Question about Poulan Mower Rider 30In 11.5 Hp B&S, Lrvb
Poulan pro 301 won't shift
Starts and runs but won't shift into gear
SOURCE: poulan riding lawn mower starts but won't shift into any gears
where do you tighten the cable for the cluch
Posted on May 20, 2010
hunter19_46m
  • 7482 Answers
SOURCE: Can't start my Poulan Pro weed eater. Never had
Hi jsbivens..
Sounds like you have dirt/debris in your carburetor jets,fuel passages or a diaphgram that is becoming non-flexible.
NOTE: Before you dissemble the carburetor:
Make sure you mark each piece with a Awl/Nail, or some kind of instrument that will make an alignment scratch before you dissemble the carburetor into separate pieces.
That way you will know which way it goes back together when you reassemble it.
Remove your spark plug and check to be sure you are getting fire at the spark plug.
You do this by grounding the plug on the head of the engine and pulling the crank rope, if you are getting spark then:
Be sure to check your fuel tank for water and dirt/debris, if there is water/debris then you need to clean your tank.
Also check you fuel line condition after a while they will degrade and need replacment.
Check/Clean/Replace your fuel filter if you have one, normally they are located in the fuel tank of weedeaters.
When you remove your fuel lines from the carburetor be sure to make a drawing to how the lines are connected to the carburetor.
Normally the big line will be the line the fuel filter is connected to inside of the tank.The smaller of the two lines is the return to the fuel tank from the carburetor after it is pumped thru the carburetor by the primer bulb.
Also make sure you are using fresh fuel...and oil mix if your using a two cycle mower or weedeater with the oil to the right mixture and not too much oil as it can cause hard starting.
If the mower/weedeater is over a couple of years old, then I recommend that you buy and install a new carburetor repair kit,because the diaphragm will get hard and that will cause it to be hard to crank.
Sounds like you will need to clean the carburetor or replace your carburetor internal rubber parts like the diaphgram and O rings.
I recommend that you use a laquer thinner type cleaner to clean and dissolve the laquer build-up in the float and needle jet passages.
Be sure to remove all plastic and rubber parts before using the laquer thinner because it can dissolve the plastic parts and render them unuseable.
Be sure to use compressed air to blow out all the fuel and air passages.
Be careful when blowing out the passages, because there are sometimes small rubber type seats in the bottom of some of the passages.
Sometimes you can get by with priming the carburetor or using starting fluid and letting it run a few times like that and it will flush the gunk out of the jets,but most of the time you will need to rebuild the carburetor.
Keep in mind that the float (if you have one) for the carburetor must be level when you go to reassemble the carburetor or follow the instructions you get with the carburetor kit.
When you clean your carburetor and remove the jet screws, you will first need to lightly seat the jet screws.
But before you lightly seat the jet screws count the number of turns it takes to seat the jet screws from their original position.
Be sure to mark the turns down on a piece of paper.
That way when you put the jets back in, you know to lightly seat them first and then turn them back out to their original position before you started.
Once you have your carburetor rebuilt that should solve your problem.
This is a FREE answer,Please take time to rate me
Posted on Jun 22, 2011
  • 692 Answers
SOURCE: We have a poulan pro
I would like to help but their are probably 100 screws on any given mower give or take . Can you look closer and try to find where it may have come from on your mower? Then maybe I can help with an answer as to where this screw goes and why your mower is not running.
Posted on Jun 25, 2011
  • 640 Answers
SOURCE: my poulan pro leafblower won't start, feels
Check that the spark plug is snug. If that is not it, then you should check the tightness of the head bolts. Sometimes they loosen. After that it could be a blown head gasket or a stuck valve.
Posted on Aug 11, 2011
  • 2239 Answers
SOURCE: Runs but the chain won't move? Poulan
This sounds loke the chainbrake has activated, grab the hand guard and pull it fimly fully back to the top handle until it clicks and the brake is of, now try again.
Posted on Aug 28, 2011
My polad pro 301 goes vey slow then stops in gear
Check your throttle cable on your control panel, The may have slip.
May 16, 2014 | Poulan Garden
Poulan pro 625 won't run
Its not getting gas ,check line and filter
Jul 26, 2012 | Poulan Garden
Poulan Pro riding mower won't turn right. I can
there is a plastic connector that holds the steering shaft down into the drive gear the plastic cracks and wears out then the gear jumps passed the teeth its about a $15 part
Jun 14, 2012 | Garden
Poulan won't start
check for spark then try carb cleaner behind the air filter
Mar 31, 2012 | Poulan Pro PR550N22SH 22Inch Briggs ...
Aug 28, 2011 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
Poulan 446t Will start, won't continue to
The diaphragm in the carb is likely ruined from the gas gelling onto it. This will put pinholes in it and then it won't work properly. Pick up a carb kit and rebuild it (if parts available) and then you should be good to go. If you can't rebuild the carb, a replacement will run you 30 bucks or more.
Aug 21, 2011 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
Why wont car shift into gear
Hello and welcome to FixYa!
You may want to start adjusting the brake pedals. If it detects that you are not stepping on the brake then it won't shift into gear.
If the gear is moving but won't shift gears while running then you may want to start on replacing the transmission fluid. It can be burnt that's why it's not operating properly.
Hope this helps and thank you for using FixYa! Have a good one!
Aug 14, 2011 | 1997 Ford Escort
My poulan pro leafblower won't start, feels like there's no compression
Aug 11, 2011 | Poulan Pro 25CC 2Cycle Gas Blower
Poulan Mower Rider 30In 11.5 Hp B&S, Lrvb Logo
99 people viewed this question
Top Poulan Garden Experts
Jim Parker
Jim Parker
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
