Question about 1995 -2003 Ford IPR Valve 7.3L Power Stroke
Used moter will run on starting fueld but stops when stop
Put in used moter now it will not start
    Top Expert:
  • Motorcraft Master
  • 51,198 Answers
Check for fuel blockage to the system /carby. check that the float is not stuck off
Posted on Jul 29, 2013
Changed driver door secerity ligt blinking kills moter lights flash how do i stop this
new drivers door
you drop battery neg lug first before work(per fsm warnings)
you made short circuit and borked the vtss or skim
so not the immoblizer lamp in dash glows, it dont lie.
as that cuts fuse after 3 second run time (by design!)
use a scan tool see what errors you have,
that be first.
check all fuses 1st first;.
Jan 20, 2015 | 1994 Jeep Grand Cherokee
Picture of a moter on my light board book says its something to do with emissions
It looks like an engine. This is the check engine light. Have the codes read. Re post and we can help. Keep driving and your car could stop running or moving.
Dec 28, 2014 | 2007 Honda Pilot
Moter turns over but wont start. and windos stops working after moter start.
02 ford/?
wont start, then starts. im confused.
check all fuses. first.
Dec 18, 2013 | 2002 Ford Explorer - XLT - Speed Grille
How do u wire a three phase squirrel cage motor with a motor starter with a remote start/stop/inch station and warning indicator light ?
You would first run a conductor fromL1 to L1 on the motor start then run a second conductor from L2 to L2 on the moter starter, then run a third conductor from L3 to L3 on the moter starter. next run L1 and L2 to a step down transformer so you can reduce your working voltage to 120vac, then run a conductor on one of the outputs from the step down transformer to one side of the normally closed contacts on the STOP push button, from the other side of the stop button run a wire to one side of the start button, on the other side of the start push button run a wire to one side of the magnetic motor starter coil, the other side of the coil run a wire to the other empty terminal on the transformer, this will be the neutral wire. next you need to run a wire from the normally open contactor on the magnetic moter starter to one side of your push button start switch, then run one wire from the other side of the start push button switch to the other side of the normally open contacts on the magnetic moter starter, this is your start switch latch that will keep the motor running when the start push button is released.I'm not sure how you need the warning indicator light wired up, so please reply and let me know when it needs to come on and go off
Feb 04, 2010 | Delta TP300 Shopmaster 12-Inch Portable...
Dry want start
you will nead a nother person to help you make this test.first open the dryer door,next put the timer on timed cycle.with your right hand hold in the door switch,next have someone push the start button and at the same time take your left hand and turn the tub clockwise.if it starts than you have a bad moter.the age of the dryer will determin wether it is worth fixing.
Jan 23, 2010 | Whirlpool LER4634J Electric Dryer
My old GE potscrubber 700 dishwasher stopped working
moter has probably locked up TAKE FRONT LOWER PANEL OFF AND YOU CAN ROTATE ROTOR/ if itis not free and rotates easly then the motor has failed / mm
Dec 07, 2009 | Dishwashers
Moter runs fast then slows down
check for intake leaks or idle speed control problems.
Apr 28, 2009 | 1988 Chevrolet Camaro
Wiper harness at the moter 93 1500 chevy sub.
their is a shrot in the colum
if you put in a toggle switch,run directly from the battey and use a nob that way you can cotrol the speed just by turning it
Feb 14, 2009 | 2002 GMC Sierra C/K1500
Dryer stops after 5 minutes
dryer moter is covered with lint and over heating.if the moter is not completely burned out `you mite clean it with air pressure .if it still does it `replace it.
Feb 21, 2008 | Kenmore 62602 Electric Dryer
1995 -2003 Ford IPR Valve 7.3L Power Stroke Logo
41 people viewed this question
Top Motorcraft Vehicle Parts & Accessories Experts
David Payne
David Payne
Larry Chandler
Are you a Motorcraft Vehicle Part and Accessory Expert? Answer questions, earn points and help others
