I would like to know how to boot xp from a flash.I have a compaq mini which does not have both a cd drive and would want to upgrade to xp professional from xp home.I have tried many options on the net but most do not seem to work.Kindly advice on the easiest and effective way
  • 72 Answers
This is the best way!! just check this out
VIEW
Posted on Mar 11, 2009
I have hp compaq 6730s before its got xp windows now the windows is corrupted now when I instal xp windows the system doesn't boot with external cd/dvd rom since the its own dvd rom doesn't work properly...
2008 PC from HP(old compaq name)
RECOVERY this PC ,per the book. (Ive done it)
this PC has a working F11 key if the HDD not bad, not changed out or the F11 partitions not damaged,
Power on hit F11 per the service manual. page 141
http://h10032.www1.hp.com/ctg/Manual/c01613452
CD boot fails
to boot to CD you must hit a key, called hit any key
to boot CD (aka. offically El Torito spec, wiki that and learn this)
If you dont hit (I use the huge space bar so easy to reach)
then no CD boots ever. by DESIGN. on new PCs that is true
and now you have to turn off SAFE BOOT too.
so those rules are first.
some PC, even make me hit (HP) the space bar to boot USB sticks this too is a fact. so do that.
my guess F11 is dead so you used discs, unstated disks , no HP disks (RIGHT>?)
XP the dead OS, this means adding things, , to the PC.
will fail. XP plug and play is dead, for vast things now for 3 long years, since MS ended this support. why not upgrade XP
to W7?
Old PCs do not like to boot , to external drives, its modern IDEA that (2008 is not too old,but IDK , if yours has it)
If you did boot to CD , inside or outside
XP (from MS ,not HP) will ask you to find drivers, and tell you to hit F6 and insert a floppy, tell me how you can get past here?
you cant, using NON HP install medial
XP is 2001 disks, 16 years old laying about. from MS
and guess what it cant see your HDD. due to no SATA drivers.
so the path you are on is full of pitfalls. see?
a modern feature in BIOS,its 100% a features of BIOS to boot any USB or External drive, (but eSATA might boot , not you no esata)
you posted with no mention of what external drive you have.
USB , esata, or what? Im guessing USB cable external drives.
the External drive needs a power pack to run right i most cases.
in bios, go to ALL screens, power on hammer F10
Setup bios is F10, go to all screens and turn on all USB features.
then change boot order to.
CD (hit space bar to boot CDs or DVD)
USB (hit space bar to boot USB devices (any key = space bar)
HDD.
then if all that above shows up F9 can be used to override above.
F9 only works if and only if.
1: bios supports it,! (IDK)
2: bios, has all USB features turned on, in other pages in BIOS.
including USB boot , turned on, if seen there. it must be on.
Enabled!
3: F9 only changes boot order this time, it does not enable features, that do not exist. ever.
why in the world not get a good CD/DRIVE. its like $10 used on ebay, pocket change, no?
or install with USB sticks?
there is legacy USB setting in BIOS, turn that on.
I can not teach you BIOS. (ive seen them all, so know this.)
but not yours, HP chances them like the weather, like the changing of the wind, directions. makers of BIOS changed 4 times!
and upgrades on BIOS changed on some HP PC, 10 times. or more. so I know NOTHING here, nor will most others due to that FACT. (unless theirs, is same as yours exactly)
only you can can explore BIOS, page by page and see what is there.
Test 1. (all techs have this in there KIT)
boot from USB stick, NOT external DVD drive)
if this fails doing DVD external boots is not possible.
find say any ISO for Unbuntu 17 linux, and burn the USB stick
using rufus. the boot the stick (fail now)?????????
that is the test for USB boot if that fails the PC is too old
and only fixing your bad DVD drive is the only cure.
Do not run XP with out SP3, once you have it running
XP has 700 exploits, and is a virus magnet.
never use XP is the best answer, but you you are not there yet.
so only BIOS matters now, that and only that NOW>
if the USB test 1 above works, I would.
id buy W7 from microsoft.com
the burn a stick
then load w7 , now it has future.
this PC is supported by HP in W7
here is the proof here
https://support.hp.com/us-en/drivers/selfservice/hp-compaq-6730s-notebook-pc/3687778
never run XP or VISTA today, 2017, they are now officially dead.
Learn that booting is a function of BIOS not windows.
windows is a goal and is only startup files to load windows.
booting happens at the lowest levels ,in BIOS.
BIOS has code in my newer PC to boot to any USB device.
but not external drives.
tricks for compaq old
6730b the CD is called,
'Notebook Upgrade Bay'
(odd name that)
but I have a SDD in mine so not so odd !
trick 2, is some compaq change sata to IDE or the CD will not boot. (sad no?)_
BTW my HP laptop can boot to both bays, HDD and upgrade bay
both bays in mine are SDD. one is w10 other is Ununtu 17.
booting to external drives are the most difficult tasks of all
some do , some dont.
but I always start with a stick first. test that , for booting
then go wild with external drives. (booting )
this is all for now, we can peel the onion as deep as you want, ask.
Nov 25, 2017 | HP Compaq 6730s Notebook
NTLDR compressed on a Compaq Presario SR105CL cant enter bios to set to boot
Step 1:
Which operating system ?
