link for "apps and settings." Click the "edit" button. Where it says "apps you use" click "edit settings." It might be best to remove any apps that are not officially sanctioned by facebook, and maybe even just remove all of them. To do so, just click the "x" to the right of any of these programs and remove them.
I hope this helps, if I can be of any further assistance, let me know.
Jun 12, 2011 | Facebook Computers & Internet
I can not remember my wifi password. How do I reset to a new password?
Connect tot eh router with a cable and access the wireless setting through that. If you can't do that you would have to reset the router to default and then rebuild your network.
Dec 23, 2010 | Linksys Wireless-G Broadband Router
Forgot my password when i was setting up my i guess i put in the wrong pass word idk i need help!
go to your account where it say's forgot password retype a new password and got to your hotmail account to check youe message box and then it should say cofirmed your new password clikc on that and confirm it and everything should be back to you settings
May 20, 2010 | Cell Phones
When it tries to get ahold of the router it says I need a name and password. But when I try it another way it says I already have one and it wont let me connect it.
Try using the reset button on the back of the router to set it back to factory settings. Then try the default user name and password. usually admin and password is blank, or admin and password is password. Remember all your settings will be lost and you will have to set it up again. Also if you have the model of the router, I could give you further detailed instructions.
Thanks,
Lee
Aug 12, 2009 | Computers & Internet
Password
Try pressing "ok" if you did not set a password. Otherwise a password must be set on the computer like the one at the log on screen.
Jun 23, 2009 | Dell Dimension 3000 PC Desktop
How do I stop my Blackberry going on to standby
I don't know what you are referring to when you say STANDBY option, so I'll include what I know about the password option. Maybe you mean SECURITY TIMEOUT, or maybe your version calls it standby time..
Setting up a password for the device:
Scroll to select the SETTINGS/OPTIONS icon and press [Trackwheel] to select.
Scroll to select SECURITY OPTIONS and press [Trackwheel] to select.
Scroll to select GENERAL SETTINGS before getting the next menu.
Scroll to select the PASSWORD It should say ENABLED.
For most people the security timeout is set to 1 HOUR.
Setting up the time it takes for the BB to require a password:
Select the line you need to change, and Press [Trackwheel] to access the Menu
CHANGE OPTION should be highlighted Press [Trackwheel] to select.
Scroll UP to select ENABLED and press [Trackwheel] to select.
Scroll to select the SAVE and press [Trackwheel] to select.
System responds with NEW PASSWORD: input your new password press the <-| key.
System will ask you to re-enter your NEW PASSWORD: input your new password again and press <-| key.
Mar 09, 2009 | RIM BlackBerry Bold 9000 Smartphone
Tview D65TSG 6.2" In-Dash Navigation Logo
32 people viewed this question
Top Tview Car Audio & Video Experts
xxxxxx xxx
Are you a Tview Car Audio and Video Expert? Answer questions, earn points and help others
