Question about Uniden Cordless Phone
Lost my manual for older uniden tru8806-3 - it keeps flashing but the phone isn't ringing
8 year old son was using phone hung up and its been flashing since
SOURCE: The flashing light on phone
Press down the "find handset" button until the paging beep stops (about 5 seconds) and this will reset the indicator lights on the handsets.
Posted on Jan 20, 2009
divatif
  • 39 Answers
SOURCE: uniden 5.8Ghz phone.
You need to reset the main base unit. Unplug the power from the back of the base. While the power is disconnected, press and hold the delete key while reconnecting the power. Wait for a long beep tone. When the display shows 88 or P, press play button one time. If you have a phone without an answering machine, disconnect the power from the back of the base, press and hold find hs button while reconnecting power.
Posted on Mar 17, 2009
ginko
  • 19396 Answers
SOURCE: lost manual
Without the exact model it is difficult to find the manual.
Here the manual for 900 series/996:Uniden EZI996.
I also quote from manual:
Selecting the Ringer Tone and Volume
Base ringer on/off
The ringer switch allows you to set the base ringer on or
off. If you set the switch to off, you never hear the base
ringer tone.
Base ringer tone
Press the ringer tone button in standby mode to select one of 7 ringer tones.
Base ringer volume
Slide the ringer volume adjuster to set the base ringer volume.
Handset ringer tone and volume
Press the volume up key or volume down key (labeled as the volume/ /+ or volume/ /- key) in standby mode to select one of five ringer tones and volume combinations
Posted on Apr 17, 2009
SOURCE: Uniden cordless: Adjusting ring tone volume down
If it is like mine....push on one of the volume buttons (up or down,doesn't matter) and the phone will ring. WHILE IT RINGS, push the button again and it should scroll to the next ring option. Keep pushing WHILE it rings to scroll through the ring options.
Posted on May 30, 2009
  • 102366 Answers
SOURCE: uniden dect 6.0 _cordless phone.
Select the model of your Uniden DECT 6.0 phone from the list beginning at
http://www.uniden.com/owners-manuals/dect-phones/scat/dectphones_mnl/
to download a copy of the manual.
Posted on Sep 21, 2011
Light keeps flashing on phone have put new batteries in and also the phone only rings once before going on to message bank
Since you didn't specify the model of your Uniden phone I can only suggest you select it from the list beginning here to download a copy of the manual.
Mar 04, 2013 | Uniden Lands Phones
My uniden xdect sse25 cordless doesn't ring for long enough before diverting to the answer machine I have mobility problems how can i extend the length of the ring
From the handset, press Select/Menu and then press the down arrow to get to Ans Setup. Press Select again. Go down to Ring Time. Then select the number of rings (6, 9, 12 or Toll Saver (TS)). Press Select then press Flash/Exit to exit the menu system. Toll Saver picks up after 2 rings if you have new messages or 4 rings if you don't. This lets you hang up before the answering system picks up if you are using the remote phone access feature.
Note: if you have Voice Mail from your telephone provider, you need to set that to a longer number of rings separately. Consult with your phone company on that option.
The manual for the XDECT SSE25 is available from Uniden here: http://www.uniden.com.au/RESOURCES_MAIN/pdfs/XDECT_SSE25_OM.pdf . See page 19 (23 of the PDF). You will need Adobe Reader to access the manual.
I hope this helps.
Jan 25, 2013 | Uniden Cordless Phone
How do I extend the ring time on Uniden D1600?
The D1600 isn't an answering machine. Please refer to the documentation for whatever answering machine you have connected to your phone. If you need further assistance, feel free to reply to this post but be sure to specify the make and model of the answering machine.
Nov 05, 2012 | Uniden DECT 6.0 Cordless Phone ID
I purchased a Uniden DECT1580 Series phone and can't change to a personal greeting. It states to select command 8 and I can't find command 8.
My copy of the manual states: "Press 8 to start the recording." That's the "8" button on the number pad, between the "7" and "9" buttons :-)
I'm using the manual I downloaded at
http://www.uniden.com/content/ebiz/uniden/resources/ownersmanuals/DECT1580om.pdf
Sep 20, 2011 | Uniden Cordless Phone
I have a Uniden cordless unit hooked in 4 lines. Incoming calls ring briefly for about 1 second and go out! You can talk if you pick up but not sure why no normal rings. There is no problem calling out....
When someone calls you and your phone behaves this way, does the caller get disconnected? The phone may be causing this, but it may also be due to trouble in the telephone line itself. The trouble is caused by defective wiring, a partial short circuit. When you pick up your phone to call out, the voltage on the phone line is low and it works normally. When you get an incoming call, a high voltage is sent to ring the phone. Because of the partial short, the phone company's equipment thinks you've answered the call as soon as the ringing starts. But you haven't picked up the phone, so the phone company's equipment thinks you've hung up and disconnects the call. The result is that short burst of ringing.
Disconnect the cordless phone base unit from the line and try another phone. If you still have the trouble this confirms the line is at fault. You'll need to contact your phone service provider for service. If it's in the outside wiring, they're responsible for repair. If the problem is in your home wiring, you may need to pay them unless you have a wiring maintenance plan.
If the problem goes away when the cordless base is disconnected, then it's time for a new phone.
Jul 16, 2011 | Uniden Cordless Phone
I have a Uniden dect 6.0 and not ring it, because it's a "silent mode on". As it sets off this option??? I need take ring ON!! Sorry I lost the instrucction manual.
Since you didn't specify the model of your phone, select it from the list at
http://www.uniden.com/scat/cordlessphones_mnl
to get the manual.
May 18, 2011 | Uniden Cordless Phone
The visual ringer keeps flashing on my uniden cordless phone
I CALLED UNIDEN WITH THE SAME PROBLEM.
THE VISUAL RINGER IS FLASHING WHEN YOU HAVE OLD EMAILS. YOU HAVE TO DELETE THE OLD EMAILS
Feb 10, 2010 | Uniden Cordless Phone
I lost my manual for the uniden cordless phone about 3 years old. I would like to program numbers into the phone's memory
phone.manualsonline.com/manuals/.../uniden/uniden_telephone_product_list.html -use this link
Jul 23, 2009 | Uniden Cordless Phone
GE Cordless phone "Do not Disturb" setting
There is a button on the main base that says " Do not disturb" my 4 year old son must have pushed it. It was an easy solution.
Thank you!
Jun 16, 2008 | Uniden Cordless Phone
Uniden Cordless Phone Logo
Top Uniden Lands Phones Experts
k24674
Are you an Uniden Lands Phone Expert? Answer questions, earn points and help others
