Question about Poulan Pro Gas BlowerVacuum ()
How do the gas lines on a Poulan Pro BVV200VS look? I have one line with the filter on it and the other line looks like something was suppose to be on it.
    Sergeant:
  • 260 Answers
The smaller line returns gas to the tank from the carburetor. Top of gas tank is fine for location.
Posted on Oct 25, 2017
SOURCE: gas line connections
The thicker of the two lines goes on top nearest to the primer ball
Posted on Mar 25, 2009
#1 Taper
  • 1040 Answers
SOURCE: need gasline size
The best way to get the correct size lines is to take a piece of the old lines to your local outdoor power & equipment store, or sometimes your local auto parts store will carry them, and let them match them up. You may have two different size lines, so make sure to get pieces of both.
Jim
Posted on May 29, 2009
SOURCE: poulan te 450 cxl fuel lines need routed correctly
Other line is just left open like to send gas back from the carb.
Posted on Jul 15, 2009
dontbother10
  • 2220 Answers
SOURCE: Poulan 295 Pro won't start. Changed gas and
I suspect the carburetor is full of remnants of the same fluids you found in the tank. If it was my saw I'd take it to the local Stihl dealer for an estimate to repair. I'd expect to pay $40 - 80 for a tune up and repair depending on how many fuel hoses must be replaced. HTH
Lou
Posted on Oct 28, 2009
dontbother10
  • 2220 Answers
SOURCE: I wish someone out there could draw me a diagram
You can find a typical fuel system and a couple of suggestions here:
http://www.fixya.com/support/r3706813-2_cycle_fuel_system_repair
An IPL for a Poulan PP210 can be found here:
http://www.ordertree.com/modelinfo/PWE/PP210-Gas-Saw/75.PP210-Gas-Saw.1.59.1.html
The small hose goes between the filter and carburetor and from the IPL the carburetor and primer.
The large hose between the primer and fuel tank (return).
Hose can be purchased at any chainsaw outlet, Inquire about how much hose they recommend. I have not found a good hose stretcher and I have been looking. Good luck with your project.
Lou
Posted on Jan 30, 2010
Poulan pro troubleshooting
Try changing the fuel filter in the tank.
Jul 12, 2014 | Poulan/Weed Eater PP030 966805501 Poulan...
I have a Poulan Pro leaf blower/vac. The fuel lines cracked inside the gas tank so I pulled them out & bought new ones. Now i can't get them back in to the gas tank. I understand there are
Make sure that you have the right size lines the smaller diameter line goes into the bottom hole of the tank cut a 45 angle at the end of the line as you put the line into the tank twist and push until you get enough line to pull up through the fuel filler hole then cut the line so that the 45 is no longer and slip the fuel filter on then pull back the line until the filter rests at the bottom of the tank. Do the same with the upper line except that line will only go in 3 to 4 inches. I hope this helps you.
Feb 29, 2012 | Poulan Pro Gas BlowerVacuum ()
Need to replace both fuel lines on My BVM200 LE leaf blower, 1 large and 1 small fuel line, can You tell what size they are??
On your blower, it looks like the small line supplies fuel to the carburator which will be connected to the fuel filter in the tank, and the large line looks like the fuel return line.
http://www.ereplacementparts.com/poulan-type-gas-blower-parts-c-16962_31724_131359.html
Jul 19, 2011 | Poulan Pro 25CC 2Cycle Gas Blower
Looked in gas tank, filter was free with nothing attached.
The filter is part of the clunk valve which is supposed to keep your fuel supply line submerged in the deepest part of your gas supply. Haul out the filter and the end of your gas line and reunite them.
Mar 21, 2011 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
Trying to replace the fuel line and the primer hose both were rotted off not sure what goes where on my poulan pro ppb200 31cc string trimmer there are two lines into the tank the primer wont fill i have...
The smaller line is connected to the fuel filter in the tank and goes on the carb body opposite the end with the hole in the cover. A larger diameter line coming out of the tank is the fuel return line and has the little connector on it just inside the tank to hold it in place there
It goes on the carb body (if primer is on carb) by the bulb.
If there is an external bulb...the small line is the same...there would be a larger line going from the carb body (nearest the end with a hole in the cover) to the smaller nipple on the primer bulb. A third larger diameter line would be connected to the larger nipple on the primer bulb and running to the little nylon connector inside the tank. This is the fuel return line and the smaller diameter line is of course the fuel supply line.
Aug 07, 2010 | Poulan Pro Pp125 25cc Gas Straight Shaft...
Gas line with filter broke inside tank how to
get new line cut end at an angle , lube with oil and twist it in, snag the line and pull it out the filler hole and insert filter on the end, connect and enjoy.
May 28, 2010 | Poulan/Weed Eater No. Te475 952711797 17"...
Replacing gas line
Your fuel lines are routed like the schematic below. I suggest you replace the filter, all hoses (2 different sizes), and the purge button (bleeder).
May 07, 2010 | Poulan ES350 16" Chain Saw
I wish someone out there could draw me a diagram of how the gas line are supposed to be routed on poulan pro 210 chainsaw
Lou
Jan 29, 2010 | Poulan Garden
I need info on a Poulan Pro 445 fuel line routing
I'm so confused. This is reported as a Poulan and McCulloch pole saw, which one? Is it a pole saw? That is the only 445 Poulan I can find. It is reported as an electric but has a fuel routing problem.
If it is a Poulan Pro gas pole saw it is here: PP445 Gas Pole Pruner
The fuel system routing is terrible, but it is all there is.
Fuel Routing follows:
Tank to carburetor (hose in tank with filter on free end)
Carburetor to primer (primer draws fuel from the tank through the carb)
Primer to fuel tank (returns any excess fuel to tank when pushed) HTH
Lou
Oct 11, 2009 | McCulloch 10" Electric Pole / Chain Saw
Poulan Pro Gas BlowerVacuum () Logo
143 people viewed this question
Top Poulan Garden Experts
Roland W VanLue
Roland W VanLue
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
