Question about Amana ACF3355AS Gas Kitchen Range
Fuse location amana gas stove
Electronic display doesn't work so you can't operate the actual oven yet when plugged in the stove-top still works..is there a possible fuse or reset on the stove that would allow me to make the display work again and where would that be?
SOURCE: Amana ARG7300w oven inop
It has a bad oven igniter.
Posted on Aug 27, 2007
  • 4 Answers
SOURCE: AMANA GAS RANGE ARG7302
sounds like the thermostat
Posted on Dec 11, 2008
jumptrout51
  • 3361 Answers
SOURCE: Amana gas oven not working
The ignitor may be too weak to open the gas valve. If you have a volt/ohm meter capable of reading AMPS you can hook up to a ignitor wire and turn the oven ON. If you read less than 3.5 amps replace the ignitor. If 3.5 amps or more are read,replace the gas valve.
Posted on Aug 30, 2009
Testimonial: "Thanks for the good info."
  • 80 Answers
SOURCE: Hello. Regarding my Amana range (MODEL: AGDS902),
You will have to replace the bottom element.
John
Posted on Oct 03, 2009
aborcass
  • 2651 Answers
SOURCE: Amana stove, oven igniter works but oven wont light
although the bake ignitor appears to be glowing, it probably does not glow with the intensity it needs to open the safety valve assy, VERY common problem, go aheadand replace the ignitor, this will correct your issue
Posted on Feb 09, 2010
Testimonial: "100% correct, I ordered the part from on line and it was a very easy fix and the oven is working great. Thank you"
We have a Frigidaire electronic ignition range about a decade old. The stove works fine. But lately we've noticed if we're using any stove elements the oven won't ignite and heat up. Conve
Sounds like the pressure regulator on the stove is going bad. The pressure regulator is located in the back. Your gas supply line should connect directly to it.
Dec 23, 2012 | Kitchen Ranges
My Maytag Performa glass top stove does not work. The oven doesn't heat up but the stove top works fine. I checked my fuse box downstairs and it is fine. I checked the stove to see if there were any...
Dear Gina,
It should be one of 3 things.
1) The element has burned out, or
2) The socket the element plugs into has failed, or
3) the wires hooked to the socket have toasted.
Someone must take the stove apart to see.
God bless your efforts.
Oct 26, 2017 | Maytag PER5710 Performa Electric Kitchen...
My stove is flashing this code "-F1-" on the display, some of the buttons work and some do not. All of the problems started at the same time. Also, the front right side by the knobs seem...
Hello & Welcome to FixYa
Error code F1 indicates electronic control failure and is displayed due to electronic oven control failure and the only way to solve this problem is by replacing the control board which is bad. Please get back to me if you have any other questions.
Kevin
Feb 03, 2011 | Amana ACS7270AS Electric Kitchen Range
Display on oven reads FFF. the oven no longer works but the stove top does
Try unplugging the range for about 15 minutes. The ERC (electronic Range Control) may reset itself. If you still have the fff code on the control it will need to be changed out.
Apr 03, 2010 | Amana RanARG7302 Gas Kitchen Range
I have an amana gas stove model ARG7800WW . The cook top works but the display (Clock Timer) doesn't light up and the oven doesn't work.
u need a new clock , or the oven wont work , u can bypass the clock to get the oven going but u need to know which two wire to join
Oct 27, 2009 | Amana ARGS7650SS Gas Kitchen Range
Oven won't heat
do you see a bright glow in the oven area when the oven is turned on it will take 20 secs or so..If not your ignator maybe bad no gas will flow into the oven unless the ignt. is good
Mar 03, 2008 | Kenmore 30464 / 30465 / 30469 Gas Single...
Amana ACF3355AS Gas Kitchen Range Logo
63 people viewed this question
Top Amana Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Sal De
Are you an Amana Kitchen Range Expert? Answer questions, earn points and help others