Computer is booting from a non-bootable source. Computer hard disk drive is not properly setup in BIOS. Corrupt NTLDR and NTDETECT.COM file. Misconfiguration with the boot.ini file. Attempting to upgrade from a Windows 95, 98, or ME computer that is using FAT.32 New hard disk drive being added. Corrupt boot sector / master boot record. Seriously corrupted version of Windows 2000 or Windows XP. Loose or Faulty IDE/EIDE hard disk drive cable. Failing to enable USB keyboard support in the BIOS. Many times this error is caused when the computer is attempting to boot from a non-bootable floppy disk or CD ROM First verify that no Floppy Diskette or CD is in the computer, unless you are attempting to boot from a diskette. b> Note: This error has also been known to occur when a memory stick is in a card reader and the computer is attempting to boot from it. If you have any card reader or flash reader make sure that no memory stick is inside the computer. Additionally disconnect all USB drives, cameras, ipods, iphones, etc. from the computer. If you are attempting to BOOT from a floppy diskette and are receiving this error message it is likely that the diskette does not have all the necessary files or is corrupt. If you are attempting to install Windows XP or Windows 2000 and are receiving this error message as the computer is booting verify that your computer BIOS has the proper boot settings. For example, if you are attempting to run the install from the CD-ROM make sure the CD-ROM is the first boot device, and not the hard disk drive. Second, when the computer is booting you should receive the below prompt. Press any key to boot from the CD
Mar 10, 2013 | Compaq Presario sr1055cl PC Desktop
How to unlock password for a HP 2140 Mini-Note
If you are talking about the login to Windows password then here is one way to do it:
Create a bootable USB stick using this tool: http://www.pendrivelinux.com/yumi-multiboot-usb-creator/
Use the image from Ophcrack to load onto the USB: http://ophcrack.sourceforge.net/download.php Choose the XP LIVE CD Option
1. Download the YUMI exe to your desktop 2.. Save the LIVE CD of Ophcrack to your desktop. 3. Plug in the usb stick you want to use (make sure it is at least 500MB. 1GB if possible) 4. Run the YUMI EXE and follow the instructions. Make sure to choose the USB Drive Letter ("D:" E:" etc) 5. Choose the Ophcrack ISO for the image. 6. Install to USB 7. Click Finished and exit the program and close any other open programs. 8. Restart the computer. Leave USB plugged in. 9. As soon as the computer restarts, tap the F10 button to enter the BIOS Menu. 10. Scroll to the Boot / Advanced Menu and change the boot order to USB first, HDD second. 11. Save and exit BIOS. Computer will restart. 12. Once booted up the computer will bypass the HDD and boot into the USB 13. elect Ophcrack from the list and hit Enter. 14. Follow the on-screen instructions to have Ophcrack force the password.
(If you're using Linux then use the Linux LIVE CD Image instead of XP)
May 03, 2011 | HP Mini 2140 Notebook
WHY I CANNOT SETUP WINDODS XP.
If you have a newer operating system like vista or 7, you can't do an upgrade but you can do a fresh installation.
Enter set up (usually F12 or F2 on Compaq). Change the boot order ( following the key on the bottom and right side of the page).
Make the cd or dvd the first boot device. Insert your XP installation disk and reboot the machine. You will be prompted to press any key to boot from cd...do so.
Start up should begin. If there is an operating system on it you will be given the opportunity to delete already formatted partitions...do so. you will be left with an unformatted drive (or one partition, st up windows in that partition.
If you are using an upgrade disk and have a newer OS you will have to wipe the drive first.
If you need to wipe your drive first you can do it with this free program.
http://www.diskwipe.org/
Good luck
Oct 30, 2010 | Compaq Computers & Internet
Hi I have a compaq presario C700 laptop which is currently running on Window Vista i want to change to Window XP instead of Vista can you please give me the requirements and the steps to do this please
You'll have to buy a copy of XP--probably from eBay or Craigslist. You may be able to use an upgrade version, but you'll need an install disk for 2000, or 98 to validate.
Boot from the install disk and remove the partitions from the hard disk. Then install using the defaults.
You might want to download the drivers from HP.com prior and store them on a cd or flash drive before doing the change over. If you have files that you want to transfer, copy those to the cd/flash drive as well.
Jun 18, 2010 | Computers & Internet
I have a compaq presario 5000 desktop wont boot in xp where can i find a startup disk i can upload to my zip drive?
hello, check the link below for all kind boot disks/cd/floppy flash drive etc...
Look in the computer BIOS to see if your zip drive is listed under boot options, if yes then you can use your zip disk to boot.
I hope this helps, let me know if you have any other quetions.
good luck
regards,
Amar Sondhi
Dec 06, 2009 | Compaq Presario 5000 PC Desktop
Can I upgrade my CompaqMV720 computer from Windows ME to Windows XP? If so, how?
I would think that you mast likely can do it. You need a Windows XP disk with a legitimate install key (or Microsoft will give you a hassel). When you are ready to upgrade, turn on or restart your computer and press [Delete] to enter the BIOS. Go to the Boot menu and change the boot order so that your CD/DVD drive is first.
Open the drive and put Windows XP disk in. Press the F10 key to save the changes and exit. when the computer restarts, it will provide several start options. Choose the one that will install Windows XP. From there you just follow the prompts.
Jun 03, 2009 | Compaq MV 740 17" CRT Monitor
Boot pc problem
You can solve this by going into the bios setup & changing the boot order. Make the dvd/cd drive 1st in boot line then hdd. This should allow you to boot up from the windows xp disc. Hope this helps & please rate this solution fixya. Thanks.
Feb 04, 2009 | HP Compaq EVO D510 Intel Desktop PC -...
Evo N410 usb boot
yes u can
its a long procedure so i would suggest u to go through the following pages
http://articles.techrepublic.com.com/5100-22_11-5928902.html
www.bootdisk.com/pendrive.htm
Apr 26, 2008 | Compaq Evo N410C Notebook
Computers & Internet Logo
27 people viewed this question
David Payne
David Payne
